don.ville Samba YardMan
Joined: February 07, 2008 Posts: 2831 Location: West Palm Beach, FL
Posted: Sat Jan 27, 2024 4:13 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Using existing random screw holes to attach the cargo door interior door panels
I ran out of trim screws so I’ll do the top two and bottom two middle screws later _________________
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
rudygetz Guaperia Ful Tine
Posted: Sat Jan 27, 2024 5:48 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Looks amazing! _________________ 1965 Standard Sunroof Bus build
1967 Beetle |
Posted: Sat Jan 27, 2024 8:42 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
rudygetz wrote: |
Looks amazing! |
Thank you Rudy.
Wow, back on the samba 😄.
I thought only old folks like me hang out here.
Your sig says you have a split now? Is it running ? _________________
Posted: Thu Feb 08, 2024 6:07 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
During my cargo door interior panel install a few weekends ago.
Posted: Thu Feb 08, 2024 6:11 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
My seat covers from TMI have arrived, and need to find the time to get them installed.
I just glued some gray fabric over the seat to cover the old black bay window seats
Time to rip this stuff off.
I have to strip the seats to the frame and fix springs then recover everything. _________________
Posted: Tue Mar 19, 2024 8:10 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Temporary glued on fabric over ripped bay window seats.
I sprayed the edges of the bay window seats with rattle can gray.
Waiting to install new TMI covers for the middle and rear seats
TMI website did not show Mesh Grey Vintage Vinyl, only Platinum Mesh.
So I incorrectly ordered Platinum Mesh Gray and luckily TMI called me before making the covers to ask it I was sure that it what I wanted.
I sent them a pic of my front seats and they confirmed that I needed Dark Grey Vintage Vinyl and Mesh Grey Vintage Vinyl combination for a early bay (68-73) middle and rear seats along with the molded foam seat padding. _________________
Posted: Thu Mar 21, 2024 6:37 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
don.ville wrote: |
I sent them a pic of my front seats and they confirmed that I needed Dark Grey Vintage Vinyl and Mesh Grey Vintage Vinyl combination for a early bay (68-73) middle and rear seats along with the molded foam seat padding. |
Don your thread has so much valuable information and this is such perfect timing for to read now that I found the bay window short middle seat. I was scratching my head about what fabric to pick to match what I’ll eventually need. Keep on updating us on your progress. I’m going to start to arrange pictures so I can start a build thread for my bus. It’s under the knife right now! _________________ 1965 Standard Sunroof Bus build
1967 Beetle |
Posted: Fri Mar 22, 2024 7:19 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
rudygetz wrote: |
Don your thread has so much valuable information and this is such perfect timing for to read now that I found the bay window short middle seat. I was scratching my head about what fabric to pick to match what I’ll eventually need. Keep on updating us on your progress. I’m going to start to arrange pictures so I can start a build thread for my bus. It’s under the knife right now! |
Thanks Rudy... _________________
Posted: Fri Mar 22, 2024 7:22 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Ready to roll (in the rain)
No wipers since 2008
Posted: Sat Mar 23, 2024 10:35 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
I have to jump start my bus using a lithium ion charger every now and then since late 2023.
I bough this Optima red top in 2011 https://www.thesamba.com/vw/forum/viewtopic.php?p=5433918#5433918
The lithium-ion jump box needs to be kept charged and sometimes I forget to do that.
So I got 13 years out of the Optima to date, including many times it being dead as a doornail when I don't drive much.
It is sealed, so I don't get any battery terminal corrosion.
I have a trickle charger, but I don't use it much, only sometimes.
I think I'll just get another Optima Red Top battery to save a breakdown later when I least expect it.
I hope I can find the single terminal version locally without the side terminals _________________
Posted: Sat Mar 23, 2024 1:18 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Bought a new battery from Autozone again.
Optima Red Top
Model: 7586DT
Manufacture Date: Sept. 2023
Got new terminals also.
Since one of the posts on batteries are thicker than the other (5/16") vs (6/16")
from the pics below it looks like I was using 2 positive terminal clamps causing the negative clamps to be squashed more out of shape.
The new ones I got came as a set with two different sizes post clamps.
Showing the dimensions of the battery hold down tray and measurement between the lip and the bolt hole.
The hold down clamp adjust for different sized batteries by flipping it upside down.
Posted: Mon Mar 25, 2024 4:32 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Got my seats back from upholstery guy. I really should have done them myself.
I know the frames were rusty, but if they were as bad as he explained I would have stopped and found some way to weld them up before wrapping them.
He just did a quick fix and moved on.
The middle seat frame top section is rusted away and gone (red lines) and so are the tops of the springs in this area.
He added a piece of thin wood under the foam to reinforce it.
One day I’ll do something about it.
The half hack refinishing of my middle and rear seats cost over $2k so I have a real appreciation when I see perfect looking seats properly done.
Rear seat fitment.
The new rear seat upright cover doesn’t have the tail that covers the crack when folded down so I have to make something to hide that.
One of the the seat legs was replaced with bent pipe that a friend welded in for me a few years back, so the seat clamps don’t fit properly.
Posted: Mon Mar 25, 2024 4:37 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
I bought a middle seat clamp kit a while back with aluminum clamps and wing nuts.
I also have collected original seat clamps and bolts when I got the bay window bus seats in 2008.
They are slightly different but work ok. _________________
Posted: Mon Mar 25, 2024 4:43 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
The fit of the TMI seat cover seems too tall on the 2/3 middle seat.
Notice the top of the seat back stitching is not at the edge, but at the top?
Even though the bottom edge goes tightly into a channel
The sides seem to need glue or stitching to close up the gaps once the cover is installed. I will have to do that myself.
Posted: Mon Mar 25, 2024 4:48 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Rear seat in, getting ready for short middle seat
Looks much better and hopefully should hold up as long as the front seats.
I didn’t install the middle seat belts as yet. I need to find a good set on the classifieds to match the rear. _________________
Posted: Mon Mar 25, 2024 4:54 am Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
This is where I got nuts since I had a piece of the corrugated plastic, vinyl, glue and a wicked set of tools
Velcro tape on the seat leg and kick panel
You know what’s coming next
Rolling pin action
The flea market kick panel is born
Posted: Wed Apr 03, 2024 5:43 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Purchased a clean, matching, working set of bay window bus seat belts from @TYPE4$YNDYKAT
https://www.thesamba.com/vw/classifieds/detail.php?id=2664502
Easy transaction and got them in today to use for my middle seat.
WARNING:
All the stuff I do to my bus is for off road use only, for show use only, for demonstration purposes only.
So, factory seat belts are supposed to be fastened to the floor of the bus to some reinforced plates welded under the floor.
Since my bus is a death trap, I welded 4 nuts high up on the legs of the middle seat a long time ago because I hated the look of seat belts stretching to the floor from the middle seat.
Here is the result:
Now they match the rear seat belts. 👍 _________________
Posted: Wed Apr 17, 2024 5:52 pm Post subject: Re: 67 Standard Peach Kombi, West Palm Beach, FL |
Sprayed with Walmart American Accents satin stone gray 2X
