Empi 38/38 EGAS carb.
Page: 1, 2, 3, 4, 5, 6  Next
laker
laker is offline
PostPosted: Fri Sep 21, 2012 6:33 pm    Post subject: Empi 38/38 EGAS carb. Reply with quote
Hi, is anybody have any experience with this carb on a 1600 D/P?
Besides the location of the chocke, is 38/38 better carb all the way around then a 32/36 progressive?
modok
modok is offline
PostPosted: Fri Sep 21, 2012 7:14 pm    Post subject: Reply with quote
both carbs are actually too big for a 50HP 1600
The 32/36 is 50% too big
the 38 is 100% too big
The only way a synchronous 38 would make sense is on a divided manifold, like those intended for a bugspray or DCNF, but it would probably not clear the shroud, is it a type-3?
laker
laker is offline
PostPosted: Fri Sep 21, 2012 10:13 pm    Post subject: Reply with quote
Empi claims that is jetted for a 1600 D/P...i question that....i was hopping somebody has tried one.
T2
T2 is offline
PostPosted: Thu Nov 29, 2012 8:14 pm    Post subject: Reply with quote
Anyone out there try one of these yet?
modok
modok is offline
PostPosted: Thu Nov 29, 2012 8:17 pm    Post subject: Reply with quote
Is the manifold isolated side to side?
spencerfvee
spencerfvee is offline
PostPosted: Thu Nov 29, 2012 9:30 pm    Post subject: Re: Empi 38/38 EGAS carb. Reply with quote
hi there is a other forum on the 38 egas carb with pictures under.... new vw carb empi 38 egas. ...the 38 egas works great . i have one thats going on my 1600 spencerfvee.......
david greiner
david greiner is offline
PostPosted: Wed Dec 05, 2012 5:23 pm    Post subject: Reply with quote
http://www.youtube.com/watch?v=blLK3siHYTI&feature=plcp
Out of the box on a 1600 with a 100 cam. It ran great!
noneed
noneed is offline
PostPosted: Thu Dec 06, 2012 9:50 pm    Post subject: Reply with quote
I was under the impression it's the same manifold design as a progressive....
A waste of time IMO, but to be fair I have not tried one of these on anything.
If you really are into using a center mount set up go for a real weber, like an IDF.
Drive your VW... That's what it was made for.
Schwing wrote:
Bondo is like make-up, it fools the eye from the ugly truth
laker
laker is offline
PostPosted: Fri Dec 07, 2012 11:47 pm    Post subject: Reply with quote
No electric Choke....I went to the snow at Big Bear mountain last year with my sons VW club, it was 8%, i saw a couple of bugs with single idf's having a hell of a time trying to keep the car idle or even starting but one of then with a 32/36 progressive carb had no issues what so ever...I had no problems with the 34 pic3 in our Ghia starting.
Thats why i find the 38/38 has its potential....not enough out there yet to get a real good feedback.....Also it maybe a type of carb that will work well with a 1776,1835 or 1914 (larger engines) but may not be a good choice for the stock 1600... I hope they become more popular and we get more feedback on it.
bugaddiction71
bugaddiction71 is offline
PostPosted: Tue Feb 12, 2013 8:29 pm    Post subject: egas 38 Reply with quote
ok i have a 1600dp stock rods and piston 85.5mm , cw crank 69mm , 110 cam, steel push rods,solid rocker shafts 1.1 stock rockers with swival ball ajt., stock heads with mild port and light flywheel. just ordered the egas 38 kit. ill let you know how it goes. everybody cool
laker
laker is offline
PostPosted: Tue Feb 12, 2013 10:59 pm    Post subject: Re: egas 38 Reply with quote
Sounds good, looking forward to your input
bugaddiction71
PostPosted: Wed Feb 13, 2013 1:03 pm    Post subject: egas 38 Reply with quote
ill get it monday or tuesday ill have it on by sat. monday il post some good news
jvulich
jvulich is offline
PostPosted: Thu Feb 14, 2013 11:41 am    Post subject: Reply with quote
I just installed one on a friends 1600 dual port, all stock except a 009 distributor, mild cb performance cam and straight cut gears. I'm still tuning it... Trying to find the happy medium between performance and mileage. When I hit the throttle hard it goes like hell but the speedo and the fuel gauge go in opposite directions. For the novice installer like myself there is a bit of fitting/cutting as per the instructions which I did with a pipe cutter, not a hack saw, then theres other little things Hot VW's didn't do that that I did to make it a little cleaner install. On this particular car I shortened the throttle cable with a custom made 5/32 press on fitting(not with the funky screw on fitting that will hit the shroud with this kit), made an adapter from 5mm fuel hose to the 1/4 fuel hose that the egas carb uses( clamping 1/4 inch fuel hose on a stock fuel pump is asking for trouble in my opinion) and then I put a 90 degree fitting on the vent hose at the air filter so it wouldn't kink.
jvulich
jvulich is offline
PostPosted: Thu Feb 14, 2013 11:50 am    Post subject: Reply with quote
No, it dumps into a single tube at the bottom of the intake.
sactojesse
sactojesse is offline
PostPosted: Thu Feb 14, 2013 11:57 am    Post subject: Reply with quote
Commonly known as a "plenum" manifold, as opposed to an isolated runner manifold.
1966 Karmann-Ghia convertible
Henrip
Henrip is offline
PostPosted: Thu Feb 14, 2013 2:10 pm    Post subject: Reply with quote
Quokka42 wrote:
Hmmm, blowing a lot of smoke and no dyno figures - no good, huh?
White Smoke!!! The pope is dead Sad
No good sign for me too...
Bug 1959 (Sold)
Bug 1961 (Sold)
T2A Pickup 1970
vwracerdave
vwracerdave is offline
PostPosted: Thu Feb 14, 2013 3:23 pm    Post subject: Reply with quote
You guys are gonna find out real quick thoe junky carbs will get horrable gas milage.
808OvalGreasemonkey
808OvalGreasemonkey is offline
PostPosted: Sat Feb 16, 2013 12:21 pm    Post subject: Reply with quote
I found out real quick that my perfectly tuned/wideband tuned & jetted 44idf's on a 2110 motor gets horrible mileage as well!! lol
jvulich
jvulich is offline
PostPosted: Sat Feb 16, 2013 1:06 pm    Post subject: Reply with quote
Gotta pay to play...
modok
modok is offline
PostPosted: Sat Feb 16, 2013 1:55 pm    Post subject: Reply with quote
You can only tune the carb to do what it is capable of doing.
Page 1 of 6
