mstngsal67 Samba Member
Posted: Mon Jun 08, 2009 6:44 am Post subject: 72 super only runs with choke on |
72 super beetle. long story short, rebuilt the engine - new seals, gaskets, exhaust, spark plugs, wires, etc... put it back in and it doesn't run right - - will only run with the choke on! (take choke off, it dies) we are thinking there is a vacuum leak, but cannot find anything (have re-tightened all connections). We have adjusted the set screws on the side of the carb and still a no go without the choke! PLEASE HELP!!! By the way - not sure if they have anything to do with eachother, but the ignition coil is REALLY hot!! (found a wiring diagram on another post and will verify that it is wired correctly). |
Dakota Bug Samba Member
Joined: September 23, 2007 Posts: 235 Location: Dickinson ND
Posted: Mon Jun 08, 2009 6:50 am Post subject: |
What type of carb and ignition are you using? |
Randy in Maine Samba Member
Posted: Mon Jun 08, 2009 6:59 am Post subject: |
Tell us about the gaskets you used to mount the carb to the intake and the intake to the heads. |
Posted: Mon Jun 08, 2009 10:06 am Post subject: |
ok - the carb is a 34 pict 3. ignition, i'll have to check.
the gasket from the carb to intake is a flimsy paper-ish thing. if i remember correctly, the intake to the heads is a metal gasket. |
Posted: Tue Jun 09, 2009 2:26 pm Post subject: still a no go |
we reinstalled the old carb (30 pict) and it ran without the choke on. took the brand new carb off (was working just fine before the rebuild), cleaned it out, put it back on, and still a no go. UGH!!!! HELP!!! |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79586 Location: Sneaking up behind you
Posted: Tue Jun 09, 2009 2:30 pm Post subject: |
Sounds like a vacuum leak. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
UJSLOST Samba Member
Joined: February 05, 2009 Posts: 56 Location: Alabama
Posted: Tue Jun 09, 2009 3:48 pm Post subject: |
mine done this and the jets on the right side of the carb were backwards . Swapped them and blew them out with carb cleaner and now all is good, |
BluSky Samba Member
Joined: October 05, 2008 Posts: 30 Location: Swansboro NC
Posted: Wed Jun 10, 2009 1:43 pm Post subject: |
Had a riding mower that did the same thing. It turned out to be a loose fuel line clamp which allowed air to enter the fuel stream which made the engine run lean and that in turn demanded more choke to enrich the fuel mix. Also take a look at your fuel filter it may be starving the carb if it is clogged. Hope this helps. |
