Dual Carb Linkage Easy Question
Zippy11
Zippy11 is offline
PostPosted: Mon Dec 08, 2008 1:24 am    Post subject: Dual Carb Linkage Easy Question Reply with quote
When sincing the carbs we know you remove the linkage but the linkage from the top of carb to the bottom has alot of pull on it should it? it seems like it should be resting without preasure. PO put the dual carbs on it and not sure if he knew what he was doing Please help
Thanks
Zippy11
Zippy11 is offline
PostPosted: Mon Dec 08, 2008 6:06 pm    Post subject: Reply with quote
I can't believe that no one on this forum can answer this question i've got more replies on the ford forum about a volkswagon Come on guys STEP UP your looking pretty bad this can't be the first time this question has come up or all your VWs are adjusted wrong.
abgwin
abgwin is offline
PostPosted: Mon Dec 08, 2008 6:17 pm    Post subject: Reply with quote
wow, i'm now certain that since you asked so nice, we'll all fall all over ourselves helping you out.
why don't you try the search function, since you're so certain it's been asked before?
otherwise, sounds like the Ford forum is where you'll be more comfortable. good luck.
Euro 67
Samba's 67 part whord
Euro 67 is offline
PostPosted: Mon Dec 08, 2008 6:18 pm    Post subject: Reply with quote
What type, There is only so much we can do with the crappy info that you gave.
68 Bug totaled one day will live again
69 Bug donor car
Many parts had, always need em!
millerje78 wrote:
I'm no expert but I'm guessing the spike during cold running has everything to do with the roofing tar(20-50) in the crankcase.
bill may wrote:
...i could be wrong as i have only been driving air cooled beetles since august 1965.
Bobnotch
Bobnotch is offline
PostPosted: Mon Dec 08, 2008 6:21 pm    Post subject: Reply with quote
I expected to see more replies too. Try this link for your answers.
http://www.thesamba.com/vw/archives/manuals/t3dualcarbtuning/
I hope it helps.
P.S. I'm running FI, so I can just look up above in the 90+ page sticky for my answers. Wink
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Zippy11
Zippy11 is offline
PostPosted: Mon Dec 08, 2008 6:24 pm    Post subject: Reply with quote
Watch your mouth little guy! I just need some info. They are solex 32 Pdsit It's the short linkage from the top of the carb to the throttle shaft I assume There is supposedly a spec for the length but can't seem to find it in any of the books we have.
Thanks
Zippy11
Zippy11 is offline
PostPosted: Mon Dec 08, 2008 6:31 pm    Post subject: Reply with quote
What kind of help is that if you don't know you don't know! Sorry for the attitude didn't mean to bring it here just a long day and I APOLOGIZE to all.
SORRY
Bobnotch
Bobnotch is offline
PostPosted: Mon Dec 08, 2008 6:33 pm    Post subject: Reply with quote
You don't adjust them. They are set to a length at the factory. But according to my Blue Bentley, the length is 99mm +- .2mm (3.89 inches +- .008).
Tram wrote:
Tram wrote:
Zippy11
Zippy11 is offline
PostPosted: Mon Dec 08, 2008 6:36 pm    Post subject: Reply with quote
Thank You Bobnotch you came through. The ones on this engine are at different lengths that's why the post. This should help get us on the right track at least. I knew you guys would come through
Again Thank You!
