New VW (Volksrod) owner from northern NJ
jipple28
jipple28 is offline
PostPosted: Wed May 30, 2012 4:31 pm    Post subject: New VW (Volksrod) owner from northern NJ Reply with quote
*Warning, this thread is not suggested reading material for the VW purists. This is my project and it only needs satisfy me.*
Howdy,
I recently bought my first project bug; a 1966 body (partially chopped) on a 1962 tub. I bought it from a guy in Idaho who had to move and was unable to take it with him. The tub is beautiful from what I've seen in photos and been told by the seller. It left ID on 5/27 is scheduled to arrive in NJ sometime tomorrow, 5/31.
Here are the specs and links to the photos I have at this point:
-4" chopped out of the roof
-brand new custom ragtop slider
-59 oval window to be installed
-suicide door hinges with a shaved door kit and bear claw door latches.
-two sets of doors, extra roof for donor metal
The pan has a 4-wheel disc brake conversion, mounted tranny with all smooth welds. All the hardware is plated. The pan also has 3/4" square tubing welded along the bottom of the floor boards and a solid flat piece of sheet metal along the bottom. When you look at the bottom it is completely flat and looks so sweet. The whole pan/tranny is painted a powder purple (Dodge Neon color).
I will be continually adding photos of this project to my photo set on Flickr:
http://www.flickr.com/photos/jpl3k/sets/72157629775140468/
I plan on purchasing a Corvair 110 or 140 and the necessary adapter plate, flywheel, clutch and expose it out the rear. My thought is to 'flip' the front beam instead of installing a beam extender, but I need to read up on that a little more. I'll run no fenders, no deck lid, drop it front and rear, taller tires on the rear (nothing wide).
Although I do not intend to replicate it by any means, I am taking a lot of styling from Drew Strunk's KDF Mangler:
http://www.speedhunters.com/2010/09/interview_gt_gt_drew_strunk_on_the_kdf_mangler/
I am entirely new to VWs, so this is very much be a learning experience while building, but I look forward to the challenge and expect to drop in with updates and question quite often.
Thanks all,
Jonathan "JPL"
lovethatconvertible
lovethatconvertible is offline
PostPosted: Wed May 30, 2012 4:35 pm    Post subject: Volksrod Reply with quote
Cool, But shouldn't this be in Readers Rides instead?
jipple28
jipple28 is offline
PostPosted: Wed May 30, 2012 4:46 pm    Post subject: Re: Volksrod Reply with quote
You're probably right, but I can't delete it now.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed May 30, 2012 4:48 pm    Post subject: Re: Volksrod Reply with quote
Moved
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
lovethatconvertible
PostPosted: Wed May 30, 2012 5:19 pm    Post subject: Reply with quote
Welcome to your new location, Anyway you should check out this thread, it will provide some inspiration. he's been there done that on the Corvair Engine and worked out a lot of the bugs. It's a good read. Keep us in the loop, and pictures are always fun.
http://www.thesamba.com/vw/forum/viewtopic.php?t=466290
ovalshark
ovalshark is offline
PostPosted: Wed May 30, 2012 10:41 pm    Post subject: Idaho rat Reply with quote
Cool project, is it the one from Mountain home? If I dig deep enough, I swear I have a pic of the red and white puzzle car in the Twin Falls, Id. car show in around 1991. Enjoy and good luck!
jipple28
jipple28 is offline
PostPosted: Fri Jun 08, 2012 7:06 am    Post subject: Re: Idaho rat Reply with quote
Thanks lovethatconvertible, I have seen that thread and am sure it will come in handy.
Yes, this is the project from Mountain Home, ID. I have the puzzle-piece doors and top. I'd love to see the puzzle VW before it was cut to bits.. if you can find the pic please send to me! The previous owner is a great guy and we've been corresponding throughout my progress. Since he's now on the east coast I hope to meet him and let him see it when it's complete.
Update:
This week has been nothing but rainy evenings so I've been chopping and tack-welding primarily in no more than a square foot perimeter in the garage. We have 3 cars in a standard two-car garage; a 1960 MGA and a chrome-fitted 1977 MGB.
MGA: http://www.flickr.com/photos/jpl3k/s...7600871360867/
MGB: http://www.flickr.com/photos/jpl3k/s...7606255623123/
Last night the weather was mostly clear so I got to work outside -see new pics on Flickr.
http://www.flickr.com/photos/jpl3k/s...7629775140468/
I lowered the top an additional 1 1/2" and tack-welded parts of the roof at the new height. Also chopped the front and rear aprons off to make a little more room in the garage (they both had to go in the final project regardless).
