Weber ICT Balance tube
Paul Wilson
Paul Wilson is offline
PostPosted: Sat Jul 09, 2011 5:21 pm    Post subject: Weber ICT Balance tube Reply with quote
I am very aware that the dual single barrel carbs need a balance tube. My 66 Squareback has one and is is a single port engine. Do dual port engines need another balance tube ? Is there any advantage to using two balance tubes? Front tube for 1 & 3 cylinders and a tube in the rear for 2 & 4 cylinders? Has anyone tried this?
uglyoffroader
Erik G
Erik G is offline
PostPosted: Sat Jul 09, 2011 7:07 pm    Post subject: Reply with quote
yes it needs one. maybe even more so than a single port. Never tried running more than one
Paul Wilson
PostPosted: Sun Jul 10, 2011 7:29 am    Post subject: Reply with quote
Yes, I knew dualport engines need one, I just wanted to knoe if anyone had used two balance tubes.
uglyoffroader
mxracer
mxracer is offline
PostPosted: Sun Jul 10, 2011 7:45 am    Post subject: Reply with quote
Don't know if they NEED dual balance tubes but I'm assuming it does help. The dual carb 71 models (I'm assuming European) had dual balance tubes from the factory according to the Henry Elfrink manual I have. I thought about doing it to mine as well.
Mike Fisher
Mike Fisher is offline
PostPosted: Sun Jul 10, 2011 8:05 am    Post subject: Reply with quote
The single balance tube on dual port engines is hooked to the intake manifolds not the carburetors. Dual balance tubes sounds redundant/unnecessary.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Paul Wilson
PostPosted: Sun Jul 10, 2011 8:09 am    Post subject: Reply with quote
You are right, the tube does connect to the manifold. But on the dual port manifolds it would only balance the no. 1 and 3 cylinders and not the no. 2 and 4 cylinders?
Mike Fisher
PostPosted: Sun Jul 10, 2011 12:24 pm    Post subject: Reply with quote
I would think that the vacuum probably draws all the way into the sump and all 4 cylinders end up equal? Think
Bobnotch
Bobnotch is offline
PostPosted: Sun Jul 10, 2011 1:44 pm    Post subject: Reply with quote
If you look at the dual port manifold, you'll see that it's pretty open up near where the carb attaches. That's where it gets it's vacuum from the 2-4 side of the manifolds. Yes, the vac signature is probably stronger on the 1-3 side of the manifold, but it does balance out. On the OE VW manifolds, they pull vacuum from the center of the manifold, so it's more evenly spread out between the 2 cylinders on each side.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Slow 1200
Slow 1200 is offline
PostPosted: Mon Jul 11, 2011 12:21 am    Post subject: Reply with quote
having an euro '71, I don't think the dual balance tube make a big difference (it surely does make vacuum leaks more likely!), actually they only used them for part of the year and then went back to a single balance tube (but still taking the vacuum from the 4 ports)
Now I don't remember if in my car vacuum to the modulator for the trans is taken from the 1-3 or the 2-4 tube, I'll check just out of curiosity
Root_Werks
Root_Werks is offline
PostPosted: Mon Jul 11, 2011 7:50 am    Post subject: Reply with quote
If you have single/dual carbs, you want to run a balance tube. If you have dual/dual carbs, you don't.
Wink
Dual ICT's - The balance tube should be hooked to the threaded part on the manifold that grabs vacuum from both intake ports. It's just under the flange the carb bolts to. So no need to have multiple balance tubes.
When I set my timing, why do I flush, then take a pee?
Bobnotch
Bobnotch is offline
PostPosted: Mon Jul 11, 2011 3:25 pm    Post subject: Reply with quote
I had a set of VW manifolds here that had a plastic "F" connecting the 2 ports on each side with a single outlet. I suppose you could have used 2 hoses to tie both sides together (run 2 balance tubes) if you wanted. But my thought is that it would look more crowded with the extra hose in there. Wink
On my wife's Fastback (back when it had carbs), the AT modulator was connected to the balance pipe that tied both sides together.
Tram wrote:
Tram wrote:
