thom Samba Member
Joined: October 12, 2000 Posts: 6202 Location: Sacramento
Posted: Sat Aug 09, 2025 4:27 pm Post subject: Another "unable to close long spoon latch" thread |
I found a few other threads about people being unable to close their long spoon latches, but I didn't see any resolution.
https://www.thesamba.com/vw/forum/viewtopic.php?t=755254
https://www.thesamba.com/vw/forum/viewtopic.php?t=507647
I'm currently having the issue with my bus; here's a crappy video (the GoPro couldn't focus that closely) https://i.imgur.com/q3idyta.mp4
And another that's better quality from a different angle. https://i.imgur.com/Bf10izh.mp4
I tried with both an original latch and a AAC reproduction (which is really nice, BTW). I did some basic measurements and they're virtually identical.
Yes, I have the spacer installed. I bought a pair of the WW spacers, which are a tiny bit thicker than original - it made no difference
Yes, I know there's fore-and-aft adjustment on the rear latches - there was no magical adjustment that let them close.
When installed on the other window openings, the symptom is exactly the same.
No, I didn't have the body-side seal installed yet
The kicker is, this bus had long spoons when I got it (except for the front passenger-side cargo door).
The popout frames are the originals to this bus.
The popout latch is original to this bus
On the cargo doors, the latch wants to drag across the door frame when closed.
What's the secret to getting these things installed? I don't have any good up-close pictures of the window latches from before I dismembered the bus.
For the time being, I'm using the 'medium' spoon latches.
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15282 Location: Casa de Oro, California
Posted: Sat Aug 09, 2025 6:12 pm Post subject: Re: Another "unable to close long spoon latch" thread |
I can't help you but in the videos there is metal fatigue occuring right before my very eyes so I hope you don't get cracks in that newness of everything or tweak a frame. |
John Ghia Samba Member
Posted: Sat Aug 09, 2025 8:50 pm Post subject: Re: Another "unable to close long spoon latch" thread |
In Your video it looks like the tab on the frame is hitting the latch and you don’t have all the screws on the body side. I’ve had luck adjusting the 2 screws at the frame. _________________ BUS BOYZ |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 477 Location: Mississippi
Posted: Sun Aug 10, 2025 6:30 am Post subject: Re: Another "unable to close long spoon latch" thread |
thom wrote: |
It wasn't designed to work without all the parts. It should operate correctly once the window frame contacts the seal in the window opening. Otherwise you are pulling the window too far into the opening and putting the action of the latch mechanism in a bind. _________________ Never argue with an Idiot. They'll only bring you down to their level and beat you with experience. |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1696 Location: Eerie PA
Posted: Sun Aug 10, 2025 6:43 am Post subject: Re: Another "unable to close long spoon latch" thread |
I hope I’m not high jacking this thread with this question but it might be relevant.
Is the spacing between the window mounting point and the body mounting point the same on long and short spoon latches? I’ve seen late buses with long spoon and wondered about that. Can you close them without problems. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
Another 65 hardtop
1973 standard bug
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion |
Stocknazi Samba Member
Posted: Sun Aug 10, 2025 8:04 am Post subject: Re: Another "unable to close long spoon latch" thread |
I would try it with the body window ledge seal installed. Without the seal, you are changing the geometry the latch is designed to operate within. The latch is trying to swing open, but the pop-out frame is pulling too far in, if that makes sense.
Did you try any of the other long spoons on that particular pop-out frame? _________________ WANTED:
Thomas Jefferson |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19844 Location: Land of Whine and Phonies
Posted: Mon Aug 11, 2025 11:32 am Post subject: Re: Another "unable to close long spoon latch" thread |
I seem to remember messing around with the latch to frame screws on my Standard to get them to work right. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
thom Samba Member
Posted: Wed Aug 13, 2025 3:51 pm Post subject: Re: Another "unable to close long spoon latch" thread |
I spent some more time playing with it - with the seal installed - to no avail. I could find no point in the adjustment that would get it to work. The one thing I didn't try was doubling-up the spacers.
The 'medium' spoon latches work without any issues whatsoever.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