Figure this is roughly a 5 1/2" chop, but won't be sure until its all in place in the end and I can take definitive measurements. I tell ya, it's not easy chopping more out of a top after it has already been done once.. but I knew it wouldn't be. Keep in mind this is my first time doing anything like this, so I'm still fighting the learning curve.
More to come tonight.. even though it's supposed to rain again! Mad
BTW guys, I'm on Facebook and tend to upload photos and updates there as I make progress, so if you're on send me an invite and let me know you're a Volksrod/VW guy.
www.facebook.com/VacuumTubeCowboy
-JPL
jipple28
jipple28 is offline
PostPosted: Mon Jun 11, 2012 11:56 am    Post subject: Reply with quote
This past weekend I didn’t have a ton of time to work on the VW, but I pretty much finished tacking the A & B pillars and three roof extensions above the driver door, windshield, and passenger door. Added roughly 3” of extensions, but had to cut the roof lines straight first, so it was actually a little less than 3”. Still have to complete the rear extension, C pillars, oval window graft, and find an original 3-fold ragtop slider clip.
Pics prior to installing the hood:
Picked up the hood for the front and started lightly sanding spots wherever rust discoloration was present. The tip of the nose is rough, but nothing that I can’t cut and weld to smooth out. I don’t think I’ll need replacement pieces or anything to repair it. The rest of it is very solid and it bolted on perfectly; just a couple minor dings and nasty-looking spiders crawling around here and there.
I also met a guy locally who used to rebuild Corvairs and picked up a clean set of 140 heads, six jugs, four primary carbs, and the carb linkages. All need cleaning, but not excessive work. I’m waiting on the [rebuilt, running] ‘69 110 engine, but expect to have that real soon. Still need reverse camshaft, distributor gears, alternator fan, flywheel, clutch, and adapter plate for the transaxle. Also need the ragtop slider clip and 8" front beam extension. If anyone has any leads on these LMK. I need to check and post on the classifieds. I checked eBay last week or so, but that’s all.
-JPL
vaughn bros.
vaughn bros. is offline
PostPosted: Mon Jun 11, 2012 12:08 pm    Post subject: Reply with quote
Nice house and surroundings. Are you sure your wife will allow you to build that car in the driveway? Shocked
VOLKSWAGENUT just finished his and my buddy Drew built the KDF Mangler. After seeing the youtube of VOLKSWAGENUT vair powered volksrod, I know I aint gonna try to race them. Drew always seem to have belt guide problems. Check out VOLKSWAGENUT's valve covers. Keep up the hard work.
jipple28
jipple28 is offline
PostPosted: Mon Jun 11, 2012 1:46 pm    Post subject: Reply with quote
Thanks Vaughn Bros, but this is my parent's house. Embarassed
I've been looking for a bachelor pad; 2-3 car garage with a studio apartment upstairs, but that's not a common find in my area. Older carriage houses only pop up once every so often and I just missed the last one about a year ago. I'm a single guy, so it's the best I can do right now. I prefer the country to crowded suburbs any day.. especially in Jersey! #spit
I'm sure I've seen VOLKSWAGENUT's.. Was that dubbed 'Operation X'?
Drew's Mangler is like my all-time favorite Volksrod. It's my desktop background at work. If he sold autographed posters/calendars of it I'd own both.
This project is something entirely new to me.. I've never done bodywork like this. My daily driver is a fairly beefy Jeep (see background of the last photo I posted). I've fabbed a couple things for it, but I'm tired of pouring money and gas into it, so I've shifted to this.. gotta play with something, right?
My dad disagrees, but I feel this currently has too much of a highboy look to it, and I'm not thrilled with that. Thinking I may need to section about 3" out about the lower door hinge.. would appreciate feedback on this. How difficult do you guys reckon that being? My only real concern is splicing the door because I want to be able to have working driver and passenger windows. I don't expect it to really be relevant, but I intend to install suicide door hinges with bear-claw latches and shave the door handles (already have all the hardware).
I know it should be pretty quick when finished, but I don't intend to race this thing at all. I just want to build something to my tastes that I can enjoy and drive.
jipple28
jipple28 is offline
PostPosted: Wed Jun 20, 2012 7:54 am    Post subject: Reply with quote
Made some progress lately.. primarily last night as I decided to cut out the section between the B and C pillars and drop in the lengthier piece from the donor roof.
I chopped the necessary interior channels too, so will need to go inside and weld them in after the exterior shell is in place.
Firewall was chopped about 2” (I think), dropping the rear window. Instead of trying to pinch the rain rails in towards the grill (which looked extremely awkward from the rear) I decided to chop between the window and the body curve and add a gap between the two. I'll just graft in some sheet metal to make up the difference later. This allows me to leave the flow of the rails and not widen the rear window, which I had actually considered at one point. In the photos these sections are just mocked-up in place with locking pliers and magnets. It should all line up in the end. Considering where I came from and what I hacked away thus far it’s looking pretty dang good.
