JBMorse Samba Member
Posted: Sun Jun 22, 2008 5:42 pm Post subject: Trike brakes-plugging holes in mc? |
I recently had the opportunity to try out a VW trike which was excellent! I pored it over for a whole weekend with my dad and brothers. The body was made from a kit and the front was just an old honda 500.
Anyway, the brake master cylinder was from a vw and had one or two of the holes plugged. The trike uses the honda front brakes, so only the master cylinder only feeds the rears. My question is: where can you get those plug fittings? I can't find them anywhere and I could use some for a separate project. I am using a VW master cylinder for something that originally used a master cylinder with fewer outlets.
Thanks for any help!
Jeremy B |
vw_triker Samba Member
Joined: June 23, 2007 Posts: 99 Location: Southern Illinois USA
Posted: Mon Jun 23, 2008 11:23 am Post subject: plugs |
| I am also working on a vw trike. I bought a new mastercylinder and have not bought plugs for blocking off the other 2 holes. I was planning on filling them with bolts of the correct size. |
bob cook Samba Member
Posted: Fri Jun 27, 2008 6:34 pm Post subject: mc plugs |
| I have in the past just taken the nuts off of brake lines and welded the holes shut works good |
Posted: Fri Jun 27, 2008 9:51 pm Post subject: MC holes |
| Bob, I was thinking the same thing today...LOL |
quantri64 Samba Member
Posted: Fri Jul 18, 2008 6:45 pm Post subject: Plugs |
Any brass, bronze or steel METRIC ones will work.
You can get them from Lowe's, Home Depot or
most auto parts stores.
If you have tried that with no luck, you will notice
they would be the same size as the brake line fittings
that went into the m/cylinder.
Those plugs can be bought anywhere. Seems to me
the people you have been talking to are in the wrong
business. |
rlevans Samba Member
Posted: Wed Jul 23, 2008 10:55 am Post subject: |
| Buy an old bus or Beetle master cylinder that only has a single circuit |
Posted: Wed Jul 23, 2008 5:53 pm Post subject: |
I have a single circuit master cyl., there are still three holes for lines.... I just welded the ends of the old fittings.... _________________ Ride it like you built it! |
Posted: Sat Jul 26, 2008 5:38 am Post subject: Re: Plugs |
| quantri64 wrote: |
business. |
I thought the brake line fittings were a different thread from hardware store plugs. Are you talking about plumbing fittings or bolts? I guess I could take a line down to the store and see what fits.
I would just weld them shut but I don't have a welder or know how to weld. |
wheelsof3 Samba Member
Joined: July 26, 2008 Posts: 1 Location: Tampa Bay area Brandon
Posted: Sat Jul 26, 2008 1:37 pm Post subject: New Member and Triker |
Hi I ride a Trike and just finished my current one about a month ago. My old trike had the vw master I just purchased brass fitting "Caps" and that did the trick. I prefer a single MC but the double will work - think of filling one hole with your Brake light sensor.
Good luck on the build |
