redharleydude Samba Member
Posted: Tue Oct 03, 2006 10:42 am Post subject: Arm rest that mount to the seats |
does anyone know where you can get a pair of arm rest that mount to the seats for an oval? Or does anyone have any plans on how to make them? Any help would be welcomed. THANKS! |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Tue Oct 03, 2006 2:11 pm Post subject: Re: arm rest that mount to the seats |
redharleydude wrote: |
Bob Koch made repros of those. He still may have some.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Tue Oct 03, 2006 5:13 pm Post subject: |
i have seen a picture of the ones he build. Wondering how they mount to the seat frame |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
thai56oval Samba Member
Posted: Tue Oct 03, 2006 7:21 pm Post subject: |
Hi,
Do you think it can be used for right hand drive car ?
Thanks |
Posted: Tue Oct 03, 2006 7:26 pm Post subject: |
thai56oval wrote: |
Hi,
Thanks |
I don't think so, because the one's I've seen were only able to attach to right of the driver's seat. You might check with Coad........I think he has an original one. There was even a double one made but it too attached to the right side of the driver's seat.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Tue Oct 03, 2006 7:35 pm Post subject: |
53 0val wrote: |
thai56oval wrote: |
Hi,
Thanks |
I don't think so, because the one's I've seen were only able to attach to right of the driver's seat. You might check with Coad........I think he has an original one. There was even a double one made but it too attached to the right side of the driver's seat.  |
Thanks Bob, a 100 bucks saved then  |
coad  Samba Scapegoat
Posted: Tue Oct 03, 2006 8:05 pm Post subject: |
53 0val wrote: |
thai56oval wrote: |
Hi,
Thanks |
I just looked at mine. I could reverse the bracket and mount it on the opposite seat in my 55. I think it should work.
They are really nice to have on the car. |
Posted: Tue Oct 03, 2006 8:07 pm Post subject: |
coad wrote: |
53 0val wrote: |
thai56oval wrote: |
Hi,
Thanks |
I always check with Coad. The man knows everything.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Tue Oct 03, 2006 9:44 pm Post subject: |
RareAir wrote: |
Yes, it'll work. I've seen Ghias that use two of the amrests since those cars have a wider area between the seats. |
If the arm rest could be rotated.........I can see how it would work, but I just looked at the one I have, and it is welded to a piece of metal that cannot be reversed. I guess it would depend on how it was originally made.  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Wed Oct 04, 2006 2:34 am Post subject: |
any chance someone could post a picture with the armrest mounted the the seat. |
Kais Collection  vintage treasures
Joined: February 18, 2005 Posts: 1570 Location: Rotterdam, The Netherlands
Posted: Thu Oct 05, 2006 4:35 am Post subject: |
this was mine, I think it was one of Koch's:
_________________ Insta: @kaiscollectionvt
Fb: @KaisCollectionVT
Please check my ads: https://www.thesamba.com/vw/classifieds/search.php?username=Kais+Collection
Kai's Collection - vintage treasures |
Posted: Thu Oct 05, 2006 2:38 pm Post subject: |
thanks a million for the pic. I think maybe I will make one cant afford $100.00 for one of Koch's. Thanks again. |
Posted: Thu Oct 05, 2006 2:49 pm Post subject: |
If it helps I'm pretty sure the round pipe between the clamp and the armrest itself started life as a piece of electrical conduit pipe then it gets slightly flattened at both ends.
The armrest itself is a block of wood with a notch in it to hold the pipe and a nut and bolt drilled through to hold the pipe in place. Easy enough to make especially since even if you buy one you still need to have someone cover it with vinyl or cloth anyway. |
Posted: Thu Oct 05, 2006 4:16 pm Post subject: |
again many thanks!!! |
Posted: Thu Oct 05, 2006 4:22 pm Post subject: |
coad wrote: |
The arm on mine is crimped on the inside edge to fit up against the seat frame. I don't see any way that it would look correct on the passenger seat, but the one in the photo could easily be reversed. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
bugzey Samba Member
Joined: September 19, 2005 Posts: 285 Location: Tucson, Az aka. Hell!
Posted: Mon Feb 26, 2007 12:56 am Post subject: |
Does anyone have an idea of what an "original" one of these is worth?
 _________________ Invest is Precious Metal
....buy a Frigin Old Volkswagen!!!
.........___
.....(o\_!_/o) |
Posted: Mon Feb 26, 2007 7:40 am Post subject: |
bugzey wrote: |
I haven't seen any sell within the last year, but depending on condition, as high as $400. (especially with the way the EURO is going now.) _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
