How does 2wd fuel filler attach to gas tank?
SCM
SCM is offline
PostPosted: Tue Apr 10, 2012 2:08 pm    Post subject: How does 2wd fuel filler attach to gas tank? Reply with quote
The diagrams I've seen make it look like it just slides in with no clamps etc to hold it (or the seals) tightly together with the tank. That doesn't seem right. How do you reinstall the filler neck after replacing a gas tanks?
Thanks
'91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
presslab
presslab is offline
PostPosted: Tue Apr 10, 2012 2:15 pm    Post subject: Reply with quote
Yes, just slide it in. There is a large rubber grommet that seals it. I lubed it slightly with grease and it went in no problem.
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
westfailed
westfailed is offline
PostPosted: Tue Apr 10, 2012 2:26 pm    Post subject: Reply with quote
Oh geez that's just aching for a double entendre.I love this forum Very Happy Very Happy
PacificSticker
PacificSticker is offline
PostPosted: Tue Apr 10, 2012 2:29 pm    Post subject: Reply with quote
^ yup. You kinda just steer it into place to clear the expansion tanks and then back it out a bit and twist to line up the 3 screws. Works a treat.
1989 Wolfsburg T3 Whitestar 2.1 WBX
Libelle
Damon in Ventura
r.e.wing_fc3s
r.e.wing_fc3s is offline
PostPosted: Tue Apr 10, 2012 7:32 pm    Post subject: Reply with quote
push it in past the point where you think it cant go any deeper, to the second ring. use plenty of silicone spray. slowly remove while rotating as posted above.
Reference Automotive: NW Washingtons Vanagon Specialist. (360)366-6965. referenceautomotive.com
floggingmolly
floggingmolly is offline
PostPosted: Tue Apr 10, 2012 8:27 pm    Post subject: Reply with quote
that's what she said...
'85 Wolfsburg Weekender
windnsea
windnsea is offline
PostPosted: Wed Apr 11, 2012 12:20 am    Post subject: Reply with quote
Make sure that you have the proper tank gasket for your filler - earlier and later sizes are different.
SCM
SCM is offline
PostPosted: Fri May 25, 2012 1:32 pm    Post subject: Reply with quote
OK, that will take care of the fuel tank end of things. How do I release the neck from the body in order to get the play I need to move it around? I have a plastic filler neck and I think I read somewhere that it doesn't have the 3 screws? Does the part of the filler accessable from the outside of the body (where the gas cap goes) have to be removed or does the neck disconnect from beneath the vehicle/inside the wheel well?
Thanks for the help. With snow in the forecast (and currrently on my lawn) this seems like the perfect time to replace and reseal my leaky rusty tank.
PacificSticker
PostPosted: Fri May 25, 2012 2:38 pm    Post subject: Reply with quote
Remove the gas cap, remove the 3 screws, (may need to loosen the expansion tank) twist the (filler neck) night away
Libelle
Damon in Ventura
pinealservo
pinealservo is offline
PostPosted: Fri May 25, 2012 3:00 pm    Post subject: Reply with quote
Don't skimp on the lube! If it's not lubed well enough, the gasket/grommet will prefer to stay with the filler neck instead of the hole in the tank it's meant to be sealing as you pull the filler back to its place on the body. If that seal isn't good, you'll have a rusty tank again before too long.
I think I had to drop my new tank 2 or 3 times to retrieve grommets and gaskets that dropped in due to insufficient lubrication. Not very fun!
