Sense check - Fused supplies
Who.Me?
Who.Me? is offline
PostPosted: Mon Apr 11, 2016 12:17 pm    Post subject: Sense check - Fused supplies Reply with quote
Hi
I'm fitting a modern radio and want to make sure that both my permanent and switched-live feeds are protected by fuses, so can someone sense-check that I've got this right please...
I have the early six-fuse fusebox.
Looking at the box, the furthest right fuse is permanent live, with the input from the bottom, so the upper connections are the outgoing feeds that are protected by the fuse?
The fuse second from right (stop lights, indicators) is switched, with the input at the top, so the outgoing feeds, protected by that fuse are at the bottom? This is where I've picked up my switched live.
I've checked the wiring diagrams and I think I've got that right, but it seems counter-intuitive to have the inputs and outputs on different sides of the fusebox depending on the circuit, so can someone check my logic please?
The radio works and it has its own integral fuse, but I want to make sure that my feeds are protected by the appropriate fuses at the fuse board.
Thanks
Andy
Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786
EDragnDean
EDragnDean is offline
PostPosted: Mon Apr 11, 2016 5:45 pm    Post subject: Re: Sense check - Fused supplies Reply with quote
Yes. One side is constant, the other fused.
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
