Rowroy Samba Member
Joined: November 07, 2006 Posts: 1012 Location: The ass of nowhere
Posted: Tue Feb 05, 2008 5:57 am Post subject: |
Hophead wrote: |
What does the oil look like? I would dump it, pull the plate and take a look for sparklies.Cut open the oil filter and look at the pleats. |
That's the plan for this weekend. I will also check the condition of the pressure control valve and valve seat. I also may add a sump as well.
Hophead wrote: |
Depending on location the sensors can be wrong or off or slow to respond. |
I'm using an Auto Meter gauge w/ the electric sender in the stock idiot light port. _________________ Suicide is man's way of telling God, "You can't fire me; I quit!" - Bill Maher |
Hophead Samba Member
Joined: January 03, 2005 Posts: 940 Location: Chico,Ca
Posted: Tue Feb 05, 2008 12:40 am Post subject: |
Yep, starvation... had the same kind of issues with a 1776 about twenty years ago.... too big of an oil pump and no sump. I would throw a 1.5 quart sump on it first and see if that helps before i just tore into it. Perhaps the oil plunger work could be done easily as well. but I would not pull it without trying that first.... Depending on location the sensors can be wrong or off or slow to respond.
What does the oil look like? I would dump it, pull the plate and take a look for sparklies.Cut open the oil filter and look at the pleats. If all is clean then the bearings are probably not bad.
I wouldn't waste my time trying to chase down a pressure problem before I knew I had a consistant supply. _________________ 70' Beetle Pan off Resto
2110cc
82 X 90.5
P&P 043 40x35.5
9.6-1 comp
FK-8
48 IDA |
Jimmy111 Samba Member
Joined: October 05, 2006 Posts: 2643 Location: Wyoming
Posted: Mon Feb 04, 2008 7:46 pm Post subject: |
Still. Starvation does not address continous low oil pressure. I have had many 2180- 2332's without deep sumps and yes on very hard cornering the oil pressure would dip But most motors lasted around 80,000 miles before starting to show low oil indications.
I had a Baja that was rolled, mashed, crashed, sunk and filled with water, overheated, broke oil cooler lines and generally bashed around at any oppertunity ( i mellowed out since then) and it still lasted 40,000 miles before oil pressure problems. So problems at 6500 miles?? |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Mon Feb 04, 2008 7:19 pm Post subject: |
koolkarmakombi wrote: |
Im with starvation.
Had the same symptoms on a nice new motor in a Kombi. |
It didn't tip over?
_________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
koolkarmakombi Samba Member
Posted: Mon Feb 04, 2008 4:03 pm Post subject: |
Im with starvation.
Long corners and throttle = red light on.
Topped up oil to very full and didn't do it.
Fixed with a deep sump and slower cornering. |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Mon Feb 04, 2008 2:31 pm Post subject: |
Jimmy, i'm with ya here.... if it were mine, it would be in for a tear down just to see...but i don't drive my ACVW's very often so taking one out of service is no big deal... _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Posted: Mon Feb 04, 2008 10:02 am Post subject: |
If he had a 21mm or even a 26mm pump I would agree with you.
But his pump is pumping 1/3 more oil then necessary to maintain the 10psi per 1000 RPM. Contrary to popular belief the oil control valve is OPEN all the time the motor is running until oil pressures drop due to wear. The oil control valve is there to maintain a MINIMUM oil pressure. Even when the oil control piston is open 100% of the time he should be able to keep his pressure high. Im sure he has not modified the relief hole for the piston to increase capacity. it is only 4 mm in diameter and can only handle the volumn of the 26mm pump. so by adding a 30mm pump you will always get a corresponding increase in pressure.
He only has 6500 miles on it. It is possible however unlikely that the bearings are That worn out already.
bugninva wrote: |
i don't see a huge problem with his hot pressures...he's running 10w30 which will flow quite nicely when hot, and that means it can be being bled off at the control piston, or he may have some loose tollerances...the 42psi magic number on the stock spring is assuming the spring isn't softer than normal from years of use... if the oil starvation happened at higher rpm's there always a chance bearings were damaged and this could cause lower pressure...I still say the reason was starvation, not to say that that didn't cause other problems.. |
Rowroy Samba Member
Posted: Mon Feb 04, 2008 6:07 am Post subject: |
bugninva wrote: |
I was wondering about this myself. God only knows how many times the pressure dropped to below 20 psi while the engine was spinning at 4500 RPM's during hard acceleration.
I wish I would have installed a pressure gauge sooner.
Quote: |
Starvation through acceleration and cornering means you need to add a sump. |
I thought of this as well, but am afraid that it would fix the problem by masking the real issue. However, if the sump truly is being "pumped dry", then it sounds like I have no other option. _________________ Suicide is man's way of telling God, "You can't fire me; I quit!" - Bill Maher |
74 Thing Samba Member
Posted: Sun Feb 03, 2008 11:34 pm Post subject: |
If you need to machine your pressure control and pressure relief valve bores you can rent the tool from aircooled.net - at least they used to.
Good pressure is 10lbs for each 1k rpms |
Posted: Sun Feb 03, 2008 10:44 pm Post subject: |
i don't see a huge problem with his hot pressures...he's running 10w30 which will flow quite nicely when hot, and that means it can be being bled off at the control piston, or he may have some loose tollerances...the 42psi magic number on the stock spring is assuming the spring isn't softer than normal from years of use... if the oil starvation happened at higher rpm's there always a chance bearings were damaged and this could cause lower pressure...I still say the reason was starvation, not to say that that didn't cause other problems.. _________________
Posted: Sun Feb 03, 2008 10:04 pm Post subject: |
Yes but that does not explain the low oil pressure on the straights and at standstill
Where is the oil then?
