Portland Oregon '66 deluxe resto
bherder
bherder is offline
PostPosted: Sun Aug 09, 2009 6:08 pm    Post subject: Portland Oregon '66 deluxe resto Reply with quote
So the '67 I had went to a better home. I got a sweet deal from a fellow Portlander on a 66 deluxe. Thank you! (you know who you are) Here are some pictures on my progress. Even though I put a lot of work into the other one, this one needs a lot less work. The roof on this one has 3 small dents in it, while the 67 had about 10 thousand dents (as an example)
Seeing what the OG paint is like (that is my dad)
Took a 40 inch 3/4 drive breaker bar and this pipe to break the axel nut free. What a bitch. Someone please recommend some place to that rebuilds tranny/rgb's in the pdx area.
This is what happened to one of the socket wrenches we used
To lock the wheel, we figured out you could stick something in this hole. Worked really well.
Cleaned that black crap off with some lighter fluid.
Sexy
[/list]
My bus resto thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=371654
Parts manual:
http://oacdp.org/
Focker
Focker is offline
PostPosted: Sun Aug 09, 2009 6:45 pm    Post subject: Re: Portland Oregon '66 deluxe resto Reply with quote
I don't think Sears will take that one back...Great bus.
I’ve tried nothing and I'm all out of ideas!
BusterBrown wrote:
Well, I started out with nothing, and still have most of it left!
'67 Type II ~ Lowering My '64 Type I
Alaskan Adventurer
Alaskan Adventurer is offline
PostPosted: Sun Aug 09, 2009 6:56 pm    Post subject: Reply with quote
Gary"s trans axle in kent is good to do buss with, he has done 4 trannys/RGB for me in the last few years no problems and has it done when he said it would be for the price he said, when was the last time you heard of that? P.M. me for his P#
63 DC
60 SC daily driver
campingbox Premium Member
campingbox is offline
PostPosted: Sun Aug 09, 2009 9:56 pm    Post subject: Reply with quote
Hey Brady, if you want to bring the bus or the tranny up to Olympia I would be happy to do it for you.
Good luck with the new project.
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Sun Aug 09, 2009 10:06 pm    Post subject: Reply with quote
Greg you do transmissions?
PostPosted: Sun Aug 09, 2009 10:12 pm    Post subject: Reply with quote
I don't rebuild transmissions. I had thought he was asking about bus reduction boxes, and those are no problem for me to do. Now that I have reread his post I'm not really certain what Brady is looking for.
PostPosted: Sun Aug 09, 2009 10:15 pm    Post subject: Re: Portland Oregon '66 deluxe resto Reply with quote
I would expect that you broke the wheel cylinder into two pieces by doing that. Usually they crack right where the bolt goes through.
Mikee
Samba A.D.D. Boy
Mikee is offline
PostPosted: Sun Aug 09, 2009 10:49 pm    Post subject: Re: Portland Oregon '66 deluxe resto Reply with quote
I have an extra brand new wheel cylinder if you need one
localboymark wrote:
One man's "patina" is another man's cancer.
bugnut68 wrote:
I would have kicked the guy right in the dick, balls, ass and face and destroyed his weed. Hippies suck.
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Mon Aug 10, 2009 6:36 am    Post subject: Reply with quote
Looks sweet!
I'm going to miss your awesome welds.
That nufinish stuff is great after compounding...comes out very shiney. Cool
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
bherder
bherder is offline
PostPosted: Mon Aug 10, 2009 9:11 am    Post subject: Re: Portland Oregon '66 deluxe resto Reply with quote
It had to be done. Couldn't lock the wheel up any other way. E-brake didn't work, brakes were gone. I was literally hanging on that bar like a monkey to get the nut to move. The stange thing was the other side was just finger tight.
I was looking for someone to look over the transmission. I'm going to pull it out and give it a good cleaning at the very least. I was reading in the Bently and the RGB's look pretty easy to rebuild. We'll see if I need any help though. I do have a few spring plate bolts that are broken off inside the back of the RGB.
Parts manual:
http://oacdp.org/
bherder
bherder is offline
PostPosted: Mon Aug 10, 2009 9:13 am    Post subject: Reply with quote
Linda Grunthaner wrote:
Looks sweet!
