MANNAXMAN Samba Member
Posted: Mon Jan 18, 2010 8:58 am Post subject: 1961 Brake Lights and Turn Signals Don't Work |
I searched, but I didn't find the answers I need. Let me start by saying the following: The car is 12V and all bulbs are 12V. I checked all of the bulbs while in their sockets and ALL are good. My turn signal switch is a 6-wire switch with push on terminals, but I'm not sure if it's an original 1961 turn signal switch. The back of the arm looks like the one in this ad (third pic), but it doesn't have the holes in the ring (as shown in the bottom of the ring in the first pic). I didn't take a pic of it while I had the steering wheel off, but I remember it had a VW symbol embossed on the ring. So here's my situation:
Brake Light Problem
My friend and I checked for voltage at the lights and there is voltage when the brake pedal is depressed. But when the wires are connected to the bulb holders, the left brake light lights up intermittently, the right brake light doesn't light at all. However, if we bypass the turn signal switch and connect the wire from the brake switch directly to the brake light wires under the hood, the brake lights light consistently when the brake pedal is depressed. WTF?!?
Question 1 - Is my turn signal switch bad?
Turn Signal Problem
I recently purchased this flasher relay from CIP. I have it wired according to the diagram below and it seems to have a good ground. When I activate the left turn signal, the relay clicks consistently, the rear left turn signal flashes sometimes, but the front left turn signal does not flash at all. When I activate the right turn signal, the relay clicks sometimes but neither the front nor the rear signals flash. If I connect the front turn signal wires directly to the fuse for the headlights and turn on the headlights, the turn signals light up. At one point while troubleshooting the rear signal lights, I had the left tail light disassembled and just the wires connected to the bulb holder but the bulb holder wasn't grounded. When I activated the left turn signal, the filament for the parking light flashed.
Question 2 - What would cause the relay to not click consistently when the right turn signal is activated?
Question 3 - Why won't the front turn signals flash if they light when connected to the headlight fuse?
Question 4 - Is the parking light supposed to flash when the turn signal is activated?
Komissar Samba Member
Joined: May 18, 2008 Posts: 894 Location: Bucharest, Romania
Posted: Mon Jan 18, 2010 9:42 am Post subject: |
An important thing:
Since you got the car did it always behave like that, or it started recently?
My bet would be bad grounds in the rear... _________________ 1965 Sunroof Beetle
1972 Type 3 Squareback
1978 Skoda 105S |
Posted: Mon Jan 18, 2010 10:55 am Post subject: |
When I bought the car at the end of Sept., the brake lights and turn signals didn't work. It had the wrong flasher relay, for one thing. I just recently started to work on the electrical after spending most of my Saturdays working on the brakes and engine. How can it be a bad ground in the rear if the brake lights work consistently when connected directly to the brake switch (bypassing the turn signal switch and relay)? That's what has my friend and me so confused. I would think either the turn signal switch or the relay is bad, or both. But as stated above, when wired through the turn signal switch and relay, we get voltage when the brake pedal is depressed. They just don’t light up. I even tried to connect an extra ground wire on the left tail light to see if it was a ground problem and it still only worked sometimes when connected through the turn signal switch and relay.
By the way, I forgot to mention that it still has the snow flake tail lights. |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26534 Location: Douglas, WY
Posted: Mon Jan 18, 2010 11:30 am Post subject: Re: 1961 Brake Lights and Turn Signals Don't Work |
Quote: |
Question 1 - Is my turn signal switch bad? |
I think so, you bypassed the switch entirely, and the brake lights work. So it follows that the connection in the "middle" position of the turn switch is not connecting those as it should.
Quote: |
Question 2 - What would cause the relay to not click consistently when the right turn signal is activated? |
Poor connections somewhere.
Quote: |
Question 3 - Why won't the front turn signals flash if they light when connected to the headlight fuse? |
Well, make sure you have power to whatever source you are using to test those lights. If you are using a headlight fuse as a source, that headlight circuit needs to be on!
Quote: |
Question 4 - Is the parking light supposed to flash when the turn signal is activated? |
No it is not. Separate circuits entirely. If there are bad grounds somewhere at the rear bulbs you might get feedback into the parking light circuit though.
