The og 4 wheel drive tooling dstryed in hamburge bombng
Page: 1, 2, 3  Next
deathdealer
deathdealer is offline
PostPosted: Sat Feb 24, 2007 6:41 pm    Post subject: The og 4 wheel drive tooling dstryed in hamburge bombng Reply with quote
Ive been doing some light research into the history of original four wheel drive bugs, there was a proto type four wheel system that worked on the rear motor set up like the 82e( commandur wagon or the swimmen wagon four wheel drive systems, how can one find out how to get that going again for the baja community, theres gotta be plans still in extisence mabe porche still has it, I dont know. how much could the mexicans want for there leftover vw tooling? If its still even around?
GA_Boy
GA_Boy is offline
PostPosted: Sat Feb 24, 2007 7:28 pm    Post subject: Reply with quote
It is my understanding that only one of a very few 4x4 VW's ever manufactured exist today and it is in a German Musuem.
Maybe find someone in Germany and have them do a search.
My German is limited to: Ein Bier bitte. LOL
Marvin
subybaja
subybaja is offline
PostPosted: Sun Feb 25, 2007 12:29 am    Post subject: Reply with quote
Start with this:
Throw in a mini-truck diff and talk Ellobo into modifying his a-arm setup for front stubs...
I don't really see a need to duplicate what they built 50 years ago, except maybe for collectors.
Other than some fab work, the only really difficult thing is the front output from the mainshaft. Just a matter of $.
Insanity: /ɪnˈsænɪti/ -noun: repeatedly voting for the same party and expecting different results.
Vote Libertarian
mattt
mattt is offline
PostPosted: Sun Feb 25, 2007 1:39 am    Post subject: Reply with quote
subybaja wrote:
Start with this:
What transaxle is that? It looks like a heavily modified 091. Its definitely not a Syncro transaxle. I have a Syncro transaxle for a future project build.
subybaja
subybaja is offline
PostPosted: Sun Feb 25, 2007 2:05 am    Post subject: Reply with quote
Bingo. Homebrew 091.
I wonder what Weddle would charge to make an extra-long mainshaft?
Vote Libertarian
deathdealer
PostPosted: Mon Mar 05, 2007 10:08 pm    Post subject: Reply with quote
Yea that's what my feeble research came up with as well, only a couple are left in the mueseum's over there in the swimmen wagons and the one commandure wagon thats in englands mueseum.
Marvin
deathdealer
PostPosted: Mon Mar 05, 2007 10:18 pm    Post subject: the reason behind old 4 wheel Reply with quote
Well the reason I was thinking old 4 wheel drive tooling and orginal stuff is the simplicity of it and the fact that fabrication wouldnt be that big of an issue if you could just bolt it in, for every body with the right year model or make the changes nec for a lot of different years, the years that matter for baja'ing atleast.
bajabugman66
bajabugman66 is offline
PostPosted: Mon Mar 05, 2007 10:25 pm    Post subject: Reply with quote
your forgetting somthing! Syncros were made in 4 wheel drive, take the trans and front diff out of one of those. Keeps it as vw as possible.
Im like a moderator with no real powers or motivation.
66 baja-rotary powered \=O=/
Oh I get it, the robot doesn't have any arms!
deathdealer
PostPosted: Mon Mar 05, 2007 10:25 pm    Post subject: orginal specs would be cooler, and its vw no modifying. Reply with quote
subybaja wrote:
Start with this:
bajabugman66
PostPosted: Mon Mar 05, 2007 10:35 pm    Post subject: Reply with quote
what about it? usually you add text when you post a picture. Im not a mind reader.
subybaja
subybaja is offline
PostPosted: Tue Mar 06, 2007 1:54 am    Post subject: Reply with quote
I'm all for the bolt-in thing, but I seriously doubt that the OG stuff is bolt-in for a bug. There's that little matter of a frame-head in the way. By the time you remove that and do sufficient bracing, you're a long way down the road from bolt-on.
Vote Libertarian
k29349@yahoo
k29349@yahoo is offline
PostPosted: Tue Mar 06, 2007 4:42 pm    Post subject: Reply with quote
If you could put a selectable locking differentail in a bug or bus trans, there would be no need for 4 wheel drive.
cobhc619
cobhc619 is offline
PostPosted: Tue Mar 06, 2007 5:03 pm    Post subject: Reply with quote
isnt that part of the fun of baja bugs, you can usually keep up with the 4x4s and go places where some cant like racing up dunes? power to weight ratio and all the weight over the drive tires. while the 4x4s are putting along bajas blow by them Cool
1970 Baja
1973 Westy
deathdealer
PostPosted: Tue Mar 06, 2007 5:17 pm    Post subject: Four wheel drive Reply with quote
Yea thats sound great but is it a bolt in aplitcation or do you have to start cutting and welding, man Im crippled and doing the heavy stuff is damn near impossible for me ( lifting and such)
kbwakesk8
kbwakesk8 is offline
PostPosted: Tue Mar 06, 2007 5:30 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=202692&highlight=
http://www.volksrods.com/forum/showthread.php?t=13748
These should help.
deathdealer
PostPosted: Tue Mar 06, 2007 5:35 pm    Post subject: Reply with quote
It was bolt in they made the four wheel drive commandure wagon from the bugs they had sitting around and swimmen wagon sthey still got one or to left in the world you just gotta get to the muesum and copy the old specs or porshe might have the plans still in a fileing cab or somting
bajabugman66
PostPosted: Tue Mar 06, 2007 6:01 pm    Post subject: Reply with quote
even with the original tooling its still not a bolt in job. First of all the tunnel has to be cut open to run a drive shaft through. second if the stock beam was kept I would hate to have to have spindles made let alone figure out how to mount the beam back on with the diff in the way, maybe duct tape.
kbwakesk8
PostPosted: Tue Mar 06, 2007 6:13 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...p;start=20
View this link there is pics of a 4wheel drive beam.
bajabugman66
PostPosted: Tue Mar 06, 2007 7:05 pm    Post subject: Reply with quote
ya I know, I started that thread. Even so to find one would not be worth putting it on a bug, save it for a shcwim-i-majjiger. very different from any stock beam.
bajabugman66
PostPosted: Tue Mar 06, 2007 7:07 pm    Post subject: Reply with quote
deathdealer wrote:
PANS ARENT HARD TO GET PRESSED
whats that suppsoed to mean? like the whole pan or what?
Page: 1, 2, 3  Next
