timing - tach hookup
fungi
fungi is offline
PostPosted: Tue Oct 22, 2002 6:27 pm    Post subject: timing - tach hookup Reply with quote
I have a tach/dwellmeter. I have been hooking it up to my coil (-) form dist and a ground. I get 900 rpm on an 8cyl scale isn't it supposed to be 450 on an *cyl scale. any way that would mean my car is ideling at 1800 rpm and i'm sure it's not. SO am I hooking my tach up wrong.
Thanks Paul...
TimGud
TimGud is offline
PostPosted: Wed Oct 23, 2002 7:07 am    Post subject: timing - tach hookup Reply with quote
On the dwell meter I have,the red goes to a positive, the black wire goes to ground, and the green lead goes to the - side of the coil.Good luck
[email protected]
firsttraxxx@hotmail.com is offline
PostPosted: Mon Oct 28, 2002 4:38 pm    Post subject: timing - tach hookup Reply with quote
I get the same results, just added a VDO to my '76. While driving the rev needle seems to doubled and jumpy after 4k, shift levels at 6k, I know its not at redline, based on an idle of around 1200 rpm. Does anyone know what the typical redline level is (for the needle stop)?
Amskeptic
Amskeptic is offline
PostPosted: Sun Nov 03, 2002 1:01 am    Post subject: timing - tach hookup Reply with quote
Your ear should be your initial guide.
Normal engine idle is 900 warm
( 450 v-8 scale). Rev limiter on distributor rotor is calibrated for 5,400.
The 76 should be at 3,200 at around 55.
Misbehavior of your tach or dwell meter is usually a wiring problem or extremely lousy points/condensor/distributor bushings, but you would have a lousy-running car, too.
Colin
