honky Samba Member
Joined: August 10, 2006 Posts: 149 Location: Connecticut, USA
Posted: Fri Aug 17, 2007 7:32 pm Post subject: Thing Muffler |
| Will a standard bug muffler fit a Thing. I know they bolt up to the motor ok but will the tail pipes go under the body to the rear ? |
wings_n_fins Samba Member
Joined: May 02, 2006 Posts: 166 Location: Mangilao, Guam USA
Posted: Fri Aug 17, 2007 10:30 pm Post subject: |
Yeppers. _________________ DAVE
'73 Thing
'07 Harley Sportster
'09 Jeep Wrangler Unlimited |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Fri Aug 17, 2007 10:41 pm Post subject: |
That's what I have on mine right now. If I had more spare time and a welder, I would have modified it into a 1974-style muffler. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Posted: Sat Aug 18, 2007 8:07 am Post subject: |
It's hideous.
'73 Thing
honky Samba Member
Posted: Sun Aug 19, 2007 5:14 am Post subject: muffle it |
| Every pictures tells a story. Thanks for the replies. Looks ugly but it works. Especially when the correct replacement thing muffler is so expensive |
Big Luni Samba Member
Joined: December 29, 2003 Posts: 427 Location: Hartford, CT
Posted: Mon Aug 20, 2007 5:36 am Post subject: |
Not only does it fit -- by the late 70s/early 80s, dealers were replacing Thing mufflers with bug mufflers. Personally, I don't think they look right at all. If you're on a budget and can't afford one of the Thing-specific mufflers on ebay (which are way cheaper than Thing Shop, but still in the $200 range), I'd suggest getting a cheap Monza muffler and modifying it like Emerson Biggins did:
I currently have an unmodified Monza muffler and a CIP1 '74 muffler in the box for when the 10-yr-old Monza wears out -- but the Monza has worked better and lasted longer than the S&S merged header system. If I could do it over now, I'd probably just buy a new Monza instead and do the mod, rather than ordering the '74 system from CIP1.
Either way, I'd do a search. There are several good threads on exhaust options, and I'm sure you'll find a better option than a stock Bug muffler.[/url] _________________ I'm All About My Fetti! |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Mon Aug 20, 2007 6:07 am Post subject: Re: muffle it |
| honky wrote: |
I see this statement come up all the time when it comes to stock exhaust setups. I always ask folks to judge the price by it's length of life. How long did that original stock exhaust last? In most cases, it was good for 10 to 15 years (even more). I have a 71 Thing (military) and an 84 Vanagon Westy. Both have a stock exhaust. I recently replaced the Vanagon exhaust with a new stock system. Yes, it cost a whole bunch more than other systems out there, but it fit, and I know this one will give me another 20 plus years of service, provided the Vanagon or myself last that long.
You get what you pay for. Pay more for the stock exhaust, but it will fit, and last for another 10 to 20 years. Buy an aftermarket system, and you'll get maybe 5 years. Some you even have to remove their paint and redo it to keep it from burning off or rusting the first time you start the engine with it. _________________ Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181 |
Posted: Mon Aug 20, 2007 10:55 am Post subject: Re: muffle it |
| bucko wrote: |
| Some you even have to remove their paint and redo it to keep it from burning off or rusting the first time you start the engine with it. |
Agreed -- That's what happened with my S&S. It lasted about 5 years. Still, I'm not sure if Honky has a '73 or '74, but if the choice is between dropping $1000 or so for a true NOS Thing exhaust (if you can find one)or rocking a bug exhaust with pea shooters, I'd choose neither one, and drop $300 for a nice, ceramic coated aftermarket exhaust that should sound good and last a long time. _________________ I'm All About My Fetti! |
Tim10 Samba Member
Joined: April 06, 2004 Posts: 1433 Location: Minneapolis
Posted: Mon Aug 20, 2007 7:35 pm Post subject: |
go for the dual muffler/header system and do not look back.. _________________ Dub Infested- PART WI$H LI$T-CLICK |
lowsquare Samba Member
Joined: May 29, 2004 Posts: 287 Location: Queen Creek, AZ
Posted: Fri Aug 24, 2007 9:21 am Post subject: |
Hey Emerson when you cut off the 4 tips on your monza muffler...did you have the tips custom fabricated... or ... is that a 45 and 90 from Pep Boys or the like? I'm going to do the same, but didn't know if I needed to take it to a muffler shop after I cut or if I could just pick up the necessary preshaped pieces and do it myself...  _________________ PRAISE THE LOWERED.
1973 THING |
spam38 Samba Member
Posted: Thu Sep 13, 2007 5:39 pm Post subject: |
| iam running a single glasspack extractor on my 73 thing from cip1 |
7thing3 Samba Member
Joined: April 05, 2003 Posts: 473 Location: Cleveland, OH
Posted: Thu Sep 13, 2007 5:57 pm Post subject: |
Personally I think one of the coolest, most unique things about a Thing is the exhaust thru the bumper. What other vehicle of any type can match that? I think it is a must and I would never go without one. I have had the Thing shop divided exhaust on mine for 4 years, 5,000 miles. If I had to replace it tomorrow it would be something thru the bumper.
