obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2946 Location: East Northport, NY
Posted: Thu Jun 29, 2017 2:26 pm Post subject: Re: The Stupid Question Thread |
Because the ball lets me mount other things to it while still being removable - and my matting up the new dash. _________________ Mike
1964 Beetle
2001 Eurovan Camper |
Disko72 Samba Member
Posted: Thu Jun 29, 2017 6:10 pm Post subject: Re: The Stupid Question Thread |
Hi! First time posting, and new bay window owner. Meet Sunshine!
Question - early on my list will be to replace the front emblem. Which appears to be a 7" fastened clumsily with two screws, not from behind using the fasteners or clips Ive seen on most websites. Any idea how or I can replace this emblem without having to drill new holes in her front?
TIA
D
wcfvw69 Samba Purist
Posted: Thu Jun 29, 2017 9:01 pm Post subject: Re: The Stupid Question Thread |
Welcome,
If you don't won't to drill new holes, you can use the 3m double sided tape that most flaps sell. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Jun 29, 2017 9:05 pm Post subject: Re: The Stupid Question Thread |
Disko72 wrote: |
Question - early on my list will be to replace the front emblem. Which appears to be a 7" fastened clumsily with two screws, not from behind using the fasteners or clips Ive seen on most websites. Any idea how or I can replace this emblem without having to drill new holes in her front? |
I would say it depends on what emblem you are putting on and how original you want the mounting to be. Using trim tape as suggested would be one way to go. |
Tcash Samba Member
Posted: Thu Jun 29, 2017 9:43 pm Post subject: Re: The Stupid Question Thread |
Disko72 wrote: |
Front emblem mounting measurements
https://www.thesamba.com/vw/forum/viewtopic.php?t=264673&highlight=emblem |
beatles4 Samba Member
Posted: Fri Jun 30, 2017 2:50 pm Post subject: Re: The Stupid Question Thread |
This was answered a while ago but I didn't have the free time to take a look until right now I've been working on my bus motor for many many months My general grabbers have Wheel run at full lock all the way to the left. You guys said to inspect the adjusters on the beam to limit will turn radius. Attached is a photo of what my van looks like. I could not see the adjusters. My passenger wheel rubs on the sway bar at Full left but not full right. Any ideas? Did the previous owner muck with my beam?
_________________ Click to view image
http://www.vw-mplate.com/mplate2-27771.png |
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
Posted: Fri Jun 30, 2017 3:46 pm Post subject: Re: The Stupid Question Thread |
Hard to see from that angle. but you should have 2 stop bolts on the beam like this
Here is mine at full left turn with grabbers. See where the travel is limited by the bolt just before the bar hits the tire?
_________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0 |
Tcash Samba Member
Posted: Fri Jun 30, 2017 4:27 pm Post subject: Re: The Stupid Question Thread |
Not all Center links had the steering stop bolts.
Make sure your sway bar is not bent or installed wrong.
Good luck
Tcash |
Posted: Fri Jun 30, 2017 4:39 pm Post subject: Re: The Stupid Question Thread |
Hmm, ill have to see about adjusting the sway bar then because I could not for the life of me see those stops on my beam.
Follow up question. I bought a t fitting for the oil pressure switch so I could run a vdo oil pressure sender as well as the stock sender for the idiot light. In going for a test drive it looks like I have a leak from that sender area. How do you know when tight is enough on that t fitting? I was afraid of over torquing it and stripping the case threads. Any input?
For what it is worth I can continue to tighten the fitting by using my hand and grasping the sender and rotating it all as a unit. I have the VDO sender in the top port and the oem style on on the side port. My thought process was to keep as much of the weight inboard as possible to prevent from stripping out the threads and putting the vdo sender on the side port would further extend it from the motor and give it more leverage with gravity.
