NOS mint green fan plug?
OvalinAz
Samba Mini Tech
OvalinAz is offline
PostPosted: Sat May 07, 2016 1:55 am    Post subject: NOS mint green fan plug? Reply with quote
I found this at the last bug o Rama here in AZ, it's a bag (probably not original Vw) but I have never seen a an plug other than black. This one hasn't ever been mounted either. Any info on this? The part # 311 105 383 like the other black plugs I have seen.
Thanks for any help!
Dad's 4/55 Oval
8/56 Oval
5/64 French Notchback
12/62 French 11 Window Bus
1970 Subaru 360
Wedge VW
Pandraggers C.C.
ataraxia
ataraxia is offline
PostPosted: Sat May 07, 2016 6:02 am    Post subject: Re: NOS mint green fan plug? Reply with quote
It's an original part - not sure when they changed to black - I've got a few of them. Not uber rare but nice to have if you've got an early car.
PostPosted: Sat May 07, 2016 8:10 am    Post subject: Re: NOS mint green fan plug? Reply with quote
I've seen a few too but not sure why some were a different color.
There are definitely a ton more black ones.
I think I have a used one stored away somewhere, saved just because it wasn't black.
raygreenwood
raygreenwood is offline
PostPosted: Sat May 07, 2016 9:44 am    Post subject: Re: NOS mint green fan plug? Reply with quote
Have you ever noticed a fit difference between the different colors? If so...that can many times explain a difference in why they change colors on a part whose color otherwise does not matter for its function.
It varies on plastic type...but all thermoplastics have some of this issue...the more pigment/colorant additive that is added by percentage to make a color....the higher the shrinkage rate after cooling when it comes out of the mold.
It takes a LOT more colorant to make white or light colors in plastics (typically titanium dioxide or calcium as the whitening agent).....than it does to color something with carbon black. There is less "collapse" after injection molding.
We see this all the time in over adding colorant as well. For instance with many red colorants....say with polypropylene and polyethylene (which is probably what that plug is made of).....a red plug would require only about 2% colorant. Adding 3%, 5% or 8%...does not make the plastic any more red or any deeper red.....but when overloading...you see shrinkage rates that are measurable.
Light colors like that mint green....are mostly white. Ray
PostPosted: Sat May 07, 2016 11:19 pm    Post subject: Re: NOS mint green fan plug? Reply with quote
When I got it I didn't notice any difference between the 2 plugs as I do remember comparing them.
If I can find it again I will double check, if I have a black one here too.
raygreenwood
PostPosted: Sun May 08, 2016 7:12 am    Post subject: Re: NOS mint green fan plug? Reply with quote
You may or may not find a difference. A,skilled molder can usually get around it. But there are a handful of reasons that are just simpler and cheaper to move to black plastic.
Ray
ataraxia
ataraxia is offline
PostPosted: Sun May 08, 2016 7:14 am    Post subject: Re: NOS mint green fan plug? Reply with quote
Totally subjective, but I found the lighter colored cap harder to remove after being installed on the same pulley.
PostPosted: Sun May 08, 2016 9:56 am    Post subject: Re: NOS mint green fan plug? Reply with quote
For reference, here's an NOS black one I posted some time ago:
The part # has a "5" after it instead of a "1" but I don't know if that means anything other than a production run #.
Here are some more I had in the past and the last # varies and there is one with a "1" like the green cap:
Here's the green one I used to have but I can't read the full part #s there and could not find a larger version:
rustyfastback
rustyfastback is offline
PostPosted: Sun May 08, 2016 4:02 pm    Post subject: Re: NOS mint green fan plug? Reply with quote
I have one green cap. It came from a early september '65 euro 1966 squareback. I have only seen one other one other on a engine & it was out of a '66 also. Maybe the early '66 1600 motors were coming off the line while the factory still had some 1500-S motors & the green cap noted a 1600 engine.
ataraxia
ataraxia is offline
PostPosted: Sun May 08, 2016 4:10 pm    Post subject: Re: NOS mint green fan plug? Reply with quote
I had a late 65 Variant S model with the green cap - the car had never been apart and the engine was original to the car. My early 64 also had one but I'm pretty sure that engine was rebuilt - although not much of a reason to replace the cap unless it was broken.
Tram
Samba Socialist
Tram is offline
Everyone is saying these caps are light green, but they look light blue to me both on the monitor and here in person.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
D/A/N
D/A/N is offline
PostPosted: Sun May 08, 2016 6:04 pm    Post subject: Re: NOS mint green fan plug? Reply with quote
The only one that looks greenish to me is the one in Everett's post. The ones in the original post look perfectly white. I thought the OP was hallucinating a little. Though I ordered a seatbelt retractor from Wolfsburg West and it's actually greenish, not pure white. I wonder what it is about white plastic???
raygreenwood
PostPosted: Mon May 09, 2016 10:18 am    Post subject: Re: NOS mint green fan plug? Reply with quote
Don't get me started Laughing ....I work with color, color management and standards....and spend a lot of my time training people to work with color. Its hard getting people to understand what makes color.....and white and black are the tow hardest for people to grasp the reality of.
The pigments that make white plastic white are the same pigments that are used to make paints, inks dyes etc...white.
Its not just white plastic...its white ANYTHING. Bear in mind...white is not white just like red is not red and blue is not blue. The pigments are filters.
White light (sunlight) contains all colors of the spectrum. A substance that appears blue to your eye is one that absorbs all other light spectrum that hits it and only reflects the blue range to your eyes.
Along those same lines....white pigments appear white to your eye because there is at a molecular level a wide range of color reflecting agents within any of the known white pigments.....so it reflects the entire range of spectrum of white light back to your eye...so you see white.
Because of that wide range of color reflectivity...and the fact that white pigments are organic...mined out of the ground largely....they can be contaminated or tweaked in many ways.
A white plastic or paint etc....can take on a hue (exact color)....that ranges all over the rainbow from something as small as an oil smudge on the surface acting as a filter...to microscopic contaminants in the pigment or polymer base during molding...all of which act as a filter to absorb one slice of the light spectrum or another....causing a color shift.
Bluntly put....white plastic, inks, paints etc.....will NEVER, NEVER, NEVER be exactly the same way twice unless they are mixed from the same pigment batch and are using the same base polymers and solvents from the same batches.
The color differences can be from subtle to huge. White is THE hardest color to reproduce in any industry.
Not even to mention ....if you are viewing a white molded part...or painted or powder coated part...under varying lighting. Since white reflects back the spectrum of white light....iif your light source is "less white"...say if one is looking at it under 5200K lighting compared to 6500K lighting....the 5200 will appear about 10% more blue...while 6500 can make it look more greenish or yellowish.
Ray
