Van's Ruin Samba Member
Posted: Sat Mar 04, 2023 7:44 pm Post subject: Vanagon ABS panel clip alternatives |
GW is selling deluxe panel clips for use with abs or wood panels. These deluxe clips look similar to motorcycle windscreen hardware, posted an example pic above. These windscreen fasteners can be found for .35c each as apposed to $1.57 each for the GW version.
Anyone have experience with the GW deluxe style clips? Anyone have a better source? |
valvecovergasket Samba Member
Posted: Sat Mar 04, 2023 7:54 pm Post subject: Re: Vanagon abs panel clip alternatives |
I didn't have any luck with the GW deluxe clips fitting into the holes on my early van
Ended up tossing them and replacing with some black pop out/push in generic stuff that fits perfectly.
Assuming it's not a problem on later vans, since GW seems to be late van centric. _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Sat Mar 04, 2023 8:04 pm Post subject: Re: Vanagon abs panel clip alternatives |
valvecovergasket wrote: |
Assuming it's not a problem on later vans, since GW seems to be late van centric. |
Thanks, we’ve got an 89 and 91, so maybe no problem with that style of fastener. |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 920 Location: Sammamish, WA
Posted: Sat Mar 04, 2023 10:36 pm Post subject: Re: Vanagon ABS panel clip alternatives |
I tried to use the GW deluxe fittings when installing my ABS panels and didn’t like them (they didn’t truly stayed in place); ended up using rivnuts and that proved to be bomber-proof (size 10-24 fits perfectly) _________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
Posted: Sun Mar 05, 2023 11:12 pm Post subject: Re: Vanagon abs panel clip alternatives |
Do you have a link for the push in clips that you used? Reusable fasteners seem like a better solution. |
