THall Samba Member
Joined: August 25, 2010 Posts: 337 Location: Verona, WI
Posted: Sat Jan 11, 2025 2:51 pm Post subject: Trans Drive Flange Removal |
The Bentley manual describes removing the flange by using pry bars, but I've seen threads on here that say using a puller tool is necessary.
I suspect either would work, but I'm hoping you guys could provide some insight on what works well, tips, tricks, etc.
The transmission in my case is an 091.
Thanks _________________ '78 Westy - 2.0 FI |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1577 Location: New Brunswick,Canada
Globedog12 Samba Member
Joined: April 11, 2024 Posts: 196 Location: Atlanta, GA
Posted: Sat Jan 11, 2025 5:29 pm Post subject: Re: Trans Drive Flange Removal |
There was a pretty good pictorial on German supply. I think it shows using a puller. When I did mine I was pretty lucky and flanges came off pretty easily with a couple screwdrivers prying behind. Definitely get the right tool for removing the retaining clips. For me anyway that was the hardest part of the job. _________________ 1976 VW Type 2 Original fuel injection |
timvw7476 Samba Member
Posted: Sun Jan 12, 2025 12:29 am Post subject: Re: Trans Drive Flange Removal |
The flanges on a 091 will not be tight, the circlip is the thing you need to treat nicely so you do not deform it & prevent it from going on back nice n' tight.
(if you DO deform it, there's a chance it pops off under the blue cap, and then you have an axle spinning free. NO MOVEMENT.) guess how I know ?) : l
The later transaxles do require extra force to seat & release the flanges, the FWD set ups. A Type I engine case oil pump puller C brace serves as a nice 'puller' to get the flange drawn down far enough to use install/remove without drama, but those are all slightly newer FWD transaxles.
And you have to find just the right bolt length/washer stack to do it, other than that C- portion from the Type I oil pump tool. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13481 Location: West Coast, USA
Posted: Sun Jan 12, 2025 10:48 am Post subject: Re: Trans Drive Flange Removal |
I use a 6" piece of flat steel and a long bolt.
Lay it directly across the flange/CV and drill two holes so you can slip two CV bolts through it easily and thread them into the flange. Drill a third hole between the two, maybe a little larger. Then you can use CV bolts to hold the "tool" in place, then insert the long bolt (head to the differential) with a nut threaded on below the tool as well. Loosening the nut towards the tool will push the bolt down and pull the flange off easily. You may need a second wrench to keep the bolt head from turning.
The axle has M8 or M10 threads in it, which you can use in this setup as well, I just never remember to have the correct bolt on hand for that…
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Posted: Sun Jan 12, 2025 11:15 am Post subject: Re: Trans Drive Flange Removal |
I wonder could you just thread a couple of bolts into the flange and put a metal block under the flange so the bolts bottom on the metal,as the bolts get turned in it will want to push the flange out,you may have to take care not to damage the cover. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy sold dec 2024
1974 parts bus
Posted: Sun Jan 12, 2025 11:24 am Post subject: Re: Trans Drive Flange Removal |
lil-jinx wrote: |
I wonder could you just thread a couple of bolts into the flange and put a metal block under the flange so the bolts bottom on the metal has the bolts get turned in it will want to push the flange out,you may have to take care not to damage the cover. |
That’s a fine way to do it as well, similar to the T4 crank fan hub removal method. Use three bolts instead of two and the chances of warping the flange are near zero. Last time I checked, Weddle sold new flanges just in case.
www.airschooled.com
germansupplyscott Samba Member
Posted: Sun Jan 12, 2025 3:13 pm Post subject: Re: Trans Drive Flange Removal |
Globedog12 wrote: |
There was a pretty good pictorial on German supply. I think it shows using a puller. When I did mine I was pretty lucky and flanges came off pretty easily with a couple screwdrivers prying behind. Definitely get the right tool for removing the retaining clips. For me anyway that was the hardest part of the job. |
https://germansupply.com/Scotts_Folder/Tech_Articl...0Seal.html
You may not need a puller to remove the flange. The puller is needed for sure to compress the wavy ring to get the flange reinstalled after the seals are replaced.
This is an 002 but the 091 is similar. _________________ SL |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42533 Location: at the beach
Posted: Sun Jan 12, 2025 3:23 pm Post subject: Re: Trans Drive Flange Removal |
germansupplyscott wrote: |
Globedog12 wrote: |
This is an 002 but the 091 is similar. |
agree. All the ones I have pulled came off easily but it is harder putting it on. Unless it is leaking there is little reason to remove it. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
THall Samba Member
Posted: Mon Jan 13, 2025 4:36 am Post subject: Re: Trans Drive Flange Removal |
Thanks all, appreciate it. _________________ '78 Westy - 2.0 FI |
