lolpizowned Samba Member
Joined: July 21, 2010 Posts: 42 Location: Long Beach CA
Posted: Fri Dec 28, 2012 8:20 pm Post subject: VW bus sunroof |
| Does a 1977 sunroof fit a 1971? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17765 Location: San Diego, California
Posted: Fri Dec 28, 2012 10:52 pm Post subject: |
I think so _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Collie Samba Member
Joined: April 03, 2006 Posts: 1285 Location: Virginia
Posted: Sat Dec 29, 2012 10:46 am Post subject: Re: VW bus sunroof |
| lolpizowned wrote: |
Is the '71 a sunroof bus now?
Or a camper with just the sunroof hole?
Or is it a hardtop you want to put a sunroof in? |
Posted: Sat Dec 29, 2012 12:25 pm Post subject: |
| the 71 is a deluxe with the sunroof hole and hardware but im missing the actual panel and the panel is coming from a 77 |
Collie Samba Member
Posted: Sat Dec 29, 2012 12:27 pm Post subject: |
| Then, yes, you are good to go! |
Posted: Sat Dec 29, 2012 12:31 pm Post subject: |
| great to hear thank you! |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42963 Location: at the beach in Northern Wokistan
Posted: Sat Dec 29, 2012 1:08 pm Post subject: |
before you go to a lot of work, check the area on the bus at the back outside of the opening and forward from that spot 12" to see if rust has formed.
Check your bus to see if you will need to repair the area and check the donor as I am looking for sheet metal in this area to replace mine as it has pin holes. EVERY bus I have inspected, even those in a dry climate have rust pin holes there as it rusts from the inside in that area. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Posted: Sat Dec 29, 2012 2:21 pm Post subject: |
Also, before you even begin to do this job I suggest you evaluate what parts you'll need and begin sourcing them. The prices can be sky high and many parts just aren't available from parts houses. Finding good used parts can be an adventure. Be prepared to spend $500 + _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sat Dec 29, 2012 4:36 pm Post subject: |
Here's a cheap solution I just found
http://sandiego.craigslist.org/esd/pts/3508896635.html _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
