1960 steering bearing?
mdwman
mdwman is offline
PostPosted: Wed Mar 25, 2009 5:31 am    Post subject: 1960 steering bearing? Reply with quote
Did this model year have this bearing at the top of the steering column? I am trying to troubleshoot a constant horn problem that came on while driving down the road. Worked normally before; stock set up. I cannot see anywhere the column or wire is contacting the body. I have removed the steering wheel and the horn still sounds so I guess the horn ring is not the culprit. Could the steering bearing and spring be the problem? Where is it located and how can I check or remove? I perused some parts suppliers and this bearing is described as for '62-67.
Thanks for any help.
MDWMAN
bikerbrain
bikerbrain is offline
PostPosted: Wed Mar 25, 2009 6:15 am    Post subject: No Reply with quote
From what I have researched and found, the 60 model did not come with the bearing. I believe it did start with 61 or 62.
58volks
58volks is offline
PostPosted: Thu Mar 26, 2009 9:28 am    Post subject: Reply with quote
I have the same problem,
changed the 2 gromets for the colum, checked the wiring close to the steering box, if I honk, I doesnt work. If I turn a little left, the it Beeps.
Let me know how it turns out! Im clueless too. (or just tired....)
mdwman
mdwman is offline
PostPosted: Thu Mar 26, 2009 1:56 pm    Post subject: Reply with quote
Problem solved! I took off the bracket for the steering column to get a better look under there even though the rubber bumpers and grommet was intact. With the column loose I could see a worn area on the top directly beneath the speedo that was apparently making contact. I put a piece of electrical tape over it temporarily and no more constant honk.
MDWMAN
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Thu Mar 26, 2009 2:46 pm    Post subject: Reply with quote
Aha! Thought it might be something like that! Glad you got it fixed. (I was kind of snowed in out at work on Monday/Tuesday and wasn't really able to get online much to follow your previous thread on this topic.)
Oh, and I think the 1960-61 used the same bearing as the later 60s models did. Maybe not, as I see them sold as fitting 62/up, but I thought the bearing was the same, it was just some extra insulation in the spring setup and where the turn signal cancel tab bolts to the steering wheel that isolated that unique 60-61 horn setup.
-Andy
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Thu Oct 22, 2009 7:40 am    Post subject: Reply with quote
Does the bearing on a '65 tap out of the top of the tube or down through the bottom? Need to get it out ASAP for paint / clean up and also to install new WW bearing.
Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
bill may
bill may is offline
PostPosted: Thu Oct 22, 2009 8:28 am    Post subject: Reply with quote
out the top.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Thu Oct 22, 2009 11:09 am    Post subject: Reply with quote
Thanks Bill!
Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
