Obi Van Kenobi Samba Member
Posted: Wed Dec 05, 2018 1:07 pm Post subject: Transmission fluid level after driving |
A few hundred miles ago I refilled my transmission and the level looks good when I check it running in neutral on level ground after a bit of driving , but after an hour or two of driving it checks about a centimeter above the max line on the dipstick. Is this normal or should I drain a bit of fluid?
Thanks for any advice you can share![/b] |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Wed Dec 05, 2018 2:37 pm Post subject: Re: Transmission fluid level after driving |
| djkeev wrote: |
Honestly, a millimeter is akin to nothing when it comes to fluid levels.
Dave |
He said, "Centimetre, Dave." IE ten millimetres!  _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Wed Dec 05, 2018 3:42 pm Post subject: Re: Transmission fluid level after driving |
| A centimeter is pushing the limit in my mind, I would drain or suck a bit out. When filling I usually use less than called for and then add once warmed up to make sure it is at the lower line and then add more as needed once the tranny is nice and hot. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3456 Location: Bozeman MT
Posted: Wed Dec 05, 2018 3:49 pm Post subject: Re: Transmission fluid level after driving |
Doesn't the Bentley / owner's manual specify to check the ATF after warming the engine/trans by driving a certain number of miles (6 or 7 IIRC)?
If that's the case, and if you drove much farther than that, doesn't it stand to reason that the ATF could be higher than the mark just because the trans is warmer than the specified condition for checking the level? _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