What do y’all think about my chopped ‘oval’? Just kidding, I am going to insert the original ’57 Oval once everything else looks smooth.
After that I’ll get the interior support channels in place and start prepping for an original ragtop slider clip.
I ordered a bunch of Corvair-to-VW parts from Starr Cooke (adapter place, flywheel, clutch, reverse camshaft, etc), so those should be arriving any time now.
Still need the ragtop clip, if anyone has one collecting dust.
Also need to order a 10” extension beam and associated parts.
I have to admit- I had a dream last night that I was actually driving this beauty.. I was so proud. Very Happy
More photos can be found at my Flickr photoset:
-JPL
vaughn bros.
PostPosted: Wed Jun 20, 2012 3:11 pm    Post subject: Reply with quote
Lotta work man. Keep going and posting pics. Very Happy Very Happy Very Happy
jipple28
jipple28 is offline
PostPosted: Tue Jun 26, 2012 1:16 pm    Post subject: Reply with quote
Thanks Vaughn Bros. Yeah, I've definitely been doing this the hard way, but that's nothing new for me. First time doing anything like this, so live and learn. I would have done it differently if I started with a top that hadn't already been chopped once before.
As for the '57 oval window clip (the one that was run over in the parking lot) I pounded it way back into shape and am only slightly off at this point. I'll post pics or a video later to demonstrate where the issue remains. I'm sort of considering leaving this heavily-chopped square window in; my friends and I kinda like it.. maybe I could save the oval for the next time around (LOL!)?
This past weekend was less than progressive but I expect to get some more work done tonight. I'll continue to post pics as I move along.
Still need to find an original ragtop slider clip; that would certainly help me line up the roof and get all the curves smooth.
jipple28
jipple28 is offline
PostPosted: Tue Jul 03, 2012 9:20 am    Post subject: Reply with quote
A quick update; I decided to keep the shorter, wider square window instead of grafting in the '57 oval. Much of the work in the rear is complete, aside from some minor cut/weld adjustments.
Honestly I think the rain rails look great from behind the B pillar to the tail end, but still not pleased with the front.. I cut the A and B pillars yet again and will work on lining them up properly. Without the rails I could easily hide the difference, but that's not how I want to do it.
Here's a pic showing how I got my 63' ragtop slider home from central Jersey last weekend. Worked excellent.
It is pristine, barely any surface rust to be found!
Almost all of the slider hardware was included (minor surface rust). I know I need one of the long aluminum rails that the plastic wheels slide down, however (I think the driver's side track).
Before cutting the ragtop clip out and grafting into my project bug I need to get the A and B pillars sorted out for good. I had them close, but not to my liking and I'm pretty dang close to a perfectionist. I'm taking many more measurements now trying to figure out what needs to go left/right and up/down.
-JPL
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Tue Jul 03, 2012 9:39 am    Post subject: Reply with quote
Welcome to your new location, Anyway you should check out this thread, it will provide some inspiration. he's been there done that on the Corvair Engine and worked out a lot of the bugs. It's a good read. http://www.thesamba.com/vw/forum/viewtopic.php?t=466290
Well..... most but not all...worked out.. Wink
Its pretty cool to have something "different" A Volksrod in general will give you that. They DO draw more attention than any ole' VW right out the gate..
If I would have not had the Corvair engine already, and had to buy parts....or even an engine, it would have easily been a Turbocharged Beetle engine...or Subaru... Cool
The Corvair engine is a heavy lump of misc. alloy... and in my opinion needed extra supports to make it viable. Its an old idea, old engine, odd to find, and parts are really not redily available... The people that have these engine have 20 laying around and wont sell them. It could look just as cool hanging a big hair drying snail and carb out the back on a pumped up VW engine.....plus would be faster too boot... Twisted Evil
jipple28 wrote:
I'm sure I've seen VOLKSWAGENUT's.. Was that dubbed "Operation X'?
Its VOLKSWAGNUT... Smile Nice to meet ya....
Hey vaughn bros to get it right..... will ya.. Laughing
yep... Operation X that's the one...
I'll be keeping an eye on your build..... Wink
I was born in Jersey... Rahway to be exact... Cool
Finding a good canidate Corvair engine may be rough, then spending the coin to make it work.. You can easily build a super VW engine for lots less..
But hey if you got your heart set on the flat 6 beast.... go for it.. Ill offer any advice I can to help make the plunge...
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
jipple28
jipple28 is offline
PostPosted: Thu Jul 05, 2012 8:19 am    Post subject: Reply with quote
Thanks Volkswagnut. Nice to meet you too.