Now I suppose if I just had some rat mobile or had a baja'ed up Thing with a different bumper I would consider otherwise. But for a decent stock or modified stock it would only be thru bumper for me.
Just my $.02 worth. |
bmwloco Samba Member
Joined: March 19, 2006 Posts: 1093 Location: Asheville NC
Posted: Thu Sep 13, 2007 6:12 pm Post subject: |
I keep my vehicles stock. My Mercedes, my BMW motorcycles and my VWs.
Very, very rarely is it a good idea to do otherwise. Compromise one system, it effects something else.
Oh, seats are often a change, but I keep the originals (if possible).
When you start using something other than stock, you drop the value, often get less performance, and sometime create other problems.
But hey, it's your Thing. Do what you want to do. |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Thu Sep 13, 2007 6:38 pm Post subject: |
| bmwloco wrote: |
| When you start using something other than stock, you drop the value, often get less performance, and sometime create other problems. |
Strongly disagree, unless you add the modifier "without thinking it through". So, "Without thinking it through, if you start using something other than stock..." - that's a bold statement that I can agree with.
Or do you think the 2270 Type 4 engine I've put in my Thing will give me less performance than the stock 1600? Care to wager?
I paid $1000 for my Thing. Do you think the combination of all the upgrades I've done - high performance engine, transmission and supports to match the engine, radically improved exhaust, aftermarket upholstery, very well done tiger-striped paint, centerline wheels, disk brakes, roll bar - all this has reduced the price of my car below $1000?
I suppose I can't argue that it has caused other problems. I do have to engage my brain when finding a car part and I anticipate that it will be more difficult to avoid speeding tickets in the future.  |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1697 Location: Nebraska
Posted: Thu Sep 13, 2007 8:21 pm Post subject: |
| lowsquare wrote: |
Hey Emerson when you cut off the 4 tips on your monza muffler...did you have the tips custom fabricated... or ... is that a 45 and 90 from Pep Boys or the like? I'm going to do the same, but didn't know if I needed to take it to a muffler shop after I cut or if I could just pick up the necessary preshaped pieces and do it myself...  |
Just a 45 and a 90 from the auto parts store but I had to cut and flare a little bit. |
bucko Samba Member
Posted: Fri Sep 14, 2007 4:35 am Post subject: Re: muffle it |
| honky wrote: |
Yep, the correct muffler is expensive, but one has to figure how long the original muffler lasted. 30 years yes?
You have an original VW in the Thing. Why would you want to but a Beetle muffler on it and ruin its originality? In the case of Ian Epperson, he went the modified route, but he does not have a stock Beetle muffler on his Thing. So originality and value was not ruined in his case. Placing a stock Beetle exhaust will take away from your Thing's "originality" factor, and since you did not indicate that you are going the "modified" or "performance" route, you are getting the suggestions of leaving it stock. Besides, a stock Beetle exhaust does nothing for perfomance.
Save up, and buy a correct fitting muffler. There are other types that exit through the bumpers of the Thing that I'd go for rather than put a Beetle muffler on it. _________________ Current VW drives: 1984 Westfalia
Posted: Fri Sep 14, 2007 7:07 am Post subject: |
Ian,
Sorry to offend. It wasn't my intent. Do what you want with your Thing.
For me, though, Stock rules. I've been going to Hershey since I was a kid. Sure, there's a place for hot rods, hacks, mods, and other stuff, but when you want top dollar for your vehicle, stock and OEM is the way to go.
Again, if it makes you happy, do what blows up your skirt. It's a free country (allegedly). |
dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
Posted: Sat Sep 15, 2007 3:12 am Post subject: |
I used a stock beetle muffler. Blocked off the original outlets and added my own.
The key to modifying exhaust without affecting performance is to keep back pressure below 2psi at 2000 rpm. Easy to measure using a low pressure dial type gauge. _________________ Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone |
Posted: Sat Sep 15, 2007 7:23 am Post subject: |
| Ian Epperson wrote: |
| bmwloco wrote: |
I think the basic point is that in the case of most vehicles if you had two 30 year cars both with 50,000 miles the one that was stock, OEM, unmolested, etc. would be worth more than the one that modified, chached up, etc.
With 30 year old VWs that aren't worth anything anyways there is more give and take on modifications. In my case I had an old rust bucket Thing that I "improved" by adding a bigger engine, bug tranny, better seats, disc brakes, XM radio, bikini top, etc. I enjoy driving it but never expect to get back out what I put in. |
kubelmann Samba Member
Posted: Sat Sep 15, 2007 7:32 am Post subject: |
| I have a original factory 73 Thing muffler available |
