Jim Bear Samba Member
Joined: March 25, 2006 Posts: 670 Location: Watkinsville, GA
Posted: Mon Apr 13, 2015 8:10 am Post subject: New fuel tank woes: gauge bolt holes and now outlet threads |
I bought this tank yesterday. When I got ready to install it this morning I noticed the holes for the gauge sender unit on the tank itself are off from piece with the threaded holes welded to the inside of the tank. Take it back and throw the project off course? Dremal the overhang? Just try it as is --thinking the bolts will do the trick? Thanks in advance... _________________ "You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING
Posted: Mon Apr 13, 2015 8:12 am Post subject: sorry |
Sorry if that picture is crazy huge. I did it on my phone and do not know how to adjust the picture size. _________________ "You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Mon Apr 13, 2015 9:02 am Post subject: |
I would try to open the holes a little. or get an original tank. more aftermarket trash parts  _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
| tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
| sb001 wrote: |
maybe he just snapped cause his car sucked  |
Posted: Mon Apr 13, 2015 8:00 pm Post subject: Working on it.. |
Holes tapped by the dealer. Trying it tomorrow. Should work _________________ "You're either on the bus, or you're off the bus." ~kk
hitest Samba Member
Joined: September 30, 2008 Posts: 10327 Location: Prime Meridian, ID
Posted: Mon Apr 13, 2015 8:33 pm Post subject: |
Have you tried threading the bolts into it? The reason I ask is it looks like the holes were stamped, but the nuts were welding in using a jig that holds them in the correct (non radial) position. Have you rotated the sending unit to all five positions to see if it aligns?
If you've done all that and it still is screwy, I'd call Mid America Motorworks and ask them where they come from so we can all avoid them. That is where you got it, right? _________________
| EverettB wrote: |
FU#5 |
Posted: Wed Apr 15, 2015 5:09 am Post subject: well |
The tank is from my local dealer. I have no idea where he got it. I took it back to him and he simply tapped out the sender bolt holes, easy.
New problem: the threads on the outlet pipe of the tank do not seem to match up with the nut that holds the outlet tube and sock in place; when I try to put the nut on it does not groove with the threads and wants to strip them. Wrong kit? Cheap Chinese tank? Get a die and chase threads on tank? _________________ "You're either on the bus, or you're off the bus." ~kk
