Lind Samba Member
Joined: November 06, 2000 Posts: 10216 Location: idaho
Posted: Sat Apr 08, 2017 6:27 pm Post subject: Hazet spare tire tool kit versions |
I have been collecting and researching spare tire tool kits for a while now. I have seen information in various places on the web, and mostly on this website. There is plenty of information spread through the Hazet tools with photos and numbers topic which is a sticky topic in this forum.
https://www.thesamba.com/vw/forum/viewtopic.php?t=391860
I would like to get all the possible information and knowledge about these kits in one place.
I would like to go through each style, version and variation of the various kits.
The style is the main layout.
The version is evolution of the particular style
The variations are the changes of the tools, etc. within each style.
What I have seen so far is that there are six styles:
V1 standard layout
V2 fabric tool roll
V3 "brake" kit
V4 1500 kit
V5 late style kit
V6 rectangular box
The standard layout is the most common. I have identified 6 versions of this box. Each can be identified by number, style and locations of the clips that are rivitted to the box.
V1.1 full circle, 11 tools
V1.2 full circle, 12 tools
V1.3 semi circle, 12 tools
V1.4 13 tools
V1.5 4 wrenches, no T socket wrench
V1.6 extendable spark plug wrench, separate tommy bar for spark plug wrench.
Through time the tools, etc. changed. These are the variations of the particular version.
for instance perhaps:
V1.3.1 had a 36 wrench and felt backing.
V1.3.2 had a 36x21 wrench with a decal still showing the earlier wrench.
V1.3.3 had a 36x21, earlier decal and flocking instead of felt.
V1.3.4 had flocking and a decal with the 36x21 wrench shown.
I am not sure of that exact progression, but with enough input and data points we should be able to nail this down.
Hazet catalog/brochure images:
style 1:
style 2:
style 3:
style 4:
style 5:
style 6:
I want to include everything that is known about these kits. here are some simple facts which I believe to be true:
The kits with VW stamped on them were sold through VW dealers
The kits with Hazet tourist stamped on them were sold through the aftermarket, or could have been sold through dealers.
Both style lids were produced concurrently through the production run.
VW box:
Hazet Tourist box:
The decal in the lid may not match the tools inside the kit.
early kits have felt under the tools.
later kits have flocking on the tool side of the inside of the kit.
some kits have neither felt or flocking
VW specific specialty tools have numbers starting with 5xx. i.e. 527, 561, etc.
sometime in the mid '50s (1957ish) the numbering changed to 25xx. i.e. 2527, 2561, etc.
The tools that don't start with 5xx or 25xx are standard hazet tools.
In 1965 the Hazet name went to HAZET with an upper case A.
There are transitional tools that have both upper case "A" and lower case "a" on the same tool.
I am not sure that everything I am putting here is exactly correct, so any corrections are welcomed. _________________ .
Wanted:
Lind Samba Member
Posted: Sat Apr 08, 2017 6:29 pm Post subject: Re: Hazet spare tire tool kit versions |
Various versions of style 1:
style 1 version 1:
style 1 version 2:
style 1 version 3:
style 1 version 4:
style 1 version 5:
style 1 version 6:
_________________ .
Wanted:
Lind Samba Member
Posted: Sat Apr 08, 2017 6:30 pm Post subject: Re: Hazet spare tire tool kit versions |
V1.1
"16 inch" kit
full circle ring on back
felt lined
11 tools:
1850 small pliers
527 14mm T handle wrench
600 14mm wrench
600 10mm wrench
450 7x9mm wrench
813 flathead screwdriver
772 lug wrench
561 36mm wrench
811 flathead screwdriver
760 slipjoint pliers
764 sparkplug wrench
Note:
full circle ring
no phillips screwdriver
yellow ends on screwdriver handles
_________________ .
Wanted:
Lind Samba Member
Posted: Sat Apr 08, 2017 6:31 pm Post subject: Re: Hazet spare tire tool kit versions |
V1.2
"16 inch" kit
felt lined
12 tools:
1850 small pliers
814 phillips screwdriver
600 14mm wrench
600 10mm wrench
450 7x9mm wrench
772 lug wrench
561 36mm wrench
Note:
early variations may have decal showing no small phillips screwdriver
_________________ .
Wanted:
Lind Samba Member
Posted: Sat Apr 08, 2017 6:32 pm Post subject: Re: Hazet spare tire tool kit versions |
V1.3
semi-circle ring on back
felt lined
12 tools:
1850 small pliers
813 phillips screwdriver
2527 14mm T handle wrench
600 14mm wrench
450 10x12mm wrench
450 7x8mm wrench
772 lug wrench
2561 36mm wrench
Note:
