Simon DeCasas Samba Member
Posted: Sat Nov 15, 2008 11:30 am Post subject: Type 3 Front Sway bars |
Anybody have an aftermarket front sway bar on there car? How is it mounted and any problems with the way its mounted? I have a rear bar and was wanting to upgrade the front. I know they come with one stock I just want to stiffen the front to match the back. I have seen one by empi but they are almost nonexistent. Any suggestions on an improvement over stock?
Last edited by Simon DeCasas on Sat Nov 15, 2008 6:36 pm; edited 1 time in total |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11497 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Sat Nov 15, 2008 2:10 pm Post subject: Re: Type3 Front Sway bars |
| Simon DeCasas wrote: |
| Anybody have an aftermarket front sway bar on there car? How is it mounted and any problems with the way its mounted? I have a rear bar and was wanting to upgrade the front. |
you are aware that the Type 3 beam has one built in, right? _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36223 Location: Conejo Valley, CA
Posted: Sat Nov 15, 2008 4:08 pm Post subject: |
You are smart to look to increasing front roll stiffness if you are adding a rear bar. Otherwise you increase oversteer, already a problem in these cars.
It owuld be nice if someone made stiffer stock-mount T3 bars, but I know I'm dreamin'... |
red_6 Samba Member
Joined: July 01, 2008 Posts: 57 Location: Denver City Denver
Posted: Sat Nov 15, 2008 6:24 pm Post subject: |
God I wish,
It was a nightmare just finding a replacement stock beam for mine! |
frank2 Samba Member
Joined: December 27, 2003 Posts: 246 Location: Portland, OR
Posted: Sat Nov 15, 2008 6:39 pm Post subject: |
I have a empi front swaybar on my square.Has mounting clamps similar
to a bay bus style.Dont think it does much other than look cppl.-Frank  |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Nov 15, 2008 6:57 pm Post subject: |
| red_6 wrote: |
God I wish,
You didn't ask me. And I am just a 1/2 day drive.
And where are all the ones that KCW pulled out. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
localboy Samba Longboarder
Joined: December 06, 2003 Posts: 5153 Location: "Mainland", PNW
Posted: Sun Nov 16, 2008 11:50 am Post subject: |
| Russ Wolfe wrote: |
| And where are all the ones that KCW pulled out. |
Excellent question. _________________ One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project |
DucMike Samba Member
Joined: November 27, 2006 Posts: 156 Location: Outskirts of Sacramento, CA
Posted: Tue Nov 18, 2008 2:38 pm Post subject: |
| KTPhil wrote: |
It would be nice if someone made stiffer stock-mount T3 bars, but I know I'm dreamin'... |
Correct me if I'm wrong, but didn't they increase the diameter of the upper bar at some point, say somewhere around '70? Larger diameter should equal an increase in stiffness. At least it felt like it did when I swapped out the one on my '66. Running that & my old camber compensator & it seems to corner pretty flat. _________________ Mike S.
'66 Variant Sunroof TIII4ME
'76 Rabbit
'91 Passat Variant (Big 'back)
'96 GTI VR6
'03 20th AE GTI OEM+ 20th
Niello Ranch Run |
wolfman's brother Samba Member
Posted: Tue Nov 18, 2008 7:49 pm Post subject: |
| localboy wrote: |
| Russ Wolfe wrote: |
Excellent question. |
if I had to guess they were tossed in the scrap heap and crushed,probably already melted down,made into cheap chinese crap and sitting on a shelf in wal-mart(sprawl mart)in the form of a cheap toaster already.the kcw terrorist don't care  _________________ insanity takes it's toll,please have exact change ready.
my imaginary friends keep telling me I have a mental problem. |
Posted: Tue Nov 18, 2008 9:51 pm Post subject: |
| wolfman's brother wrote: |
| localboy wrote: |
| Russ Wolfe wrote: |
if I had to guess they were tossed in the scrap heap and crushed,probably already melted down,made into cheap chinese crap and sitting on a shelf in wal-mart(sprawl mart)in the form of a cheap toaster already.the kcw terrorist don't care  |
SIGH....  _________________ One man's "patina" is another man's cancer...
Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Tue Nov 18, 2008 10:14 pm Post subject: |
| Russ Wolfe wrote: |
| ...And where are all the ones that KCW pulled out. |
That's sig line material right there. LO effing L. _________________ OGST
Samba Member #4862 |
KTPhil  Samba Member
Posted: Wed Nov 19, 2008 11:11 am Post subject: |
| Rear bars changed at some point, and may be different for early swing square vs fastback. I didn't think the fronts ever changed.... anyone know for sure? |
Syncronaut Samba Member
Joined: September 17, 2004 Posts: 24 Location: Trondheim, Norway
Posted: Wed Nov 19, 2008 2:48 pm Post subject: |
According to the VW parts book (and how I read the info given there...) the front sway bar came in two different diameters; 11.0 mm and 13.7 mm. The thinner version came in all type 34, Notch- and Fastbacks and in the Squareback for '67 and '68 model years, where as the other Squareback models has the thicker one (this is also true for all AT Squarebacks...).
So you people with Ghias, Notches and Fastbacks (and myself, since my Squareback is a '68 ) want to look for a Squareback front sway bar if you want to stiffen up the front end a bit. And be sure to stay away from model years '67 and '68  _________________ Gorm |
KTPhil  Samba Member
Posted: Wed Nov 19, 2008 2:56 pm Post subject: |
| Excellent info! I will check mine when I reset the ride height. I have a spare axle and would like the stiffer bar if it has it. |
Posted: Fri Nov 21, 2008 8:36 am Post subject: Type3 Front Sway Bar |
| If a latter 13mm bar helps what is stopping us from making a 19mm bar for the front that would fit in the stock location? It would be a matter of gettting the right kind of steel and machining the ends to fit the torsion arms right? If there is enough interest I don't see why we as the type 3 community couldn't make a short run of these bars from a small machine shop and have a awsome suspension set up. Any body know a friendly machine shop? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18050 Location: Eugene, OR
Posted: Fri Nov 21, 2008 9:02 am Post subject: |
Any Machine Shop could do it! If your first set comes out good post some pictures and we'll buy from you!  _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
KTPhil  Samba Member
Posted: Fri Nov 21, 2008 10:52 am Post subject: |
| Choice of steel and the heat-treating required may not be so simple. Filleting work is also critical. VW cautions that small nicks (or even rust from a nick in the paint) can cause failures under stress. But with homework it may be possible. |
Franz Samba Member
Joined: March 31, 2005 Posts: 346 Location: Grand Junction
Posted: Fri Nov 21, 2008 1:40 pm Post subject: |
| localboy wrote: |
| Russ Wolfe wrote: |
Took them to the metal recycler...really! About 10 type 3 beams complete drum to drum. Along with about 5 RGB bus transaxles. _________________ https://www.vervemotorworks.com/ |
Posted: Fri Nov 21, 2008 1:47 pm Post subject: |
| Syncronaut wrote: |
So you people with Ghias, Notches and Fastbacks (and myself, since my Squareback is a '68 ) want to look for a Squareback front sway bar if you want to stiffen up the front end a bit. And be sure to stay away from model years '67 and '68  |
From what I remember (& it's been a while now), my '66 had the smaller 11mm bar in it when I swapped it out & it was an untouched car before I got my hands on it.  _________________ Mike S.
'76 Rabbit
'96 GTI VR6
Niello Ranch Run |
grethi Samba Member
Posted: Fri Nov 21, 2008 2:37 pm Post subject: |
What about these?
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=SSS0002&cartid=
Does anyone have any pro/con info on these, or what difference they make to the vehicle stability and safety? Would using them as pictured damage or warp the factory suspension?
For that matter, it looks like the one currently mounted under my Subaru Impreza DD. _________________ My mind not only wanders, sometimes it leaves completely.
'69 square |
