broken exhaust valve Yreka CA
Clara Premium Member
Clara is offline
PostPosted: Fri Jun 12, 2009 8:17 am    Post subject: broken exhaust valve Yreka CA Reply with quote
Just got a call this morning from my boyfriend who is broken down, he caught a ride down to the Classic with a friend with a 79 westy. Turns out the #3 exhaust valve had the end break off. The piece was lying in there near the rocker arm. That valve was not opening due to the end breaking off. Vince was trying to screw the adjusting screw in to adjust it, but then it was screwed so far in there wasn't enough room for the keeper nut. I suggested to put the nut on the other side of the rocker arm but there may not be space ? Awkwardness.
It just got new heads recently, I am not sure if this engine is hydraulic or not.
So... brand new heads...
broken valve,
WTF!
Is this a common issue?
mattcuddy
mattcuddy is offline
PostPosted: Fri Jun 12, 2009 8:30 am    Post subject: Re: broken exhaust valve Yreka CA Reply with quote
I'd be worried that the grooves for the valve spring keeper wouldn't hold anymore.
broken valve,
WTF!
Depends on the heads used, and/or the builder. Wink
germansupplyscott
germansupplyscott is offline
PostPosted: Fri Jun 12, 2009 8:36 am    Post subject: Re: broken exhaust valve Yreka CA Reply with quote
broken valve,
WTF!
if the heads are new then they are made by AMC and the valves are not very good out of the box on these. the keepers do not fit well, for one thing, and the minimum acceptable for using these heads is to correct the keeper fit and replace the valves. seems ridiculous to have to service a brand new head, but that's the reality.
SL
busdaddy
busdaddy is offline
PostPosted: Fri Jun 12, 2009 8:42 am    Post subject: Reply with quote
Sorry to hear you are finding this out in Yreka Crying or Very sad That's not really a roadside job to fix.
Слава Україні!
Clara is offline
PostPosted: Fri Jun 12, 2009 9:31 am    Post subject: Reply with quote
Turns out Vince had replaced all the valves before installing the head. I guess he knew about that deal with quality new parts. Confused
So one of the new valves that did not come with the head had broken.
They only had a minimal tool/parts kit with them.
Chris House has since earlier this morning hooked them up with tools and a new valve. Thanks Chris, you rock!
Vince and Greg had the head off, replaced the valve, and the head is being torqued back on right now.
Cross your fingers!
Very Happy
onion456
onion456 is offline
PostPosted: Fri Jun 12, 2009 10:02 am    Post subject: Reply with quote
you guys are hardcore Razz
'76 Sage Green Westy 2.0 FI
'76 Creamsicle 7-passenger 2.0 CS FI
'85 Tan Westy
House
Minutia Militia
House is offline
PostPosted: Fri Jun 12, 2009 11:13 am    Post subject: Reply with quote
They are done and gone... Two hours start to finish Smile
Onward to OCTO!
busdaddy
busdaddy is offline
PostPosted: Fri Jun 12, 2009 11:34 am    Post subject: Reply with quote
Great news Exclamation VERY impressive, I think you've raised the bar for everyone with the speed of that fix Shocked Either they were craving In and out really bad or you just wanted that bay out of your driveway right now Wink
Слава Україні!
stevo
stevo is offline
PostPosted: Fri Jun 12, 2009 3:26 pm    Post subject: Reply with quote
two hours, that leaves very little time for reading muir.
skills!
Clara is offline
PostPosted: Sun Jun 14, 2009 8:26 am    Post subject: Reply with quote
They didn't stop by the Blackstar Campout Friday night, but showed up at the OCTO show at 2 am Saturday. That's about 650 miles south of Yreka.
GusC2it
GusC2it is offline
PostPosted: Sun Jun 14, 2009 9:13 am    Post subject: Reply with quote
Im wondering why the piston wasn't destroyed???
75 type 2 http://gusc1.tripod.com/1975vwtype2
Old vices have now been upgraded to bad habits.
http://www.facebook.com/pages/VW-Wild-Weekend-2011-St-Pete-Fl/197064760336111
Clara is offline
PostPosted: Wed Jun 17, 2009 12:11 pm    Post subject: Reply with quote
the little piece of the valve that broke was in the bottom of the head, under the rocker arm.
The keepers were still holding the valve in place.
But with the top broken off, the valve was not opening, the rocker didn't move it. This caused a loss in performance.
stevo
stevo is offline
PostPosted: Wed Jun 17, 2009 12:14 pm    Post subject: Reply with quote
shearly odd. Neutral
GusC2it
GusC2it is offline
PostPosted: Wed Jun 17, 2009 1:16 pm    Post subject: Reply with quote
can you tell what brand of valve it is?