-Andy |
Posted: Mon Jan 18, 2010 2:03 pm Post subject: Re: 1961 Brake Lights and Turn Signals Don't Work |
glutamodo wrote: |
I think so, you bypassed the switch entirely, and the brake lights work. So it follows that the connection in the "middle" position of the turn switch is not connecting those as it should. |
Can you think of a reason why, when the brake lights are connected through the turn signal switch, we get voltage on a meter when the brake pedal is depressed, but the lights don't come on? And is the switch more likely the problem than the flasher relay? How can I confirm the switch is the problem other than bypassing it like we did?
glutamodo wrote: |
Poor connections somewhere. |
That's what I thought. But if the only change we make for the lights (not the relay) is where the incoming wire is connected, and the lights then work, shouldn't that rule out a poor connection? And wouldn't that point more to the turn signal switch and/or the relay? (Is what I'm saying/asking clear?)
glutamodo wrote: |
Well, make sure you have power to whatever source you are using to test those lights. If you are using a headlight fuse as a source, that headlight circuit needs to be on! |
My question probably was not clear. I hooked up the front turn signals to the headlight fuse ONLY to check if they work, and they do. It is when the front turn signals are connected to the turn signal switch that they don't flash. In my original post, I said that the front left doesn't flash at all. There were a few times that it did flash, but for the most part it doesn't flash at all. |
Posted: Mon Jan 18, 2010 3:33 pm Post subject: |
Where are you checking that you have +12V? If you connect any +12V to the black/violet turn switch wire, with the switch in the middle position you should have +12V at the black/red and black/yellow wires. If you don't, the switch is not working. |
Posted: Tue Jan 19, 2010 10:10 am Post subject: |
We checked at the rear. We pulled the terminals off of the bulb holders, one probe to the terminal, the other probe to ground. We indirectly did what you're suggesting. But if there is a bad connection from the brake switch wire to the black/violet wire, I could see that being the reason the brake lights aren't working if the switch is good. I'll try testing the switch directly the next time I'm down at my friend's house. |
Posted: Tue Jan 19, 2010 10:30 am Post subject: |
Sometimes the brake light switch will test out OK un-loaded, like it will output 6V or 12V when the wire is unplugged, but once you plug it into the circuit and a current path, it's worn out to the point where the contacts inside can deliver the current and you drop to zero volts.
I think I started to mention this but then I guess I didn't, but you can check the turn signal switch itself with an ohm-meter. You'd be best to unplug the wires coming out of it and leading into the car. Set your meter on the most sensitive ohms setting. Touch the leads together and read what it says, that is your meter's reading for "continuity" - Then with the turn switch in the middle position: The black/red, black/yellow and black/violet wires should all read continuity. Make a left turn, then the black/green/white should have continuity with the black/yellow and black/white wires. (and meanwhile, the black/violet and black/red should still have continuity) Make a right turn and the black/green/white shoud have continuity with the black/green and black/red wires. (and then black/violet and the black/yellow should still be connected)
-Andy |
Posted: Sat Jan 30, 2010 6:47 pm Post subject: |
glutamodo wrote: |
I think I started to mention this but then I guess I didn't, but you can check the turn signal switch itself with an ohm-meter. You'd be best to unplug the wires coming out of it and leading into the car. Set your meter on the most sensitive ohms setting. Touch the leads together and read what it says, that is your meter's reading for "continuity" |
The meter pegged out.
glutamodo wrote: |
Then with the turn switch in the middle position: The black/red, black/yellow and black/violet wires should all read continuity. |
Not sure if my friend and I did this right. Disconnected all connections from the turn signal switch, except the black/green/white to the relay. One lead on black/violet, other on black/yellow - meter reads nothing. One lead on black/violet, other on black/red - meter reads nothing. One lead on black/yellow, other on black/red - meter reads nothing.
glutamodo wrote: |
Make a left turn, then the black/green/white should have continuity with the black/yellow and black/white wires. (and meanwhile, the black/violet and black/red should still have continuity) |
One lead on black/green/white, other on black/yellow - meter fluctuates but never pegs out. Didn't check the other wires.
glutamodo wrote: |
Make a right turn and the black/green/white shoud have continuity with the black/green and black/red wires. (and then black/violet and the black/yellow should still be connected) |
One lead on black/green/white, other on black/red - meter reads nothing. Didn't check the other wires.
What conclusion(s), if any, can I draw from these findings? |
Posted: Sat Jan 30, 2010 7:21 pm Post subject: |
Black/violet should connect to black/red whenever the switch is in middle position and on left turn. Black/violet should connect to black/yellow whenever the switch is in the middle position and on right turn.
I'd consider the brake light portion of the switch as bad.
black/green/white and black/yellow only get connection on left turn.
black/green/white and black/red only connection on right turn. |
Posted: Sun Jan 31, 2010 9:28 am Post subject: |
Is this something that can be easily fixed or am I better off just buying a replacement switch? |
Posted: Sun Jan 31, 2010 10:14 am Post subject: |
Depends on what brand of switch it is. You can try and take it apart - sometimes they are a bugger to get back together though. Some switches don't have any way of making the contact tabs stay in place once you take them apart. Others have tabs you can get to which can be secured, or are already bent or peened over so they will not fly out. You might want to look in this thread as to some photos of what some switches look like inside.
http://www.thesamba.com/vw/forum/viewtopic.php?t=157894 |
Posted: Sun Jan 31, 2010 10:32 am Post subject: |
It was a couple of weeks ago when I took the steering wheel off to look at the switch, so I don't remember for sure. I think it looks like one of the two below. I'm pretty sure SAE was embossed on the outside of the switch. I can't confirm that right now, as my car is at my friend's house.
