agreendaya Samba Member
Joined: November 16, 2006 Posts: 1311 Location: Winthrop, MA USA
Posted: Mon Aug 27, 2007 4:07 pm Post subject: Very little heat...and it's stinky |
I just replaced the hose from the fan to the mysterious hole on the left (driver) side of the engine compartment, and I'm still getting very little heat in my '74 (2.0L FI, presumably from a later bus). I get some heat when the engine revs high, but that's it. Also, it only comes from the defrost, no the foot vents, no matter what I do. I checked the hoses under the bus, made a few repairs, but still no luck.
Does anyone have pics/diagrams of where the wires go from the levers on the dash? I think then I could figure it out...
Any ideas would also be appreciated.
Thanks! |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Mon Aug 27, 2007 4:42 pm Post subject: stinky heat |
Ryan, Have you checked the black plastic fuse holder in the engine compartment? it's hanging near the blower motor.see if there is a good fuse in it,Start the engine and pull down on the red levers at the dash.the wiring diagram here shows the current track's as track 4 and track 5. the brn/wht wire at the lever completes the circuit. _________________ V.W.owner since 1967 |
gr8fuldad Samba Member
Posted: Mon Aug 27, 2007 5:03 pm Post subject: |
I had the same problem last fall. I went underneath the bus and opened all the heater ducts and found mounds and mounds of old mouse nests from over the years. You may want to check at the spot where the tubes branch out. There is a flap to direct the air flow. Mine was stuck closed. I oiled it up and I now get plenty of heat. _________________ "SLOW AND STEADY WINS THE RACE" |
Randy in Maine Samba Member
Posted: Mon Aug 27, 2007 5:24 pm Post subject: |
Compressed air is your friend. Start at the front and remove those black heater accordian hoses and blow it all out to start with. |
Posted: Mon Aug 27, 2007 6:03 pm Post subject: |
The fan does work, I can see it spinning when I turn it and the car on. All this sounds good, guess I just need to find someone with an air compressor.
gr8fuldad, I think that may be my problem. Should the wires from the levers in the dash go to that branch point? There's a wire there, but when I had my girlfriend move the levers, the wire under the car didn't go anywhere... |
mnskmobi Samba Member
Joined: February 28, 2005 Posts: 536 Location: Melbourne, Australia
Posted: Mon Aug 27, 2007 7:18 pm Post subject: Re: Very little heat...and it's stinky |
agreendaya wrote: |
Thanks! |
The most critical cables for getting heat to the front are those connected to the flapper boxes on either side of the bus just forward of the engine (get under and work forward from the heat exchangers and you will soon find them). Are these working on your bus? They often sieze up over time or get out of adjustment so that the flaps do not fully open. |
Posted: Mon Aug 27, 2007 10:46 pm Post subject: |
^^^ I think I know what he's talking about, but does anyone have pics? I was under there and don't recall noticing any cables there, but perhaps I was looking at the wrong thing...
Thanks! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16800 Location: State College, PA
Posted: Tue Aug 28, 2007 7:19 am Post subject: |
The title of the thread sounds like my ex-wife............ _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1930 Location: N.W. Georgia
Posted: Tue Aug 28, 2007 8:57 am Post subject: |
.. the diverter for the foot vents/defroster is on the vertical pipe right behind the shifter, body colored metal, between the floor and the dash. Flip it up for heat down low, down for heat up at the windshield. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
Herbst '71 Samba Member
Joined: April 14, 2004 Posts: 245 Location: Augusta, GA
Posted: Wed Aug 29, 2007 4:27 am Post subject: |
I agree with Randy. First make sure you have all the junk out of the tubes. It's simple and it doesn't take long. _________________ Rik
'71 Deluxe/1600 DP
"Fortunately my mistakes are serving as a warning for others." |
Posted: Wed Aug 29, 2007 10:35 am Post subject: |
Soon as I get a little more time, I'll be able to do all this stuff. It's looking like that flap is messed up. How about the second part though, what little heat I do get stinks like engine compartment. Personally, I don't mind, but my girlfriend complains.
Anything I can do?
(Besides get a new girlfriend) |
Posted: Wed Aug 29, 2007 1:52 pm Post subject: |
Also.....
The next time you have the engine out, remov ethe heater boxes and throughly clean them out with an engine degreaser and triple rinse them.
I would then hook up a source of heated air (ie a blow dryer) and dry them out really well. |
Posted: Wed Aug 29, 2007 2:55 pm Post subject: |
Randy in Maine wrote: |
Also.....
Cause I take my engine out all the time, just for fun, you know...
sounds like good advice, though. |
Posted: Wed Aug 29, 2007 7:48 pm Post subject: |
agreendaya wrote: |
Thanks! |
Maybe this will help (photo courtesy Ratwell). The cables are in metal tubes and attach to the flapper box at the top. Like I said, if the cables are not pulling the flaps in the flapper boxes all the way open you will not get much heat.
