Jack Frisch Samba Member
Joined: August 12, 2003 Posts: 768 Location: Northhampton, MA
Posted: Thu Apr 12, 2012 11:59 pm Post subject: Long Spoon Popout Window Latch Questions.. |
Installed a long spoon latch on my 67 buses rear cargo door's pop out window tonight in order to get the windows to pop out more., and when closed and I go to open the door, the latch drags across the surface of the interior when he door opens
I have no spacer under where the latch gets screwed to the interior using three screws, am I suppose to use a spacer in this location, is that why its touching and dragging?
any help appreciated
Jack _________________ 1958 Beetle orig. 6 volt 36 hp engine, body & pan, Black w/red/off white inter., Orig. VW wood roof rack and orig. rear luggage rack.
1967 13 Window Walk-thru Deluxe Bus, stock 1500 engine, Titan Red/Grey, Platinum Mesh interior, orig. & stock
1966 GT350H Shelby Orig. low mileage car |
Joined: April 27, 2002 Posts: 6815 Location: Pentwater, Michigan
Posted: Fri Apr 13, 2012 6:17 pm Post subject: |
The only windows that were supposed to have the spacers were the rearmost which are past the cargo doors. Not sure why you are having the problem. The long spoons were not installed stock on 67's. _________________ Roads Scholar
Member# 2059 |
Posted: Fri Apr 13, 2012 6:52 pm Post subject: |
yes, not stock but everything about how they mount and or work is suppose to similar and or exact to buses that do use and or come with them.
so i am wondering why the issue _________________ 1958 Beetle orig. 6 volt 36 hp engine, body & pan, Black w/red/off white inter., Orig. VW wood roof rack and orig. rear luggage rack.
olliehank47 Samba Member
Posted: Sat Apr 14, 2012 8:05 am Post subject: |
Your problem may be that the long spoon latch is mounted on a low hinge door (67). There is a picture of a long spoon latch mounted on a rear cargo door but it is a high hinge and therefore the outward swing of the door may be just different enough to allow the latch to clear the interior. http://www.thesamba.com/vw/classifieds/detail.php?id=1245616
Just a theory as I have no personal experience. Spacers on the door are not used as the mounting plate for the latch is welded to the outside of the frame rather that inside the channel as for the interior windows. |