Posted: Mon Feb 01, 2010 5:18 pm Post subject: |
Found these pics in the classifieds. Pretty sure this is what my switch looks like.
Chip  Samba Member
Posted: Mon Feb 22, 2010 8:04 pm Post subject: |
Did you ever get this issue sorted? My 60 had some funky issues as well. Signals would both work, but my right brake light would light...explain that one. I found that it was the contacts inside the switch. I took my switch apart and had to fix the surface of the contact pads inside. They had channels worn in them after 50 years of use and these were causing issues. I fixed the channels and everything works! Don't use solder though, this IS what I did, and now i'll need to redo it in the near future. I'll just file them down next time around instead of building up with soft solder. Be careful when you open up the switch, there are a bunch of little tiny springs under the copper contacts and they are gonna want to come apart as the unit is opened. Good luck with getting it all sorts out. It can be a major head scratcher at times, but there really is not that much too it. It's probably just worn contacts. |
Posted: Tue Feb 23, 2010 8:27 am Post subject: |
No, I haven't fixed the problem yet. The car has been sitting at my buddy's house for the last few months, so I'm only able to work on it on the weekends. But I'm planning to bring it home this Saturday. I've been trying to find an original '61 turn signal switch to replace it with, but they aren't cheap. I'll probably attempt to take the turn signal switch apart when I get the car home. I'll keep you posted. |
Chip  Samba Member
Posted: Tue Feb 23, 2010 12:08 pm Post subject: |
I ran into the same issue with the switch, they are expensive! Mine had a broken off handle as well as the poor contacting issues. I ended up buying a 66-67 one, and making a hybrid of the 2. I wanted the dimmer switch that was in the handle for line lock/rev limiter purposes. It just so happened that I managed to get everything to do what I needed. It is worth the effort to try to repair your old switch. It won't take long, its just intimidating. Definitely worth the $100+ that you'll save.
Chip |
Posted: Tue Feb 23, 2010 3:23 pm Post subject: |
I've done it too - combined two switches to make one good one. Remember though, you can only combine switch parts if they are made by the same company.
-Andy |
Chip  Samba Member
Posted: Tue Feb 23, 2010 3:46 pm Post subject: |
Interesting, thats good to know. Mine was not a direct swap over, it required a little "machining" to get everything to fit and function like it was supposed to. |
Posted: Sat Mar 06, 2010 5:46 pm Post subject: |
I decided to re-test my switch as Andy prescribed. I did this on my own, as I now have the car at home.
glutamodo wrote: |
This tested out ok.
glutamodo wrote: |
Set your meter on the most sensitive ohms setting. Touch the leads together and read what it says, that is your meter's reading for "continuity" - Then with the turn switch in the middle position: The black/red, black/yellow and black/violet wires should all read continuity. |
I don't know if it was because the battery in my meter was dying, but I wasn't getting much of a reading when I touched the probes together, so I just set it to the tone setting. Initially I got a tone on black/violet-black/yellow and black/violet-black/red.
glutamodo wrote: |
Initially I got a tone on black/green/white-black/yellow but nothing with black/green/white-black/white. Black/violet-black/red also gave a tone.
glutamodo wrote: |
I did not get a tone on any of these.
I tried repeating everything, except checking for +12V. Each time, I got a different result. So I decided to take my turn signal switch apart. Here's what the inside looked like AFTER I cleaned the grease off of the contacts (I didn't think about taking pics until after I started cleaning things).
There was so much grease on the contacts before cleaning them that the T-shaped contacts from the lever part of the switch were sticking to them when I pulled the switch apart.
After cleaning all the grease off of the contacts, I proceeded to re-assemble the switch. I was having some difficulties putting the lever back on, and, unfortunately, in the process, the mechanism that holds the self-cancelling arms onto the posts broke off. This is pic shows what I'm referring to (pic taken prior to them breaking).
I still have the washers. Can I solder them onto the posts or use something like JB Weld? Any suggestions?
Anyway, I re-assembled the switch without the self-cancelling parts, just to see if it would work. With the hood open, I could see both front turn signals working. I had to get creative to check the rear signals, as I was by myself, but they both worked as well, as did the brake lights!
By the way, Andy, the pic of the switch you posted with the text that says "MISSING SOME CANCEL PARTS" is the same as mine. I don't think it's missing any cancel parts, as I'm pretty sure mine worked fine before taking it apart. |