Should be in the case. So the 38psi indicates another problem. |
Posted: Sun Feb 03, 2008 9:31 pm Post subject: |
miniman82 wrote: |
bugninva wrote: |
Rowroy wrote: |
My engine speed was steady @ about 2800 RPM's all three times. Also, I noticed that all three times the light came on I was going through a sweeping right-hand turn.
I'm with mini, it sounds like oil starvation....a 30mm pump, no add on sump, and a right sweeper are a very good recipe for pumping the sump dry... |
It's probably all in his left side valve cover by the time the light flickers. |
exactly! _________________
Posted: Sun Feb 03, 2008 9:29 pm Post subject: |
bugninva wrote: |
Rowroy wrote: |
It's probably all in his left side valve cover by the time the light flickers. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Posted: Sun Feb 03, 2008 9:22 pm Post subject: |
Rowroy wrote: |
I'm with mini, it sounds like oil starvation....a 30mm pump, no add on sump, and a right sweeper are a very good recipe for pumping the sump dry... _________________
Posted: Sun Feb 03, 2008 8:45 pm Post subject: |
The 30mm pump does pump more than the valve can regulate properly. But that just resulte in excessive pressures. Happens all the time. The 42 PSI is if everything is stock. People change springs, pistons, machine the piston seats and other Bright ideas and it all effects the pressure that the valve will open and close at. The 30mm pump pumps a LOT of oil. It is backed by a 40-200hp motor so pressure is not a problem. If the pressure isnt vented somewhere something will break. Usually the hoses or filter or oilcooler but cases crack too.
The whole Idea of the pressure control valve is to lenghten the service life of the motor by being able to supply more oil as the motor wears out. as the motor wears more oil will flow around the bearings and less oil will flow thru the controll valve untill no more oil flows thur the control valve and the oil pressure starts to drop.
The control valve is not a pressure regulator but more of a waste gate. |
Rowroy Samba Member
Posted: Sun Feb 03, 2008 8:36 pm Post subject: |
Okay, I just went back and read Tom Wilson's write up on the pressure control and pressure relief valves and it got me thinking . . . .
According to him, the oil pressure control valve is supposed to open @ 42 psi. That leads to another set of questions:
1. Should a 30 mm pump be able to pump more than the pressure control valve is capable of flowing? If not, then I would think that the oil pressure would never get above 42 psi.
2. Are the "in and out" pump covers restrictive enough to limit enough oil flow that it could never generate more than 42 psi even with a 30 mm pump? _________________ Suicide is man's way of telling God, "You can't fire me; I quit!" - Bill Maher |
Rowroy Samba Member
Posted: Sun Feb 03, 2008 8:16 pm Post subject: |
miniman82 wrote: |
Rowroy wrote: |
miniman82 wrote: |
Sounds like starvation, but 20 PSI should not be low enough to cause the light to flicker...have you reaplced the idiot light sender? They are normally notorious for turning the light on at very low pressures. |
The light doesn't come on @ 20 psi. It only came on on three separate occasions, prompting me to install the pressure gauge. |
I see, and when the light came on, what was your RPM doing? Does your RPM drop off around turns (float bowl sloshing), or do you notice that the light comes on any other times? Do you have a center mount carb, or duals?
My Corvair almost dies sometimes going around a corner, and the pressure light definitely comes on at those times. |
I have dual carbs.
_______________________________________________________
I'm going to start by taking Jimmy111's advice and inspect the pump cover and pressure control valve.
Is it possible that a fatigued pressure control spring could cause this problem? _________________ Suicide is man's way of telling God, "You can't fire me; I quit!" - Bill Maher |
Posted: Sun Feb 03, 2008 6:19 pm Post subject: |
Rowroy wrote: |
miniman82 wrote: |
My Corvair almost dies sometimes going around a corner, and the pressure light definitely comes on at those times. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Posted: Sun Feb 03, 2008 5:48 pm Post subject: |
The valve nearest the flywheel. The other valve is just a oil cooler bypass. But the piston should fit well in there too and not leak. |
Rowroy Samba Member
Posted: Sun Feb 03, 2008 4:49 pm Post subject: |
Jimmy111 wrote: |
I got to disagree with you Randy. The step is there for a reason. The step should be reamed to exactly 15.95mm The hole is 16mm and the piston should be 15.93mm If you ream the hole to 5/8" you will increaase the oil that will flow thru the valve as much as 1 gallon per minute.
A 21mm pump will flow all the oil that the motor needs. When the pressure control valve was installed they increased the pump to 26mm to compensate for the oil that was flowing thru the comtrol valve. With a 30mm pump there should be about 30% more oil than the motor really needs.
The motor should build about 10psi per 1000 rpm .If 38psi is the max expecially with a 30mm pump there is a big leak somewhere.
If the piston does not fit, clean it with some sand paper or replace it.
Warm up the motor then remove the cap from the oil control valve. let the oil drain out. put the cap back on and starrt the motor. let it run for a little while and then shut it off. Open the cap. there shoiuld be no oil or just a little oil there. If you have a lot the piston is leaking.
If you suspect the valve is not holding pressure, get a used piston and weld it to a piece of round stock. Use some lapping compound and lap the valve seat just as you would do your cylinder valves.
Usually if you have that big of a leak, it is leaking past the oil pump into the case or a lifter or 2 ground away their journals.
Check the in and out oil pump cover for wear first.
Then check the oil valves.
Next is motor disassembly. |
Is that the front or rear valve? . . . I can never remember. _________________ Suicide is man's way of telling God, "You can't fire me; I quit!" - Bill Maher |