I actually already have a '69 110 in 'running' condition, 140 heads/jugs and 4 primary carbs. Also picked up the adapter plate, clutch, flywheel, distributor gear and reverse camshaft from Starr Cooke. It's a matter of rebuilding the engine and fabricating supports for the thing now.
Honestly I'm kind of kicking myself for not running a larger turbo'd VW, though. I'm concerned as to how far out the back the Corvair engine is going to hang and if my body is going to be low enough to pull it off.. Don't know if I could recover enough of my funds to make it feasible at this point.
A belated Happy Independence Day to all!
I didn't go to any local fireworks but I showered myself in sparks all day if that counts. Anyway, lots of progress made; perhaps the most single productive day with the bug. Lined-up A and B pillars, tacked B pillars in and then cut out just below the rain rails to allow me to lay the A pillars and rain rails on top. To my amazement everything worked like a charm.
When I was pleased I dropped in the ragtop clip and tacked that in (added supports to hold the ceiling up), then began filling the rear center that was previously left wide open.
Next I'll continue filling roof gaps, pinch the upper A pillars together (as they are too wide), building up the B pillars where they meet the roof, etc. Moving forward.
The height of my visibility through the window is 8 1/2"; how much of a chop does that equate to?
I'm really looking forward to pulling the doors off and working on those, too, but don't know if I have enough strength in the whole roof section to do so yet. Thoughts? Right now I barely fit though the windows (I'm a fairly thin guy), so I am carefully getting in and out of the thing by stepping on the front tire and in over the roof through the ragtop clip.
Also seriously considering sectioning out a few inches of the body. I don't need heater channels, and certainly want to drop the body as low as possible so there's no gap between the rear grill and the top of the engine.
For the rest of my photos so far see my flickr set:
-JPL
VOLKSWAGNUT
PostPosted: Thu Jul 05, 2012 9:00 am    Post subject: Reply with quote
You can always sell the Corvair stuff to another sucker....
-JPL
Windshield started at 15 inches. I guess that means you never put a scale on it.... Wink
Thoughts,
Oh yes... If you have not already you need to cross brace the door gaps and cross brace the body across the B pillars near the lower quarter windows.
It looks like you have though....
Once you do, the doors can come off. .
VW's have the tendency to fold up like a fortune cookie if you dont brace them.
aka Ken {o\!/o}
jipple28
jipple28 is offline
PostPosted: Thu Jul 05, 2012 9:24 am    Post subject: Reply with quote
-JPL
Thoughts,
Thanks Ken. I bought this as a project chop; the previous owner cut out around 4" and I wanted to go lower. So no way to get accurate measurements or anything, aside from setting clear body joints as references and measuring from there.
The top of the windshield to the hood may be 15" stock, but I'm talking about POV from the inside. The top of the pinch weld to the bottom of the pinch weld seams is where I measured 8 1/2".
I do have a cross support from B pillar to B pillar. Guess I'll have to weld supports from that support bar to under the dash. I thought with the roof in one piece I'd be OK, so long as the body didn't come off the frame.
VOLKSWAGNUT
PostPosted: Thu Jul 05, 2012 10:12 am    Post subject: Reply with quote
The roof will hold it together side to side if you have it fairly well welded in place.
Chances are its already sprung a little, just due to the previous owners work, in addition to the rag top clip being added.
Besides..its going to be a Volksrod... you can pretty much make this up as you go ...
Im not a body guy by no means... more mechanical, but I've at least learned it doesn't hurt to have the extra support in place.
It looks like the doors were welded as braces???
I wouldnt take the chance of having the roof hold it all together when you break those loose.
I'm just giving you advice, as I have learned by experience and the caution of others.
It looks like you have it under control...now get to workin'...
By the way do you have a name for your project... of did I miss it?
Good luck with that.....
aka Ken {o\!/o}
jipple28
jipple28 is offline
PostPosted: Mon Jul 09, 2012 9:21 am    Post subject: Reply with quote
Well, it's been kind of a running joke with my friends that I'd call her Lindsay.. Even though it's not a true '53, it's got the ragtop clip from one. Wink Admittedly she's less than admirable these days, but I loved Lohan before her troubled years.
Not a lot to report other than I've been filling the gaps along the sides of the ragtop clip. Overall the curve all around isn't bad, certainly would not require much bondo to smooth out, but I'm wondering how much work leading would be?
Also starting filling the gaps in the C pillar, but no pics of that yet.
I'm going to need to pick up a recharged tank of oxyacetylene this week.
Sorry for the blurriness of this photo- I was balancing myself on the driver front tire and holding the phone over my head when I took it.
Inside front view.
Inside rear ceiling.
-JPL
My Volksrod project thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=6093484
Flickr set:
