This doesnt sound right (deck height)
Bashr52
Bashr52 is offline
PostPosted: Thu Jun 18, 2009 7:24 am    Post subject: This doesnt sound right (deck height) Reply with quote
I bought what I was told were 92B's for my 2234 project. I'm in the mockup stages now, and I have a .155 inch over hang from the pistons. Sounds to me like these are really A's no?
turboblue
turboblue is offline
PostPosted: Thu Jun 18, 2009 7:37 am    Post subject: Reply with quote
Not really.
84 stroke takes a pretty healthy shim pack.
Is your case decked as well?
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
The Noof
The Noof is offline
PostPosted: Thu Jun 18, 2009 7:42 am    Post subject: Reply with quote
Sounds about right to me, especially if the case registers have been cleaned up.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Thu Jun 18, 2009 10:01 am    Post subject: Reply with quote
Do they make long 92's?
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
nsracing
nsracing is offline
PostPosted: Thu Jun 18, 2009 2:25 pm    Post subject: Re: This doesnt sound right (deck height) Reply with quote
Only that much overhang? It is not a drop-in huh, Bash? Very Happy
How long are the rods you using?
Just push the cylinder up to the deck you desire then measure the deck space below the cylinder. Mock up some shims together and see where the final deck figure is. Then find or have the proper spacers made.
They make really long cylinder barrels and just trim for whatever height you need. These cylinders are really usefull when you go to the 88mm strokes and 6-inch rods. Talk about a wide engine block.
Bashr52
Bashr52 is offline
PostPosted: Fri Jun 19, 2009 11:09 am    Post subject: Reply with quote
Ok just checking. These cylinders were run on a stroker briefly before, and the tops of the pistons were machined slightly to help with deck. I guess I'm giving RIMCO or someone a call with the shim dimensions... Mabie I'll give the local machine shop a call as well.
Rods are 5.5 chevy.