Did you see the rubbing compound at the rear of the bus? Very Happy You are right though, that combination makes the OG paint look pretty darn good.
Thank you about the welds. I didn't really think they were that good. I only welded for about 2 hours before I tackled the long side rocker.
Parts manual:
http://oacdp.org/
bherder
bherder is offline
PostPosted: Mon Aug 10, 2009 9:15 am    Post subject: Re: Portland Oregon '66 deluxe resto Reply with quote
Actually Greg, I have the page turned to the RGB in this picture. Looks like a few bearings, some gears and a gasket. And a C ring
Parts manual:
http://oacdp.org/
Mikee
Samba A.D.D. Boy
Mikee is offline
PostPosted: Mon Aug 10, 2009 10:35 am    Post subject: Reply with quote
buy one of these and a good hammer or a good impact wrench
http://www.thesamba.com/vw/classifieds/detail.php?id=404552
PostPosted: Tue Aug 11, 2009 10:15 am    Post subject: Reply with quote
I used the Nu Vinyl in the late 70's on my vinyl top and it lasted for 2 years. I am not 100% sure I used Nu Finish in the 70's but I do remember I used something that was a wipe and shine product so this could be the same stuff. As I recall my 65 Pontiac was flat dull blue and I hardly rubbed the product in and she was shiny again. I was amazed.
Check out the commercial I remember seeing it on TV and that's how I learned about it. Whoa 70's how scary Shhh
http://nufinish.com/tv.html
What is in it? The ad says there is no wax.
read here:
http://nufinish.com/products_polish.html
Looks sweet!
PostPosted: Tue Aug 11, 2009 1:03 pm    Post subject: Re: Portland Oregon '66 deluxe resto Reply with quote
Hey Brady, that's a small nut box diagram. Those take less time to rebuild, but still require about $500 in bearing pullers to make the job "pretty easy". On the big nut box you will need to weld a stud from the back side to pull the plug out. The job is pretty easy with the right tools, and a royal PITA without.
PostPosted: Tue Aug 11, 2009 1:07 pm    Post subject: Re: Portland Oregon '66 deluxe resto Reply with quote
Unless you know the transmission is bad, I would try to get it running & stopping to limp it around the block first. Check the gear oil first. If the tranny doesn't make an horrible noises, pop out of gears, or have any major leaks you might consider saving your money. It costs around $400 to rebuild the center section of the tranny and it takes about 8 hours to rebuild both boxes. Those late reduction box bearings aren't cheap, so expect about $200-$300 in parts for both sides if you want to replace them all.
As far as it "having to be done", to get the wheel nut off.
Get an impact gun. If that doesn't work buy one of these;
http://www.empius.com/2009_catalog/empi2009_pg336.html
Tool #5750, or make you own.
Having the right tools on hand always makes things easier and faster with less damage to surrounding parts.
bherder
bherder is offline
PostPosted: Fri Aug 21, 2009 7:45 pm    Post subject: Reply with quote
Is it normal to have RGB fluid pour out of this spot after you take off the brakes? The Bentley manual didn't mention this......
Transmission out! Most likely going to take it over to German Transaxel of America in Bend, OR.
Parts manual:
http://oacdp.org/
Keysar
Samba Grammar Tutor
Keysar is offline
PostPosted: Fri Aug 21, 2009 10:06 pm    Post subject: Reply with quote
hello...im in battle ground wa....what are you going to do with that wheel well and vent... that is in the cargo area of your bus in the pics?
Clara wrote:
...but mainly perfecting my tossing peanuts shells out the window into the air scoops technique.
PostPosted: Fri Aug 21, 2009 11:22 pm    Post subject: Reply with quote
Yes, you are supposed to empty it first.
bherder
bherder is offline
PostPosted: Thu Aug 27, 2009 5:32 pm    Post subject: Reply with quote
The big part in the cargo area was hiding this big hole where the spare tire goes. I was able to cut that part out of my old bus to use in this bus. Here it is fitted and ready to weld up tomorrow.
Parts manual:
http://oacdp.org/
Page 1 of 7
