54ovsemi Samba Member
Posted: Sat Aug 15, 2009 9:11 pm Post subject: April 54 motor... seamed fan shroud? |
Ok.....I need some help with this..so I just got this motor for my 54 Oval project, It's an early 54 production motor according to number on stand. Upon closer inspection when I received delivery of motor I found that it has a seamed fan shroud. I thought these where on earlier cars. Is it correct on for my 54???
Still gonna use it on my project.... |
janerick3 Samba Member
Posted: Sun Aug 16, 2009 12:00 am Post subject: |
It appears to have the faint outline of a square factory rebuild stamp directly under the number. Are there numbers stamped on the right side of the generator stand? If so, it probably received the 25hp fan shroud when it was rebuilt in the mid-'50s, so I'd leave it alone.
It has a 701E intake manifold. I suspect there was a mid-'50s service campaign to retrofit all '54 and early '55 36hp engines with these, so again I'd leave it alone.
The fuel pump, crank pulley and round voltage regulator look correct. It looks to have the late '54-'55 wide-lip generator pulley. Does it have the '54-'55 only oil filler or the smaller, teardrop-shaped '53 cap with the mesh filter inside?
Other than the "modified" dual-tip muffler, I probably would keep it the way it is. You'll need a strap-type Knecht air cleaner or a two-clip, dome-top Mann (acceptable for very late '54s and '55s), a TE6A3 coil and a VJU6-BR8 distributor (assuming it was rebuilt with flat-top pistons).
Given the amount of dust and lack of later 36hp accessories, I'd guess the engine's been stored under cover for at least 45-50 years. _________________ Thanks,
Jan K. |
52brezelfenster Samba Member
Posted: Sun Aug 16, 2009 8:45 am Post subject: |
If you decide to swap it out, you won't have any trouble finding a new home for that seamed fan shroud  |
Posted: Sun Aug 16, 2009 12:49 pm Post subject: |
janerick3 wrote: |
Given the amount of dust and lack of later 36hp accessories, I'd guess the engine's been stored under cover for at least 45-50 years. |
janerick3....thx for the info, I did find a number stamped on the right side of stand 234 423
is there any way to findout when and where it was rebuild???
some pics of it cleaned up a little...and the seamed shroud.
billmetric Samba Member
Joined: March 16, 2006 Posts: 1062 Location: Columbus City USA
Posted: Sun Aug 16, 2009 3:03 pm Post subject: |
nice! the fan shroud, oil filler and spark wire tube clamps are 100% split era parts, you could easilly sell or trade them off to someone who needs them in exchange for the correct aircleaner and some extra cash, whether or not the factory put a seamed fan shroud on a 36hp rebuild its way WAY wrong on a '54 car, no one is going to give you extra points for having split window parts on your oval engine, the voltage regulator is late '50s early '60s, since the entire thermostat mechanism and air ring is missing from the back of the shroud I'm going to say that the engine has been "touched" a few times since it was rebuilt, no telling how that shroud got on there, the generator is not a split one though _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
bally Samba Member
Joined: April 29, 2006 Posts: 1195 Location: Melbourne, Australia
Posted: Tue Dec 04, 2012 4:47 am Post subject: |
When did the fan shroud change from seamed to smooth? I'm guessing in 52, but when in 52 if I'm correct?
Cheers,
Dave |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4770 Location: St Charles, MO
Posted: Fri Jun 27, 2025 11:32 am Post subject: Re: April 54 motor... seamed fan shroud? |
I believe that the current general consensus is that the seamed to smooth change happened in Feb 1952...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Joined: April 27, 2002 Posts: 6738 Location: Pentwater, Michigan
Posted: Fri Jun 27, 2025 2:09 pm Post subject: Re: April 54 motor... seamed fan shroud? |
Janerick3- thinking it’s a typo- a VJ 6 BR 8 distributor- they do exist-will not be happy in a VW engine. The six would indicate the points cam would have six lobes for a six cylinder engine. _________________ Roads Scholar
Member# 2059
bugnutt Samba Member
Posted: Fri Jun 27, 2025 4:19 pm Post subject: Re: April 54 motor... seamed fan shroud? |
It looks like a factory rebuilt 25hp engine with upgraded components, that looks like an aluminum case and there were no aluminum-cased 36hp engines. It would be interesting to see what piston and cylinders are under the tin
Check the production dates on the generator stand |
Posted: Sat Jun 28, 2025 10:21 am Post subject: Re: April 54 motor... seamed fan shroud? |
One other thing, the number on the side of the tower, 234 423, if that is the original engine number, falls in the aluminum case era. ; |
Posted: Sat Jun 28, 2025 11:03 am Post subject: Re: April 54 motor... seamed fan shroud? |
Bus distributor= VJR 4 BR 8. Beetle= VJUR 4 BR 8. _________________ Roads Scholar
Member# 2059 |
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 28096 Location: Free State of Florida
Posted: Sat Jun 28, 2025 10:10 pm Post subject: Re: April 54 motor... seamed fan shroud? |
VW kept many of the earlier parts on the industrial engines. I've seen an industrial 36hp with the seamed shroud. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
