74 super tranny into 71 mexi?
wizcleland
wizcleland is offline
PostPosted: Mon Oct 21, 2013 5:25 pm    Post subject: 74 super tranny into 71 mexi? Reply with quote
Hey all,
can pick up a 74 super beetle tranny cheap. Would it fit into a 71 mexican beetle? Swing arm (link and king front end), like a pre 67 american or canadian?
Will the axles and tubes etc swap over? any bolting in issues?
Thanks guys!
something so self assuring drving home and having people give you the thumbs up sign. yeah, may be the car but the car was my decision too.
Bruce
Bruce is offline
PostPosted: Mon Oct 21, 2013 6:36 pm    Post subject: Reply with quote
It will only fit if you convert your Mex Beetle to IRS.
SgtSamy
SgtSamy is offline
PostPosted: Mon Oct 21, 2013 7:26 pm    Post subject: Reply with quote
I highly suggest you to find another swing axle tranny. The conversion from IRS to swing axle is way too much work for what its worth.
At the moment owner of:
1968 Mex Beetle
wizcleland
PostPosted: Mon Oct 21, 2013 7:54 pm    Post subject: Reply with quote
after hunting some more i found if the irs tranny has bolted covers both sides (and it does) you can basically swap out (or maybe sourch new) the diff etc parts (if ok) from the old swing into it, set it up and carry on as a swing. Will probably let the tranny shop do it. Might be a pain but the IRS tranny is a fresh rebuild, never in and dirt cheap. Worth futzting with over the winter. considering my reverse has now become not much more than a noise maker. More than likely due to it being totally empty when i bought the car, who knows how long t was driven like that....
Bruce
Bruce is offline
PostPosted: Tue Oct 22, 2013 6:03 pm    Post subject: Reply with quote
wizcleland wrote:
.... if the irs tranny has bolted covers both sides (and it does) you can basically swap out ....
This means the IRS gearbox you have is NOT from a 74 Super.
If you want to try to swap your swing axle diff parts into this IRS gearbox, first you must determine if your swing axle diff is 6 bolt or 8 bolt. IRS only used 8 bolt.
