sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4030 Location: Deep In My Own Psyche
Posted: Sat Sep 10, 2011 9:00 pm Post subject: Universal Case hard to turn Even without pistons and.... |
my 67 fasty
its got a universal case engine
was Frozen...?
took heads off and thought i got it loose
which i did
put it back to gether and same thing!
Can Not turn by hand or screw driver pry...
i have taken off heads, piston heads, barrels
And STILL Hard to turn
all parts look Brand New
No particals in the oil...
i have looked inside and everything Is Super Clean!!
i dont get it
with it in the car its tough enough that i can get the fan bolt loose
out of the car i have to hold on to it Hard and turn it
i get maybe an inch of easy back and forth movement
BUT then....
should i just put my good starter in it and try to crank it over??? _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote: |
Extremity is relative to how far your willing to jump |
Ward Cleaver wrote: |
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
supaninja Samba Member
Posted: Sat Sep 10, 2011 11:59 pm Post subject: |
spun?
like one on top of each other?
wouldnt that mean a loose rod or worn crank?
engine is short block, no piston heads
and i can move the rods freely
my thought was a tight fan? maybe an main bearing _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
PS4 "NKOGNEATO" |
Willo357 Samba Member
Joined: August 05, 2010 Posts: 483 Location: Melbourne
Posted: Sun Sep 11, 2011 12:40 am Post subject: |
it could well be that the main bearings are misaligned (usually caused by overheating)
I had an engine like that. when i tried to torque the main case bolts the crank would get tight at some spots. it can be fixed by line boring the case but my case was cracked so i just put less torque on them and built the engine. (i'm not recommending this) but i thought i would do an experiment.
i recently took that engine apart after 5000+miles and all seemed well... actually the main bearing bolts were quite tight.
i would split the case and have a good measure around. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22435 Location: Kimball, Mi
Posted: Sun Sep 11, 2011 8:40 am Post subject: |
sharkskinman wrote: |
and i can move the rods freely |
With the heads, pistons and cylinders off, can you still spin the engine over easily? It should. If not, then you need to split the case and find out why. It's possible that the dowels aren't in the correct spot with the main bearings (wouldn't be the first time that happened). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1290 Location: roseville, ca
Posted: Sun Sep 11, 2011 8:55 am Post subject: |
Is the distributor in? If not, the drive gear will pop out and bind on the crank.
Have you checked the end play? |
Posted: Sun Sep 11, 2011 9:20 am Post subject: |
thats what i was saying
its a short block and still hard to turn even tho Everything is Super Clean...
im not splitting it!..not the tools or the know how
atleast not now
Im just trying to get it to run to put it on a truck
might just put T1 in it till its out in Cincy.. then deal with it
going to have someone run by and pick the short block up and see whats what hopefully monday _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
PS4 "NKOGNEATO" |
BearBroth Samba Member
Joined: May 11, 2004 Posts: 142 Location: San Antonio TX. (just north of Hades)
Posted: Sun Sep 11, 2011 11:07 am Post subject: |
...This might be a "duh" moment here but... are you sure the oil slinger on the snout of the crank is facing the right direction? If this is facing the wrong way... it will cause all of the above and it's the easiest to overlook (good news: this is the least catastrophic of problems you may have. bad news: you still have to split the case to correct it ).
I haven't heard anyone mention this yet so I figured I'd throw it out there. Good luck!
The slinger is the big washer-looking thing about an inch behind the crank pulley bolt. Please note that it is dished towards the bolt. If dished towards the flywheel end of the crank, it will lock up the engine. The engine CAN be assembled this way although you'd have to be determined to do things wrong cuz it will fight you.
_________________ "It is possible to store the mind with a million facts and still be entirely uneducated."
- Alec Bourne |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Sun Sep 11, 2011 11:42 am Post subject: |
With the heads and pistons off it should turn effortlessly.
If not the bottom end needs to be rebuilt...
...or you can use it as a boat anchor. _________________
modok wrote: |
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold |
Posted: Sun Sep 11, 2011 11:04 pm Post subject: |
Quote: |
Also if the engine got over heated the case might have warped and needs align boring. I agree with josh, it should spin effortlessly, case needs to be split |
i mentioned this earlier but seems to have been ignored.
splitting the case requires nothing fancy. just a 13mm and it memory serves me correctly a 17mm socket. if all you want to do is get it to turn over just back off the 6 main bearing nuts a bit and it will free up.
if you have torn it down to the short block then you may as well keep going. |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Tue Sep 13, 2011 2:15 pm Post subject: |
Shark you need to split the case, that engine will implode in a very short amount of time if you try to run it that way, split the case and find out whats wrong , by some permatex aircraft sealant for reassembly if things can be put back together.. or find another short block in good shape... but you aint going to far if you run it like that bro!
-Trevor _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Tue Sep 13, 2011 7:11 pm Post subject: |
it won't run at all... if you can't turn it over with a wrench, it will never spin over enough to start... _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Farfromstock Samba Member
Joined: January 27, 2006 Posts: 161 Location: anaheim,ca
Posted: Mon Mar 12, 2012 7:54 am Post subject: |
Someone might have pinched the main bearings with the dowel pin causing it to be tight. If it was pinched main bearing will need replacing. Also bad bore will cause it even with new bearings. |
