fuel guage question
pioneer1
pioneer1 is offline
PostPosted: Tue Nov 10, 2009 3:05 pm    Post subject: fuel guage question Reply with quote
In my 84 ,with new gas tank and sender unit, the gauge is "wonky". After a fill up, the dash guage never shows full. The level drops off quickly to 3/4 tank after 40 miles and when it hits empty I still have 15 gallons or so.
Is there an adjustment on the sender,or a test? or could it be the voltage regulator? What relation does it have to the guage and where is it under the dash? Thanks
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
Vsyevolod
Vsyevolod is offline
PostPosted: Tue Nov 10, 2009 3:17 pm    Post subject: Reply with quote
Often times, it's the wires that need replacing. That or the sender unit itself has gone tits up. Unfortunately, the best time to replace that sender unit is when you already have the tank out...
Stephen
Home Team Van
Home Team Van is offline
PostPosted: Tue Nov 10, 2009 3:27 pm    Post subject: Reply with quote
the voltage reg is in the center of this picture. It's on the back of the instrument cluster.
_________________________________
82 Diesel Westy
pioneer1
pioneer1 is offline
PostPosted: Tue Nov 10, 2009 6:02 pm    Post subject: fuel gauge Reply with quote
Thanks for the picture and location.The sender is new but how/what does the voltage regulator affect the fuel gauge reading?
dobryan
dobryan is offline
PostPosted: Tue Nov 10, 2009 6:34 pm    Post subject: Re: fuel gauge Reply with quote
My voltage stabilizer is bad, reads 12 volts not 9.5 - 10.5 and as a result the gas gauge reads somewhat high. Basically it always reads 1/4 tank higher than I actually have.
Dave O
The Western Syncro build
rolfsky
rolfsky is offline
PostPosted: Tue Nov 10, 2009 10:51 pm    Post subject: Re: fuel gauge Reply with quote
Tom Hanks, is that you? Very Happy
'85 Merian brown Vanagon Westfalia
dobryan
dobryan is offline
PostPosted: Wed Nov 11, 2009 9:18 am    Post subject: Re: fuel gauge Reply with quote
Do these things come with real A/C or do I just keep the windows open??
Wink Razz
Dave O
Vanagon Nut
Vanagon Nut is offline
PostPosted: Wed Nov 11, 2009 11:56 am    Post subject: Re: fuel guage question Reply with quote
AFAIK, the voltage regulator does exactly what it's name implies. The temp gauge and fuel gauge need a constant voltage. (~ 10 volts IIRC) If the regulator wasn't there, variations in voltage would either harm the gauges and/or the gauges would provide incorrect readings.
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
pioneer1
pioneer1 is offline
PostPosted: Wed Nov 11, 2009 12:17 pm    Post subject: fuel gauge Reply with quote
Thanks VNut for the answer-I guess I'll check the voltage and go from there.
Vanagon Nut
PostPosted: Wed Nov 11, 2009 8:23 pm    Post subject: Re: fuel gauge Reply with quote
You're welcome.
I found that the middle pin on mine ('81 air cooled) is not be connected to the foil. Still worked fine to measure from there as per Bentley though. Just in case yours' is the same.
(VW Gas I4)
VE7TBN
whafalia
whafalia is offline
PostPosted: Thu Nov 12, 2009 8:54 am    Post subject: Reply with quote
If I recall correctly the middle pin equals the mounting tab equals ground.
Dogpilot
Dogpilot is offline
PostPosted: Thu Nov 12, 2009 9:33 am    Post subject: Reply with quote
If your voltage regulator is bad, your temp gauge will be wonkey as well. The float in the tank may be mis-adjusted or the rod bent. You may want to pull it out and check it against the gauge outside the tank and then bend the rod to get proper readings.
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
Vanagon Nut
PostPosted: Thu Nov 12, 2009 11:09 am    Post subject: Reply with quote
Yup. That's what I found on mine.
Neil.
(VW Gas I4)
VE7TBN
reluctantartist
reluctantartist is offline
PostPosted: Thu Nov 12, 2009 12:19 pm    Post subject: Reply with quote
I had to replace my voltage regulator when I would run out of gas at 1/4 of a tank. At least I got the impression of having awesome gas mileage for a little while. I have some extra voltage regulators in my parts drawer if anyone has a trouble finding one.
1982 Westy, 1974 412 Variant... Yes, Aircooled's are great! Oh and I do have modern computer controlled vehicles too, but I just don't care about them.
stayfido
stayfido is offline
PostPosted: Wed Dec 23, 2009 4:02 pm    Post subject: Reply with quote
Any idea where to find one of these voltage regulators? Is it a specific Volkswagen part or a generic electronic component I can find more easliy?
BC Westie
BC Westie is offline
PostPosted: Wed Dec 23, 2009 4:45 pm    Post subject: Reply with quote
I went through this couple of years back. With an Air Cooled without a Water temp gauge it is easy to think it it the sender unit in the tank.
I replaced my tank sender, baptized by fuel, only to find my gauge was the same.
I then went to check the voltage regulator and there was a touch of wht corosion on the arms. Cleaned them off and voila!
Turns out I did not need a sender unit in the tank.
I think everyone should start with this cheap part. As mentioned easy to diagnose if you are water cooled.
I did try to source one and my local moms and paps auto parts store could get them cheaply out of the US.
1980 Vanagon Cali Import 86,000Miles
1981 Vanagon (Auto) 219,000kms
1981 Westfalia (Auto) Cali Import 169,000Miles
1981 Westfalia 300,000kms
1982 Westfalia Cali Import 193,000Miles
1982 Westfalia (Auto) 205,000Kms
1984 Vanagon 306,000kms
1987 Vanagon GL 300,000Kms
mad.macs
mad.macs is offline
PostPosted: Wed Mar 17, 2010 9:12 am    Post subject: Reply with quote
The 1A Voltage Regulator is $0.75 at mouser.com
the 2.2A VR is NLA (apparentley)
http://www.mouser.com/Search/Refine.aspx?Keyword=KA7810A
Fairchild Semi PN KA7810A
Do we need the 2.2A or will 1A do?
'84 Rivi Vanagon Auto Trans, Stock WBX
Dogpilot
Dogpilot is offline
PostPosted: Wed Mar 17, 2010 9:22 am    Post subject: Reply with quote
I don't think the system would draw more than an amp for the cluster, but then again the sensor for the coolant tank level, which is essentially a conductivity meter, may be the culprit for high draw. Thinking about it, at .75¢, live on the dangerous side and experiment. The worst that can happen is your .75¢ goes up in smoke. The regulator will die, nothing else.
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
