Keys and locks through the years
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Fri Jun 06, 2014 7:17 pm    Post subject: Keys and locks through the years Reply with quote
I've perused the different posts regarding keys and locks for ignitions and door handles. Here is what I have come up with. Maybe someone can fill in the blanks or provide corrections and we can make this a sticky:
Type 1
1946 - December 31 1951:
Ignition = A profile key (Number stamped on ignition cylinder face),
Door handle = Y profile (four tumblers)
1952 - December 31 1953:
Ignition = P profile key (Number stamped on ignition cylinder face),
Door Handle = G profile (five tumblers)
1954 - 1959:
All keys SG profile (six? tumblers)
1960 only:
All keys SE profile
1961 - 1966:
All keys SC, SV, or SU profile
1967 - 1970:
All keys K profile
1971 - 1979:
All keys M profile
Type 2
1950 - December, 1951:
Door handle = E,Z,D,V,F profile (four tumblers)
1952 - February 28, 1953:
Door Handle = E,Z,D,V,F profile (4 tumblers)
March 1, 1954 - August 5, 1963:
All keys the same, E,Z,D,V,or F profile (5+1 tumblers)
1964 - 1966:
All keys T profile
1967 - 1970:
All keys L profile
1971 - 1979:
All keys R profile
fatbeetle
fatbeetle is offline
PostPosted: Sat Jun 07, 2014 2:04 pm    Post subject: Reply with quote
Im a little confused about the 53 type 1 door and ignition keys. Is it all of 53 had the "p" ignition key and "g" door key....or did they switch mid year to the "sg" ignition and door key or a mix of both to use up parts before the switch?
1953 OVAL
Bruce
Bruce is offline
PostPosted: Sat Jun 07, 2014 5:32 pm    Post subject: Re: Keys and locks through the years Reply with quote
Correction in blue
nlorntson wrote:
1946 - December 31 1951: Ignition = A profile key (Number stamped on ignition cylinder face), Door handle = Y profile (four tumblers)
1952 - December 31 1953: Ignition = P profile key (Number stamped on ignition cylinder face), Door Handle = G profile (six tumblers)
Jan 1 1954 - 1959: All keys SG profile
1960 only: All keys SE profile
1961 - 1966: All keys SC, SV, or SU profile
1967 - 1970: All keys K profile
1971 - 1979: All keys M profile
Bruce
Bruce is offline
PostPosted: Sat Jun 07, 2014 5:33 pm    Post subject: Reply with quote
All 53s had a G type door key. SG first appeared on Jan 1 54.
Peter_KG
Peter_KG is offline
PostPosted: Sat Feb 11, 2017 4:37 pm    Post subject: Re: Keys and locks through the years Reply with quote
What about the differences in the lock cilinders; for example should a SV ('61-'66) cilinder fit a 54 ice pick door handle that should have the SG cilinder lock?
Thx!
VW Karmann Ghia '63
VW Kupla Dickholmer '64
VW Bubbla Oval '54
Bruce
Bruce is offline
PostPosted: Sun Feb 12, 2017 1:28 pm    Post subject: Re: Keys and locks through the years Reply with quote
no
Peter_KG
Peter_KG is offline
PostPosted: Sun Feb 12, 2017 1:51 pm    Post subject: Re: Keys and locks through the years Reply with quote
Bruce wrote:
no
Much appreciated, Bruce!
Thx
VW Karmann Ghia '63
VW Bubbla Oval '54
finster
finster is offline
PostPosted: Wed Jan 19, 2022 12:03 pm    Post subject: Re: Keys and locks through the years Reply with quote
nlorntson wrote:
Type 2
should that be march 1953, otherwise what was used from feb 53 to 54...?
PostPosted: Wed Jan 19, 2022 10:01 pm    Post subject: Re: Keys and locks through the years Reply with quote
finster wrote:
nlorntson wrote:
Type 2
I fixed it, here's the correct info for the above
Type 2
1952 - February 28, 1954:
March 1, 1954 - February 28, 1955:
Door handle = E,Z,D,V,F profile (5+1 tumblers)
March 1, 1955 - August 5, 1963:
The handles are the 2-3 exterior handles with locks - Driver's door handle, cargo door handle, and decklid T-handle (Barndoor only)
esde
esde is offline
PostPosted: Thu Jan 27, 2022 5:50 am    Post subject: Re: Keys and locks through the years Reply with quote
I'd like to try to cut keys for my ignition, but I'm missing a few critical pieces of information, maybe someone can help fill in the blanks? I have a P code ignition, which is supposed to use a 90º angle at the notch like the A code. I have the code for the 4 tumblers, 1-2-3-4. What I don't have is how the number corresponds to the depth of the cut. Is a "2" in the code a 2mm deep cut? Is it 2mm from one of the grooves on the key?
Any help is much appreciated, I'm trying to find something I can do in the house while it's 10º out in the barn.
modok wrote:
qwerty
qwerty is offline
PostPosted: Thu Jan 27, 2022 12:27 pm    Post subject: Re: Keys and locks through the years Reply with quote
Here is the spacing from the shoulder and depth info for P key.
esde
esde is offline
PostPosted: Thu Jan 27, 2022 5:26 pm    Post subject: Re: Keys and locks through the years Reply with quote
Excellent information. Thank you! Where is this from?
modok wrote:
qwerty
qwerty is offline
PostPosted: Thu Jan 27, 2022 6:02 pm    Post subject: Re: Keys and locks through the years Reply with quote
This info isn't in the VW locksmithing books or the old Reed code books.
I have access to locksmith information - looks like your depth code 1 2 3 4 starting from the shoulder of the key corresponds to key code P172
I just typed the info into an excel spreadsheet....
Good luck!
esde
esde is offline
PostPosted: Thu Jan 27, 2022 7:38 pm    Post subject: Re: Keys and locks through the years Reply with quote
Good luck!
Thank you so much for sharing. 1-2-3-4 was just an example. But now that I know what the depth of the cuts are, and distances from the shoulder I should be able to decipher the codes I have. The lock I'm working on is probably P59, but may be P69. Wish me luck!
modok wrote:
qwerty
qwerty is offline
PostPosted: Fri Jan 28, 2022 11:44 pm    Post subject: Re: Keys and locks through the years Reply with quote
Sent you a pm with P59/69 codes. Have fun.
