Can i weld my engine case if it has a crack
[email protected]
justjoshenu@hotmail.com is offline
PostPosted: Sat Feb 22, 2003 10:58 pm    Post subject: Can i weld my engine case if it has a crack Reply with quote
my engine case has a crack..
and i think theres no hope for a case saver..
would i damage anything by trying to weld the crack in the case...
would it even work?
thank you in advance
josh
wgargan
wgargan is offline
PostPosted: Sat Feb 22, 2003 11:06 pm    Post subject: Can i weld my engine case if it has a crack Reply with quote
i would not know but the guys that do would probably need to know what kind of case it is. what i can tell you is, the origenal bug engins are either made of magnesium (not likely) or have magnesium mixed in with the "other" metal. and if it is a later engin from a bus or type four it is alumminum. i know that aluminum can be welded with an alluminum welder of cours, but i do not know if the other cas can be welded. so what is the answer? i dont know, lets find out.
[email protected]
vw61ragtop@attbi.com is offline
PostPosted: Sat Feb 22, 2003 11:57 pm    Post subject: Can i weld my engine case if it has a crack Reply with quote
Since you're actually heating up the metal to a melting point when welding, I wouldn't want to even try if there is magnesium in it. Seeing how magnesium doesn't exactly extinguish once it's on fire.
[email protected]
PostPosted: Sun Feb 23, 2003 12:28 am    Post subject: Can i weld my engine case if it has a crack Reply with quote
is there a way of telling if i have a magnesium case or not...
the numbering system on engine?
any help would be much apreciate
to make the magnesium cases, they had to heat it up to melting point to pour the mold so...im not trying to be cynical, just wondering if its worth a a try...
if it was magnesium what type of welder would one try..would they all pretty much do the same job?
[email protected]
PostPosted: Sun Feb 23, 2003 12:38 am    Post subject: Can i weld my engine case if it has a crack Reply with quote
i took amother look at it...
it looks like someone tried to work on the crack..bastards sold me a mickey mouse engine and i didnt even know it...burned again
so i guess someone tried to repair it, but i still want to try it before i give up and put alot of work and money into another engine...
ANY ADVICE OR WISDOW WOULD BE SOOOOOOOOOOO APPRECIATED....PLEEEEEEASE (im desperate)
jeremysmithatshawdotca
jeremysmithatshawdotca is offline
PostPosted: Sun Feb 23, 2003 1:37 am    Post subject: Can i weld my engine case if it has a crack Reply with quote
It is possible to weld magnesium, but you probably need to take precautions to keep it from overheating, and the durability of the results certainly wouldn't match a new case. You are better off to get a new case, any hope to get the guys who sold you the engine to do right? Who are they? Good luck, Jeremy
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sun Feb 23, 2003 3:51 am    Post subject: Can i weld my engine case if it has a crack Reply with quote
The decision to weld a case depends upon quite a few variables. The old engine cases were welded all the time. I have a 36 horse that has a pancake sized patch in front of the oil cooler where the piston detonated and put a small hole in the case. I disassembled the engine and inspected it thuroughly before rebuilding. I have been running that engine for the past six years with no problems... You do not mention where on the case you need to weld, that is an important consideration. some cracks tend to grow and effect a critical stress point in which case I would start over with a different case.
edgy
edgy is offline
PostPosted: Sun Feb 23, 2003 11:20 am    Post subject: Can i weld my engine case if it has a crack Reply with quote
Be sure to check cost of welding exotic metal. May exceed price of new case. Why weld it if you aren't sure of result. New cases aren't that expensive.
