Type IV flywheel
trackwesty
trackwesty is offline
PostPosted: Thu Mar 17, 2005 8:15 pm    Post subject: Type IV flywheel Reply with quote
It seems that the flywheel I have installed on the 2.0L is a 228mm clutch and wont fit the bell housing of the trans without heavy grinding to clearance for the large clutch plate. Kennedy Engineering offers a 200mm flywheel that will work allowing for the less expensive and readily available beetle heavy duty clutches. But I am very cheap can a type I flywheel be modified to work on the type IV motor.
I hope everyone is having a great St. Patty's day
AKA The Mummy
ratwell
ratwell is offline
PostPosted: Thu Mar 17, 2005 8:25 pm    Post subject: Reply with quote
trackwesty wrote:
IKennedy Engineering offers a 200mm flywheel that will work allowing for the less expensive and readily available beetle heavy duty clutches.
That will work but you may need a heavy duty pressure plate which means a heavy pedal and there is no slave unit on your transmission to assist.
You'd have to modify the crank to accept the glandnut...if possible the cost would likely be more that locating a core Type 4 flywheel that would fit your transmission.
'78 Westfalia CDN
'76 Doublecab Sweden
Read the Baywindow FAQ
jberger
jberger is offline
PostPosted: Fri Mar 18, 2005 12:40 pm    Post subject: Reply with quote
Do you have an 091? If you have an 022 you can swap the bell housing for an 091 to fit your 2.0 flywheel.
trackwesty
PostPosted: Fri Mar 18, 2005 11:32 pm    Post subject: Reply with quote
I will look into the bellhousing solution. Is there any help you can give to identify which bell housing I have and how do I verify a used 091 when at a wreaking yard?
AKA The Mummy
Randy in Maine
Randy in Maine is offline
PostPosted: Sat Mar 19, 2005 5:10 am    Post subject: Reply with quote
If you already have the 228 mm flywheel, clutch and starter for the 76-79 2.0 engine, then do the bell housing or transmission swap.
If the PO switched it to a FI engine (that isn't there anymore) it may have been anything in there. Make sure the starter works with the flywheel.
If you don't have that stuff, just use a 210 mm flywheel, clutch and starter for your 72 02 transaxle.
trackwesty
PostPosted: Sat Mar 19, 2005 9:18 pm    Post subject: Reply with quote
The car was purchased without a trans or motor. It looked like at one time the FI conversion had taken place. I picked up what I thought was the correct trans(seller said it would work) for a engine 2.0L a friend was letting go for $150 (no F.I. included) now I am trying to make it all fit and work. I have a starter that came with the trans and has been rebuilt.
Now about the bell housing, any ideas on how to identify the correct one?
Much thanks all
AKA The Mummy
ratwell
ratwell is offline
PostPosted: Sat Mar 19, 2005 11:30 pm    Post subject: Reply with quote
On the inside will be a part number starting with 091:
http://homepage.mac.com/ratwell/.Pictures/Engine5/50-MagneticPlug.jpg
'78 Westfalia CDN
snydlywhiplash
snydlywhiplash is offline
PostPosted: Mon Feb 23, 2009 9:12 am    Post subject: 1980 auto to manual converstion Reply with quote
hey folks.... i am putting in a new engine that has an auto on it. and my van is origanly a manual. just wondering what i will need to make this converstion. flywheel? size.. and or anything else i may need.. thanks
Wildthings
Wildthings is offline
PostPosted: Mon Feb 23, 2009 9:17 am    Post subject: Re: 1980 auto to manual converstion Reply with quote
We would need a bit more information to be able to give you any meaningful help. What year, what engine, what tranny will you be running?
norcalmike
norcalmike is offline
PostPosted: Mon Feb 23, 2009 4:18 pm    Post subject: Reply with quote
Holy old thread hijack, batman!
enjoispammy8
enjoispammy8 is offline
PostPosted: Mon Feb 23, 2009 4:21 pm    Post subject: Reply with quote
seriously! why not start a new thread!
1969 Westy, 1690cc. montana red and cloud white.
1969 Standard Beetle [sold]
Watch My Movies: https://www.youtube.com/user/taylorlikesacdc
Desertbusman wrote:
Is there a message here? Enjoy Spammy Ate
EZ Gruv wrote:
Way to fuck up some little kids riding in the car next to you.
hazetguy wrote:
you need to be doing better drugs.
View user's profile Send private message Send e-mail AIM Address Facebook Gallery Classifieds Feedback
brotha bran
brotha bran is offline
PostPosted: Mon Feb 23, 2009 4:52 pm    Post subject: Reply with quote
1 post @ the Samba and he's already hijacking. they start them younger and younger each day.. Rolling Eyes
but yeah. probably deserves it's own thread, you'll get more useful responses that way.
1976 Transporter "Betsy" [Reef Blue, Rebuilt 2L w/ Raby CS heads, 010 Auto. ]
1968 Single Cab "Neptune" [Neptune Blue, stock, stock, stock]
airkooledchris
airkooledchris is offline
PostPosted: Mon Feb 23, 2009 6:26 pm    Post subject: Reply with quote
gotta give a 1st time poster credit for using search to ask questions tho...
usually we aren't bashing a new user for hijacking an old thread, rather for starting a new thread Vs using search and posting back to an existing one on a related issue.
to the new poster - you do need to provide a lot more info if your workings aren't exactly the same as the original posters in this thread.
Tcash
Tcash is offline
PostPosted: Tue Sep 12, 2017 6:30 am    Post subject: 210 - 228 mm Type 4 Flywheel Reply with quote