This is the particular one I bought.
https://www.egauges.com/T-Adapter-VW-male-M10-x-1-p/240-850.htm _________________ Click to view image
Posted: Fri Jun 30, 2017 4:40 pm Post subject: Re: The Stupid Question Thread |
It looks like you have an aftermarket (EMPI) sway bar on it that's much thicker than stock? _________________ Contact me at [email protected]
Posted: Fri Jun 30, 2017 4:42 pm Post subject: Re: The Stupid Question Thread |
wcfvw69 wrote: |
It looks like you have an aftermarket (EMPI) sway bar on it that's much thicker than stock? |
Do you think mine is aftermarket too or are you just referring to the other person that chimed in with his photo of his setup with an aftermarket swaybay? _________________ Click to view image
Posted: Fri Jun 30, 2017 4:57 pm Post subject: Re: The Stupid Question Thread |
beatles4 wrote: |
wcfvw69 wrote: |
Do you think mine is aftermarket too or are you just referring to the other person that chimed in with his photo of his setup with an aftermarket swaybay? |
Oops, I thought that was your photo. I can't tell with your picture if yours is stock or not. _________________ Contact me at [email protected]
Posted: Fri Jun 30, 2017 6:25 pm Post subject: Re: The Stupid Question Thread |
wcfvw69 wrote: |
beatles4 wrote: |
wcfvw69 wrote: |
Oops, I thought that was your photo. I can't tell with your picture if yours is stock or not. |
Yeah mine is not stock. Thats the "HD" sway bay _________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Posted: Fri Jun 30, 2017 6:53 pm Post subject: Re: The Stupid Question Thread |
I am intending to have a custom sway bar made that will give extra clearance for the fatter than stock tires. I am going to do one for the rear as well as there is no reason for the rear bar to hang down the way some do. Probably go with a 7/8" or 1" front bar and a 5/8 or 3/4" rear bar. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Fri Jun 30, 2017 7:05 pm Post subject: Re: The Stupid Question Thread |
Disko72 wrote: |
Sunshine is beautiful! And she appears to be in great shape. Congratulations on a terrific find!
But I'm a little confused... She has an early bay Westy top, but a late bay body (hi lights, no step bumper). Did someone replace the pop top at some point? Or was it a bus assembled during a transitional production phase? _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51182 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jun 30, 2017 7:20 pm Post subject: Re: The Stupid Question Thread |
KentPS wrote: |
But I'm a little confused... She has an early bay Westy top, but a late bay body (hi lights, no step bumper). Did someone replace the pop top at some point? Or was it a bus assembled during a transitional production phase? |
It looks like a 73, early top and mostly early interior on a later body, still has the gas door though. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 30, 2017 7:21 pm Post subject: Re: The Stupid Question Thread |
Good catch, Busdaddy. I missed the gas door. _________________ -Kent-
---williamM |
Posted: Tue Jul 04, 2017 11:23 am Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
KentPS wrote: |
It looks like a 73, early top and mostly early interior on a later body, still has the gas door though. |
AFAIK (and according to the PO ownership) she is a '72. She may have had some body work mid-70's, I believe the interior is orig. Motor rebuilt 10 yrs ago. However, as her 2nd owner, I would love any help in how I can identify which parts came from which year ie 72 or mid-late 70's.
Re the emblem there appears to be three unused drilled holes behind the current emblem besides the two current screws - 2 at the top and one at the bottom, so 5 holes total. Sticky tape might be the best way to adapt a new one. Any idea whether 7" emblem is the right size for a '72? Thanks for all the help friends! |
bbrowncods Samba Member
Joined: December 27, 2014 Posts: 58 Location: Virginia
Posted: Tue Jul 04, 2017 1:10 pm Post subject: Re: The Stupid Question Thread |
Anyone know what the small black piece of tin is with the hole in it. It is mounted on the case just below the oil breather.
Sorry about the camera angle. 1979 engine.
Posted: Tue Jul 04, 2017 1:18 pm Post subject: Re: The Stupid Question Thread |
bbrowncods wrote: |
Anyone know what the small black piece of tin is with the hole in it. It is mounted on the case just below the oil breather. |
A spark plug wire clip goes in there. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