early variations have a felt liner under the tools
later variations have flocking on the tool side of the inside of the box
early variations have a 36mm 561 wrench
mid variations have a 36x21 561 wrench
later variations have a 36x21 2561 wrench
flocked
_________________ .
Wanted:
Lind Samba Member
Posted: Sat Apr 08, 2017 6:33 pm Post subject: Re: Hazet spare tire tool kit versions |
V1.4
13 tools:
1850 small pliers
605 14mm wrench
605 13mm wrench
450 10x12mm wrench
450 7x8mm wrench
772 lug wrench
2561 36mm wrench
FRK wrote: |
'60 (One Year Only) Spare Tire Round Tool Kit
_________________ .
Wanted:
Lind Samba Member
Posted: Sat Apr 08, 2017 6:34 pm Post subject: Re: Hazet spare tire tool kit versions |
V1.5
12 tools:
1850 small pliers
605 14mm wrench
605 13mm wrench
450 10x12mm wrench
450 7x8mm wrench
772 lug wrench
2561 36mm wrench
Note:
earlier variations have metal handle 772 lug wrench
later variations have plastic handle 772 lug wrench
_________________ .
Wanted:
Lind Samba Member
Posted: Sat Apr 08, 2017 6:41 pm Post subject: Re: Hazet spare tire tool kit versions |
V1.6
12 tools:
1850 small pliers
605 14mm wrench
605 13mm wrench
450 10x12mm wrench
450 7x8mm wrench
772 lug wrench
2561 36mm wrench
2505 sparkplug wrench
literature indicates this is a '68+ kit
_________________ .
Wanted:
Lind Samba Member
Posted: Sun Apr 09, 2017 4:25 pm Post subject: Re: Hazet spare tire tool kit versions |
v2.1
fabric tool roll
many many tools
September 1950 parts list image:
discussion:
https://www.thesamba.com/vw/forum/viewtopic.php?p=2594974 _________________ .
Wanted:
Lind Samba Member
Posted: Sun Apr 09, 2017 4:30 pm Post subject: Re: Hazet spare tire tool kit versions |
V2.2
second version of the tool roll
image from 1958 parts list:
discussion:
https://www.thesamba.com/vw/forum/viewtopic.php?p=5773391 _________________ .
Wanted:
Lind Samba Member
Posted: Sun Apr 09, 2017 4:42 pm Post subject: Re: Hazet spare tire tool kit versions |
V2.3
later tool roll
_________________ .
Wanted:
Lind Samba Member
Posted: Sun Apr 09, 2017 4:44 pm Post subject: Re: Hazet spare tire tool kit versions |
Does anyone have any other versions of the accessory tool roll? _________________ .
Wanted:
Lind Samba Member
Posted: Sun Apr 09, 2017 4:53 pm Post subject: Re: Hazet spare tire tool kit versions |
V3.1
"brake" tool kit
520 feeler gauge
450 7x8mm
450 10x12mm
600 14mm
527 14mm T-wrench
559 oil pressure sender T-wrench
772 lug wrench
760 pliers
513-27 wheel bearing wrench set
764 spark plug wrench
_________________ .
Wanted:
Lind Samba Member
Posted: Sun Apr 09, 2017 4:59 pm Post subject: Re: Hazet spare tire tool kit versions |
Style 4 is the kit for the 1500 (type 3 models)
These boxes are made out of plastic.
middle -- late -- early
_________________ .
Wanted:
Lind Samba Member
Posted: Sun Apr 09, 2017 5:04 pm Post subject: Re: Hazet spare tire tool kit versions |
V4.1
1500 kit
flocked
plastic box
(the one of the left)
_________________ .
Wanted:
Lind Samba Member
Posted: Sun Apr 09, 2017 5:06 pm Post subject: Re: Hazet spare tire tool kit versions |
V4.2
1500 kit
plastic tray
plastic box
_________________ .
Wanted:
Lind Samba Member
Posted: Sun Apr 09, 2017 5:07 pm Post subject: Re: Hazet spare tire tool kit versions |
V4.3
1500 kit
plastic tray
plastic box
no 27 wrenches
_________________ .
Wanted:
Lind Samba Member
Posted: Sun Apr 09, 2017 5:10 pm Post subject: Re: Hazet spare tire tool kit versions |
V5.1
_________________ .
Wanted:
Lind Samba Member
Posted: Sun Apr 09, 2017 5:11 pm Post subject: Re: Hazet spare tire tool kit versions |
V6.1
rectangular box
this kit came with one empty tray that was meant to be filled with tools from the stock tool roll that came with the car from the factory.
_________________ .
Wanted:
Lind Samba Member
V6.2
_________________ .
Wanted:
