crankshaft pulley removal
VWest77
VWest77 is offline
PostPosted: Tue Jun 28, 2011 6:12 pm    Post subject: crankshaft pulley removal Reply with quote
Is there a way to take off the crankshaft pulley, without the puller tool? I've been looking around, but can't find any information on this.
Thanks!
1973 Thing 1600 T181
1963 Double Cab
JonF
JonF is offline
PostPosted: Tue Jun 28, 2011 6:18 pm    Post subject: Reply with quote
3 jaw gear puller should work to get it off after you get the bolt off of it.
68 bug 1600sp 30/31
68 baja 1600sp 010 32ndix
Revelen
Revelen is offline
PostPosted: Tue Jun 28, 2011 6:19 pm    Post subject: Reply with quote
And when you put it back, it shouldn't be flush. Don't warp it all to hell trying like I just did!
I probably have no idea what I'm talking about. That's honesty, not shrouded modesty. No, really.
benny27
benny27 is offline
PostPosted: Tue Jun 28, 2011 6:43 pm    Post subject: Reply with quote
I have taken mine off with a pry bar behind the pulley. I would pull and then rotate the motor and slowly worked it off. the motor was in the car or I would of used a 3 jaw puller.
VWest77
VWest77 is offline
PostPosted: Tue Jun 28, 2011 6:45 pm    Post subject: Reply with quote
Yeah I have the bolt out... just wondering if there is a way to get the pulley off (mine is warped), without using a puller tool. I have very limited access to tools... so looking to macgyver something.
1963 Double Cab
cletus_zuber
cletus_zuber is offline
PostPosted: Tue Jun 28, 2011 7:21 pm    Post subject: Reply with quote
I had a real stuck one, used the John Muir method, 2 big screwdrivers with engine standing on the flywheel, popped it right off.
Smear some anti sieze around when you re-install
HPMX 40's & 019
jlex
jlex is offline
PostPosted: Tue Jun 28, 2011 8:20 pm    Post subject: Reply with quote
I was watching the bug me video on engine tear down. They used either a two screwdriver method or just got one screwdriver & hammered on it where the pulley meets the crankshaft to get it off.
jlex.
'70 std. "Elsie"
'88 Carrera
VWest77
VWest77 is offline
PostPosted: Tue Jun 28, 2011 8:49 pm    Post subject: Reply with quote
That sounds like it would be good to watch... do you know which video it was?
1963 Double Cab
VWest77
VWest77 is offline
PostPosted: Tue Jun 28, 2011 9:53 pm    Post subject: Reply with quote
Might be heading to the city tomorrow... Do you think this would work?
http://www.princessauto.com/workshop/hand-tools/au...ear-puller
1963 Double Cab
alexvw
alexvw is offline
PostPosted: Tue Jun 28, 2011 10:25 pm    Post subject: Reply with quote
It would work yes but if it is already warped and if you are replacing it, why be afraid of bending it up. Get 2 prybars or screw drivers and go back and forth and work it off. Try that first before buying a tool. Cool
1995 Mitsubishi 3000GT SL
1974 Volkswagen Superbeetle( Mitsubishi 4G63T Swap in Progress )
http://www.thesamba.com/vw/forum/viewtopic.php?t=575769&highlight=
VWest77
VWest77 is offline
PostPosted: Tue Jun 28, 2011 10:54 pm    Post subject: Reply with quote
Yea, that's what I thought... but I was reading Rob and Daves write up, and they said Do Not Pry Pulley... because it can cause damage to more then just the pulley.
1963 Double Cab
alexvw
alexvw is offline
PostPosted: Wed Jun 29, 2011 12:36 am    Post subject: Reply with quote
Yes it can if you are not careful. They are probably talking about the tin getting bent. The call is up to you. Just an idea
Lettuce
Lettuce is offline
PostPosted: Wed Jun 29, 2011 12:44 am    Post subject: Reply with quote
you can damage the bore in the case and then the pulley will always leak. The pulley needs to be pulled straight off, like with a puller
Joel
Joel is offline
PostPosted: Wed Jun 29, 2011 12:46 am    Post subject: Reply with quote
I removed my stock one years ago to fit an degreed pulley.
With the engine in the car there is not enough room to put pullers on there.
there is a factory puller tool which fits but not many of us have one of them laying in the bottom of the tool box.
I got mine off with a slide hammer.
Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
gooser
gooser is offline
PostPosted: Wed Jun 29, 2011 1:57 am    Post subject: Reply with quote
x2
ashman40
ashman40 is offline
PostPosted: Wed Jun 29, 2011 7:32 am    Post subject: Reply with quote
I have a suggestion but there is some risk to the #1 crank bearing (thrust bearing). So decide if you want to try it.
Since your pulley is damaged this may be one of your only alternatives if you can't fit any other options.
First, spray penetrating oil on the mounting area of the pulley. Allow time for it to soak in.
Using the plastic handle of a large screwdriver, tap the front side of the pulley toward the rear (removing)... While you simultaneously pull on the opposite side. You are tapping and pulling towards the rear. Each tap should move the pulley a very small amount as it is a tight friction fit. It could take a while but you are trying to tap the pulley off a little at a time. You want it to come off as straight as possible.
If you are not concerned with saving the pulley you can use a metal bar or small hammer to tap the pulley. The impact of metal to metal will create a sharper impact and result in more energy being transferred, but you could easily bend the thin metal of the cheaper pulleys.
The impact to the thrust bearing is much smaller than you are applying to the pulley because the flywheel and crank have a very large mass (large inertia) relative to the pulley and hammer.
As mentioned, there is a bit of risk when using this technique but you asked for "MacGyver methods". Use at your own risk.
AshMan40
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Wed Jun 29, 2011 8:30 am    Post subject: Reply with quote
Sure synch you boys have never lived on a farm !
No (1) soak it with blaster for two days-- read it a weep -- two days - hit is several times -- blaster nothing else!
Wipe it down
(2) Heat just the pulley with an oxyacetylene torch.
When you do this the pulley gets larger and crushes the rust - works everytime!
Now ya have to not be an idiot when you do this- if you heat it too much you will warp the pulley - if you heat it to little and to slow the nut gets hot and you have done nothing.
Then let it cool - add more blaster -- hold an ice cold rag on the pully then you can damn near take it off by hand
Experience always triumphs over hearsay and You get to select which theory to believe
jlex
jlex is offline
PostPosted: Wed Jun 29, 2011 12:59 pm    Post subject: Reply with quote
I think it was #3 Engine Rebuild...
But just the same, I'm sure the pulley is safer if it puts up any resistance!
jlex.
jlex.
'70 std. "Elsie"
'88 Carrera
alexvw
alexvw is offline
PostPosted: Wed Jun 29, 2011 6:10 pm    Post subject: Reply with quote
Yes if you are seriously prying on the thing. But if you wiggle it back and forth gently, it will work its way off and come off.
VWest77
VWest77 is offline
PostPosted: Thu Jun 30, 2011 3:31 pm    Post subject: Reply with quote
So I did pick up the previously mentioned Princess Auto gear puller... didn't realize it was only a 3"... I don't think it'll span the width of the pulley... but maybe it can fit in the notches though?
I'm currently travelling, and will be back at the Beetle on the weekend, but only have an afternoon and then have to be driving it... so I want to make sure I have everything I need.
If I can't get pullers I'll use the methods suggested above. Thanks for everyone's input!
Peace.
1963 Double Cab
