Fuel gauge sending unit
wanta23
wanta23 is offline
PostPosted: Wed Feb 27, 2008 10:17 am    Post subject: Fuel gauge sending unit Reply with quote
How do I know if my sending unit is good? My gauge only reads 3/4 when it's full and goes to empty with about a half a tank. My gauge needle also bounces around quite a bit. I've already checked the gauge ground and it's OK
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed Feb 27, 2008 10:55 am    Post subject: Reply with quote
It's prolly dirty and/or corroded. The extremely fine wires inside it get that way after some 40+ years and only give a signal where clean. You can clean them up being very careful so as not to break them, or you can just replace the sending unit for a new one. Good luck! Cool
dstefun
dstefun is offline
PostPosted: Wed Feb 27, 2008 12:42 pm    Post subject: Reply with quote
Since a new sender is only $31 at busdepot, if I'm pulling the engine and tank to work on the sender, I'm putting in a new one. Be sure to release the float on the new one or you'll be pulling it out again!
arthurnugen
Location: The PNW, where "going green" means rolling with moss.
arthurnugen is offline
PostPosted: Wed Feb 27, 2008 3:52 pm    Post subject: Reply with quote
Dave, what do you mean by releasing the float?
cdennisg wrote:
Lawyers don't deserve buses.
zozo wrote:
Don't worry too much. You can always trust a lawyer.
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke!
420GOAT
Location: Wilmington, CA on a nice quiet street but still in the 'hood
420GOAT is offline
PostPosted: Wed Feb 27, 2008 4:22 pm    Post subject: Reply with quote
sorry to but in it is a pin that is stickered to hold the float for shipping...how do i know? wellllllllll. luckily i was still able to pull it out without removing the engine or tank. 271-919-051b for $28 at wcm for a VDO of brazil. Wink
once you realize im not impressed we will get along just fine
zozo
zozo is offline
PostPosted: Wed Feb 27, 2008 5:04 pm    Post subject: Reply with quote
The pin or the sending unit?
wanta23
wanta23 is offline
PostPosted: Wed Feb 27, 2008 5:38 pm    Post subject: Reply with quote
I'm assuming the pin. If I could get the whole unit out, yes I'd just replace it. But pulling the motor and tank might be a bit beyond for me, I'm still reading up on valve adjustments Smile
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed Feb 27, 2008 7:08 pm    Post subject: Reply with quote
Then follow this procedure: Carry with you a gallon jug of gas. Fill up the tank, note the odometer reading down. Drive the bus to work, around town, etc., the way that you'd normally drive. Drive it all the way until it runs out of gas. Note the odometer reading down at this point. Figure out how many actual miles your bus will go on a full tank of gas. Pour the gallon of gas into it and go fill up the tank. Note the odometer reading now and every time you fill up. This way you'll know when to fill up BEFORE running out of gas. Cool
Though my gauge "reads" okay, I still always carry a gallon and also note the odometer reading at every fill up. Smile
Old Skool Daddy
Old Skool Daddy is offline
PostPosted: Wed Feb 27, 2008 7:56 pm    Post subject: Reply with quote
Mine reads 3/4 too, but when I throw the headlights on, it reads full. Zany Splits. Rolling Eyes
64 Standard
Sell my bus? Would Han Solo sell the Millenium Falcon?
winmotors
winmotors is offline
PostPosted: Wed Feb 27, 2008 11:23 pm    Post subject: Reply with quote
I have the exact problem with my gauge....I usually just fill up when my needle gets to 1/4.
My questions is .... do you have to remove the tank to replace the sending unit?
Thanks
Karl
Karl is offline
PostPosted: Wed Feb 27, 2008 11:38 pm    Post subject: Reply with quote
Same as upgrading to a larger bay tank here: http://www.vintagebus.com/howto/tank.html
Just go for the R&R part Smile
joe cool
joe cool is offline
PostPosted: Wed Feb 27, 2008 11:47 pm    Post subject: Reply with quote
I replaced the sending unit and swapped gauges but my fuel gauge still only reads accurately between 1/4 and 3/4. Above and below that it can't be trusted.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Thu Feb 28, 2008 7:12 am    Post subject: Reply with quote
Refer to my previous post! Confused
The Dormy has a custom made 17.5 gallon aluminum tank and uses a bug sender. Also, not having any baffles causes the sender and thus the gauge needle to bounce quite a bit. Though I do keep track of how many miles since the last fill up, I know I HAVE TO get gas real soon when the needle stops bouncing!!! Shocked
Vintage Split
Vintage Split is offline
PostPosted: Mon Jan 05, 2009 6:09 pm    Post subject: Reply with quote
Is there a way to test the sending unit outside of the bus? For that matter it is outside of the tank. I took it apart yesterday. Verified the tiny wire is in place and lightly cleaned the contact points on the float. As best I could, I verified continuity through the wire and terminal (old shoddy tester - I'm bringing another home tonight). It seems pretty simple.
Am I correct in thinking, "If the wire is in place, and the float goes up and down, and all the connections are clean it should work." Otherwise, any other tips?
1967 bus. Thanks,
Mike
--Mike--
0-60...eventually.
Clara Premium Member
Clara is offline
PostPosted: Mon Jan 05, 2009 6:20 pm    Post subject: Reply with quote
1967 bus. Thanks,
Mike
I've tested a sender outside a bus with a battery, a fuel guage and a bucket of water.
You can take the tube off the sender by uncrimping the 'washer' and undoing the nut at the end. You can polish up the wire and contact places with fine (1000 grit) sandpaper to restore the connections. That's what I did to the sender in my kombi, that was previously in a bus with a cruddy tank.
Vintage Split
PostPosted: Mon Jan 05, 2009 6:28 pm    Post subject: Reply with quote
The internals look good so I'll test it like you suggested next.
Thanks,
Mike
--Mike--
0-60...eventually.
Daddybus
Daddybus is offline
I've got a Baywindow tank (15 gallons) and sender (expensive little B) and a 6v bus gauge (12-90 ohms I believe). I had a 12v bus gauge before and they read the same...R means I have 3 gallons in the tank and a full tank reads almost full on the gauge. I will try a GM 0-90 ohm gauge next to see how it reads.
I also keep a mileage log as a back up.
Vintage Split
PostPosted: Mon Jan 05, 2009 10:43 pm    Post subject: Reply with quote
Thanks,
Mike
Hmmm, so I did the test and all that it verified is my gauge works. Basically went to full once I connected the battery regardless of the float level. I double checked the wiring diagram. Ground to sender, sender to gauge, gauge to + on battery. Correct? Am I missing something, or this is an ok test?
--Mike--
0-60...eventually.
Clara is offline
PostPosted: Mon Jan 05, 2009 10:48 pm    Post subject: Reply with quote
Thanks,
Mike
did you ground the guage? you know how the guage grounds where the U clamp hits the underside of the dash? ... clip a ground wire to one of the studs the U bracket goes on, and see if that works.
Vintage Split
PostPosted: Mon Jan 05, 2009 11:05 pm    Post subject: Reply with quote
Thanks,
Mike
Doh! That worked Clara. I was working inside my wife's Toyota (available battery) and didn't ground the gauge like you said. Now I can put the tank back in... one step closer.
Thanks.
Mike
--Mike--
0-60...eventually.
