ccb_dan Samba Member
Joined: August 03, 2009 Posts: 321 Location: Cocoa Beach, FL
Posted: Thu Nov 15, 2012 4:48 am Post subject: Repairing/Refurbishing Interior Panels |
I did a quick search but admittedly I did not spend too much time looking so feel free to verbally abuse me for posting a question I am certain has been discussed over and over.
I have all the original interior panels for my 65 standard and most of them are in very good condition. However the long panel on the driver's side has a rip going from the bottom up about 8" or so. Like someone tried to pull the bottom of the panel out and it just ripped. Is there a good way to repair that without damaging the rest of the panel?
I'll try to post a pic of the rip later so you can see what I mean.
Thanks! |
stevo Samba Member
Joined: January 22, 2004 Posts: 974 Location: the eugeniverse
Posted: Thu Nov 15, 2012 1:30 pm Post subject: |
hey dan, i'm doing this same job right this moment on my grey/mesh long panel. the rip is at the top. conspicuous, but i'm going for it. just glued the board. it was not a straight rip, it was more of a filet. i spread wood glue between the filet and have it vinyl side down with small plywood and a crank weighing it down. after a few hours i'll glue what i can on the front. i'm expecting a scar, but hoping i can shave remaining hairs, and color match imperfections with a marker. when i finish gluing the last of the perimeter i'll track down a 3x8 inch linoleum scrap and glue that splint on the back side, beginning a half inch down so the lino doesn't impact bus metal when installed. |
Posted: Fri Nov 16, 2012 4:20 am Post subject: |
Awesome Steve.
Sounds like that should work. I might give the same method a whirl and see how it goes.
Much thanks for your reply! |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1151 Location: Burlington, WA
Posted: Wed Feb 27, 2013 10:21 am Post subject: |
I thought I'd bring this post back instead of starting a new one, but I'm wondering if anyone has any tricks for this as well.
My long panel has a tear, but the board is badly warped as well. I'm planning on replacing the board, but might try soaking the whole thing with water and laying it flat with a large wood board on top.
My biggest concern is that the og vinyl is pretty crispy, so I'd like to see if anyone has any suggestions on ways to work with this and not tear it any worse... _________________ -Adam
'59 Mango Bus
'69 Bug - Cobalt Blue |
Braukuche Samba Member
Posted: Wed Feb 27, 2013 11:38 am Post subject: |
otis_bartleh wrote: |
My biggest concern is that the og vinyl is pretty crispy, so I'd like to see if anyone has any suggestions on ways to work with this and not tear it any worse... |
From previous posts I know glycerin is recommended as a softening agent. If the vinyl has shrunk you can use mild heat to stretch it. Soaking the board will soften it up and on a hot sunny day if you lay it out with some boards and weight on it it is supposed to resume its original shape more or less.
Disclaimer: I have not tried any of this yet, just recalling the suggestions. _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia |
Posted: Wed Feb 27, 2013 9:26 pm Post subject: |
Braukuche wrote: |
Disclaimer: I have not tried any of this yet, just recalling the suggestions. |
Thanks! And if I can get it close enough to put in, I'll be happy... She's a driver, not a show bus, so perfect isn't a requirement...  _________________ -Adam
'59 Mango Bus
Atlantic Samba Member
Joined: July 24, 2008 Posts: 704 Location: Kalifornien
Posted: Thu Feb 28, 2013 6:24 am Post subject: |
I have just tried this on the long and a smaller panel. Both were really bad - completely warped and bone hard. I soaked them for a while till they were fully wet, put plywood on top and parked a car on top of the ply for 1/2 day ('cause there was no way, they'd assume their orig shape just by lying around and drying). Only issue is that this way panels can't dry. So I had to let them dry in the open next day. They straightened out quite a bit, but are still warped.
Braukuche wrote: |
... I don't know if I should mention this here, but I do have a very nice og grey/mesh long panel that I do not need - contact me if you are interested! _________________ _______________________
"If we believe absurdities, we shall commit atrocities." [Voltaire] |
werksberg Samba Member
Joined: February 08, 2005 Posts: 2162 Location: Green Valley, AZ
Posted: Fri Mar 01, 2013 2:08 pm Post subject: |
I tried the watering the OEM panel & lay them flat deal and they just fell apart on me so I couldn't make a master from them at all....
Good luck! _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
Posted: Fri Mar 01, 2013 2:48 pm Post subject: |
werksberg wrote: |
Good luck! |
Yikes... I'm lucky in that instance, my buddy has a long panel not on his bus right now that he said I could use to make the new one...
Thanks, gonna start working on it tomorrow, so we'll see how it goes... I just hope I don't break up the vinyl, but I'm afraid that's inevitable...  _________________ -Adam
'59 Mango Bus
Clara  Samba Member
Posted: Sat Mar 02, 2013 12:19 am Post subject: |
I've successfully soaked and flattened a number of og panels.
If it is very warped, be gentle. Hose it, and wait till it the water has soaked in. Then spray more water, and gently lay a board on. Don't put any weight on until it has started to relax, and is just wavy. Otherwise it is like smashing a potato chip
If you wait a couple days they will dry out all the way. Well not outside in the rain. I tend to do that in the garage, as it is raining. Your climate may vary. Actually just put one to flatten today. Did I mention rain? Actually showers turning to rain.
I recommend taking the chrome trim off before flattening. |
Posted: Sat Mar 02, 2013 10:15 am Post subject: |
Clara wrote: |
Thanks! In some looking around, I've also seen upholstery folks recommend hand lotion to soften the vinyl, anyone have a though about that? Seems kind of odd, but who knows... _________________ -Adam
'59 Mango Bus
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
Posted: Sat Mar 02, 2013 11:37 am Post subject: |
Glycerin or Mineral Oil is essentially the same without the fragrance and should be MUCH cheaper. I used mineral oil on my resurrected floor mat with great results. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
