Posted: Wed Mar 19, 2003 6:52 am Post subject: Saggy Butt |
How do I do a lift on a Saggy Back End. LOL
Its not really saggy, but just a slight bit lower than the front end. Is there an easy fix for this. |
ChrisM181 Samba Member
Posted: Wed Mar 19, 2003 8:06 am Post subject: Saggy Butt |
Thers only one way to fix this, the right way, which would be to re-camber your rear suspention. You need to remove your spring plates and back them down a tooth or two. Every Thing owner should own a Bently type 1 manuel becuase it will help you out in a lot of situations! It will show you what to do.
I made a secret weapon for doing this, I took a VW jack and welded a bolt on the end of it, it helps you get the spring plates back up over the stops!! |
Posted: Wed Mar 19, 2003 8:07 am Post subject: Saggy Butt |
There is only - opps |
Posted: Wed Mar 19, 2003 2:30 pm Post subject: Saggy Butt |
Well, 1st of all, exersize and put the cookies down. Quit eating all that junk food!!!! J/K. Just do what i did to my 74 Thing, drop the front end with bug arms and spindles, problem solved. |
Posted: Wed Mar 19, 2003 11:02 pm Post subject: Saggy Butt |
Thats about the worst advice I could think of!!!
Weaken your front suspention to compensate for a sagging rear suspension, why on earth would somebody want to do that? |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Thu Mar 20, 2003 6:37 am Post subject: Saggy Butt |
It's a valid option but unless you want a lowered thing the rear should be brought back up by reindexing. Here is a link that explains how to do just that,it is for a 70 bug, but the adjustments are done the same way on your thing,at the least this will give you a good idea how to do it.http://www.geocities.com/aussiebug1970/rearaxle.html Good luck. |
Posted: Thu Mar 20, 2003 12:16 pm Post subject: Saggy Butt |
Sorry Chris181, have a sense of humor for pete's sake and put the cookies down. No, really, just do like Tim G. said and re-index the rear end, but be carefull, u really need to know what your doing, if not, u could loose a finger in not more. Those spindles are under a tremendous amounts of tension. I'd take it to a VW shop, but to each his own. Good luck and lets us know how u do it. |
edgy Samba Member
Joined: January 22, 2003 Posts: 424 Location: Bel Air, Maryland
Posted: Fri Mar 21, 2003 2:27 am Post subject: Saggy Butt |
This month in 181 magazine, there is an article on doing just what you have asked. |
Posted: Fri Mar 21, 2003 10:46 am Post subject: Saggy Butt |
181 Magazine. ??? Have yet to see that!!
Send me a copy!! |
Posted: Fri Mar 21, 2003 10:47 am Post subject: Saggy Butt |
Oh and I like the cookies, they are just too hard to put down, especially if you Got Milk!! |
TimGud Samba Member
Posted: Sat Mar 22, 2003 9:29 pm Post subject: Saggy Butt |
Or Oreos! |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sun Mar 23, 2003 2:38 pm Post subject: Saggy Butt |
saggy butt's make me want to toss my cookie's...  |
TimGud Samba Member
Posted: Sun Mar 23, 2003 6:00 pm Post subject: Saggy Butt |
Ya,and when the front drops things don't get any better looking. |
Posted: Fri Mar 28, 2003 9:36 am Post subject: Saggy Butt |
What about putting coilover shocks on the back? I head they can lift the suspension 1-2 inches. |
Posted: Fri Mar 28, 2003 7:42 pm Post subject: Saggy Butt |
Yeah coil overs will do that, and KYB whites too... but the point is those are just band-aids, best to reset the torsion bars porperly if you can or as soon as you can... |
