swade41 Samba Member
Joined: April 29, 2007 Posts: 47 Location: buffalo,ny
Posted: Wed May 09, 2007 11:55 am Post subject: Gas / Accelerator pedal floor hinge and parts |
I tried the search and came up with nothing so I'll ask.
My pedal came unatached from the floor at the hinge, it's pretty rusty and can't tell what it was suposed to look like. Is there just a pin/bolt that secures the pedal to the part on the floor ?
How can I fix this ? |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Wed May 09, 2007 10:29 pm Post subject: |
| A pin fits in the hinge. The pin came partly out of the pedal hinge in my 1957 bus, a few times, over the years, and I finally put a little piece of duct tape at each end of the hinge. There is something that holds the pin in the hinge but I forgot what it is. |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Thu May 10, 2007 9:25 am Post subject: |
| There is a piece of spring steel that bears on the recessed area in the center of the hinge pin and keeps it from moving laterally. |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10804 Location: the past
Posted: Thu May 10, 2007 9:30 am Post subject: |
bugboy63 Samba Member
Joined: December 11, 2005 Posts: 523 Location: tennessee
Posted: Thu May 10, 2007 10:00 am Post subject: Re: Gas Pedal Hinge |
| swade41 wrote: |
depends on how picky you are i guess.
mine rusted off before i got the westy,
p.o. just used a hardware store hinge screwed in ... it didn't last.
i did the same thing but bolted it in.
it does the job just fine. |
polo Samba Member
Joined: May 31, 2006 Posts: 418 Location: Pacific Palisades, CA
Posted: Thu May 10, 2007 11:27 am Post subject: |
I need to replace that little spring piece... how goes that? Pop the pin out, remove pedal, stick the spring in, replace pedal, replace pin? _________________ Michael P.
1965 Kombi
1989 Jetta GL (R.I.P.)
2004 New Beetle Convertible GLS 1.8T
| BumbleBuggy wrote: |
| Nothing is cooler than driving a car that brings joy to the world simply by idling at a light. |
Posted: Thu May 10, 2007 8:11 pm Post subject: |
| Thanks for the replies, I'm not to picky just want it to work. That pin must of rusted right off on mine because part of it is still on the pedal. I do have another pedal I was going to use in my t-bucket that hinges to the floor, might take a look at that one too. |
Culito 11010101
Joined: December 07, 2006 Posts: 5882 Location: Columbia Missourah
Posted: Thu May 10, 2007 10:23 pm Post subject: |
Thread hijack alert!
I was wondering if a roller pedal might be more comfortable for a 6' 5" driver...
And if a chrome one might add a few MPH... _________________ © CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
| johnnypan wrote: |
| ...dont pay no attention to Culito,he's a cornhole.. |
Campy Samba Member
Posted: Thu May 10, 2007 10:55 pm Post subject: |
| The pins are narrower in the center and, once, I saw a pin that had rusted clear through in the center portion. |
piercedvw Samba Member
Joined: December 28, 2006 Posts: 109 Location: BC Canada
Posted: Wed Jun 20, 2007 11:16 pm Post subject: |
| I need a good pic of how this setup SHOULD look. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12565 Location: Over 2002 posts deleted!
Posted: Thu Jun 21, 2007 7:34 am Post subject: Re: Gas Pedal Hinge |
| bugboy63 wrote: |
| swade41 wrote: |
The Plump Truck came with a barn door hinge. REALLY a barn door hinge!
 _________________ Some people are so busy being clever they don't have time enough to be wise. |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Thu Jun 21, 2007 8:46 am Post subject: |
That's all the stuff I bought.. want to intall it.. replaces a home-job last owner did.. so have no "picture" to work from. |
Z Samba Member
Posted: Thu Jun 21, 2007 8:51 am Post subject: |
| piercedvw wrote: |
I'll try to get a pic for you today - bet someone beats me to it, though. |
Posted: Fri Jun 22, 2007 8:23 pm Post subject: |
| That picture of the backside of the pedal looks like the l shaped bracket is held in place by the bracket that bolts to the floor and trapped by the pin. |
Posted: Sat Jun 23, 2007 9:02 am Post subject: |
| Got it done.. will try to post pics later. |
biggraham Samba Member
Posted: Tue Jun 26, 2007 3:19 pm Post subject: |
Thanks Z, those links willl be a huge help in the future,
Cheers
 _________________ 67 S0-42 Pop-Top Walkthru |
Posted: Tue Jun 26, 2007 3:52 pm Post subject: |
| The bracket is welded not bolted. |
mynameismud Samba Member
Joined: October 23, 2002 Posts: 5937 Location: Middle of a corn field
Posted: Wed Jun 27, 2007 12:10 pm Post subject: Re: Gas Pedal Hinge |
| pyrOman wrote: |
That's hot..  _________________ Even YOU can prevent FIRES!
Click to view image |
pyrOman Fire Master
Posted: Wed Jun 27, 2007 12:45 pm Post subject: Re: Gas Pedal Hinge |
| mynameismud wrote: |
| pyrOman wrote: |
That's hot..  |
You should see the rest of the truck!  _________________ Some people are so busy being clever they don't have time enough to be wise. |
