Reduction box disc brake conversion
victorybug
victorybug is offline
PostPosted: Sun Oct 25, 2020 9:34 am    Post subject: Reduction box disc brake conversion Reply with quote
i have searched up and down and cant find any info on putting disc brakes on small nut reduction boxes, i saw someone did a irs reduction box set up with disc brakes but they did not really specify how they did the disc brakes any help would be much appreciated i do not want to get rid of the reduction boxes
chrisflstf
chrisflstf is offline
PostPosted: Sun Oct 25, 2020 11:18 am    Post subject: Re: reduction box disc brake converstion Reply with quote
There arent any kits for this. Probably because there isnt enough room
victorybug
PostPosted: Mon Oct 26, 2020 12:17 pm    Post subject: Re: reduction box disc brake converstion Reply with quote
not necessarily looking for a kit more along the lines if anyone know whats in the way and whats involved in it, i have read somewhere cant remember where that you can mod a type 3 kit but i have no more info then that
mandraks
mandraks is offline
PostPosted: Mon Oct 26, 2020 12:54 pm    Post subject: Re: reduction box disc brake converstion Reply with quote
considering that there is so much going on on a reduction box rear, like the emergency brake for example, are you sure you need disk brakes on the rear?
are you going racing? disk brakes up front should give you plenty of stopping power?
regards
Uli
victorybug
PostPosted: Mon Oct 26, 2020 1:07 pm    Post subject: Re: reduction box disc brake converstion Reply with quote
i am not going racing but i dont like having to adjust the drums all the time, the fronts do provide enough stopping power, i would not mind more, and how much stuff do we actually put on our cars that we actually need, i just want to set up discs on the boxes so its discs all around and never have to adjust anything
mandraks
mandraks is offline
PostPosted: Mon Oct 26, 2020 1:09 pm    Post subject: Re: reduction box disc brake converstion Reply with quote
gotcha, that is why i asked.
regards
Uli
Spitty1974
Spitty1974 is offline
PostPosted: Mon Oct 26, 2020 1:22 pm    Post subject: Re: reduction box disc brake converstion Reply with quote
Russ at Old Speed had said he might attempt a kit in the future, might want to check with him. He is located in Southern California.
victorybug
PostPosted: Mon Oct 26, 2020 1:52 pm    Post subject: Re: reduction box disc brake converstion Reply with quote
do you have any contact info for russ
peecee69
peecee69 is offline
PostPosted: Mon Oct 26, 2020 2:00 pm    Post subject: Re: reduction box disc brake converstion Reply with quote
Russ is a good guy. He made a beam for my first bus - loooooong gone.
(562) 531-4190
[email protected]
1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight=
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger Facebook Gallery Classifieds Feedback
chrisflstf
PostPosted: Mon Oct 26, 2020 2:53 pm    Post subject: Re: reduction box disc brake converstion Reply with quote
Sounds like a good project to undertake. It comes up every so often, but Ive need seen one. Keeping it inside the fender wells is part of the issue
ToolBox
ToolBox is offline
PostPosted: Tue Oct 27, 2020 8:54 am    Post subject: Re: reduction box disc brake converstion Reply with quote
victorybug wrote:
but i dont like having to adjust the drums all the time...
The amount of time you will spend cobbeling something together will eat up the same amount of time as 10 years worth of brake adjustments. Plus the time spent inspecting and adjusting brakes might lead you to find other issues that might no be caught with a set it and forget it mentality.
If the fronts already off the ground for a king and link pin PM a brake adjustment is only about 10 extra minutes. If you lift the rear to do a valve adjustment another 10 minutes for a rear brake adjustment.
chrisflstf
PostPosted: Tue Oct 27, 2020 2:54 pm    Post subject: Re: Reduction box disc brake conversion Reply with quote
I think Russ at Old speed did some prelim work on this, but never got anywhere. The RGB case makes mounting a caliper mount nearly impossible unless the wheel is spaced wayyy outward. Then there is the Ebrake issue
If your willing to go straight axle, then it can be done - no rgb's
