Thing rear spring plates
Kustom41
Kustom41 is offline
PostPosted: Sat Jan 30, 2010 12:38 pm    Post subject: Thing rear spring plates Reply with quote
I am going to raise back up my Thing ( Crying or Very sad ) and I notched the rear spring plates and need to know if they are Thing only spring plates or the same as Beetle ones so I can put some non-notched ones back on.
thanks for the help,
J.D.
uberautowerks
uberautowerks is offline
PostPosted: Sat Jan 30, 2010 1:03 pm    Post subject: Reply with quote
Interchangeable for the '73 and later Beetle units. Although the Thing plates are a bit thicker.
Try calling you're local VW shops for these!!
Eric
--- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black)
Kustom41
Kustom41 is offline
PostPosted: Sat Jan 30, 2010 1:14 pm    Post subject: Reply with quote
Eric
cool thanks, I will look for some Thing ones then
kubelmann
kubelmann is offline
PostPosted: Sat Jan 30, 2010 4:17 pm    Post subject: Reply with quote
I have a number of these OE Thing parts available.
Bruce
Bruce is offline
PostPosted: Sat Jan 30, 2010 11:16 pm    Post subject: Reply with quote
71 and 72 spring plates are identical. There wasn't any change in the rear suspension in 73.
uberautowerks
PostPosted: Sun Jan 31, 2010 4:23 pm    Post subject: Reply with quote
I thought the early IRS had the "double" spring plates?!
- Douglas Adams -
'74 Thing (White)
kubelmann
PostPosted: Sun Jan 31, 2010 4:57 pm    Post subject: Reply with quote
IRS Things have their own Spring Plates
pn 181 511 205 (lft) and 181 511 206 (rt)
MAny Bug parts will (fit) on a Thing and vice versa. That does not mean they are the same part. Thing has loads of 68-71 T-2 parts but they can be replace with lighter duty stock beetle parts. There is a huge difference between will they fit and are they the same quality/strength...
Bruce
Bruce is offline
PostPosted: Mon Feb 01, 2010 2:10 am    Post subject: Reply with quote
Double spring plates are 68 autostick, and 69-70 Beetle, plus all IRS Type 3s. 71 and later Beetles plus Type 181 used single spring plates.
