igtoth Samba Member
Joined: May 09, 2006 Posts: 385 Location: Ribeirão Preto, SP, Brazil
Posted: Thu Dec 13, 2012 6:38 am Post subject: Are these Porsche heads? |
Hi,
I believe those are Porsche heads.. but I never saw it before.. Anyone knows what they are for ?
Regards.
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5669 Location: On an island in VA
Posted: Thu Dec 13, 2012 6:40 am Post subject: |
Judging by the angle of the exhaust valves and double rocker studs, they are indeed porsche. |
slalombuggy Samba Member
Posted: Thu Dec 13, 2012 6:49 am Post subject: |
Double rocker studs and angles exhaust valve definitely indicate 356/912 Porsche heads.
brad |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Thu Dec 13, 2012 9:28 am Post subject: |
Ive never seen a porch with ex port like that.possiably a vw head somebody put the porsche rocker system on & canted the ex valve, something Ive been wanting to do, but no time.(intake valve too.)but the valve cover is not vw shaped.possiably something not ment for us??brazill only? one off german?Idono. whats the spring side look like?casting ##?? the intakes also apper to be canted. if it fits use it!!!I would. |
Posted: Thu Dec 13, 2012 3:17 pm Post subject: |
I think you're right Mark, Porsche used a rectangular shaped exhaust port and the studs were level across the rocker box and the shape of the box is completely different
brad |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3668 Location: Sarasota, in my adopted state of Florida
Posted: Thu Dec 13, 2012 3:34 pm Post subject: |
Wrong bore spacing to be a Porsche head, would not fit. Has to be a one off and very rare 40hp and latter type 1 head. I would love to see the rocker arms for it or a dp version of it. Does not look like aftermarket. Been around VW's for forty years and have never seen one like that. Dan |
Posted: Thu Dec 13, 2012 4:22 pm Post subject: |
possiably the front drive gol? from brazill? and yes it would be nice with duel ports, even single I would like a few sets ready with rocker gear to play with, even add an extra intake port.but just too much stuff in the way as it is, but it would be un to play with & probably make some real good power. |
flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1173 Location: Las Vegas, Nevada
Posted: Thu Dec 13, 2012 5:09 pm Post subject: |
I have never seen a 356/912 head with round exhaust ports and a single intake port also the 356 heads have the lower part of the rocker boxes elongated to accommodate the angle of the exhaust valves. The combustion chambers are also hemispherical. But those are very interesting and would be cool vintage speed motor. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
75smith Samba Member
Posted: Thu Dec 13, 2012 5:20 pm Post subject: |
whats the marking in the head(rocker side), looks like a trapezoid, in between the stud stands? also the round print on the right side of the head(top pic)? _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
Tortie Samba Member
Posted: Thu Dec 13, 2012 8:57 pm Post subject: |
Sorry to disappoint but these heads are definitely not Porsche.
Porsche never "produced" a single port head. Even the first Gmund cars from 1948 had dual port intakes. They used VW engine blocks for the first five years, but the heads were their own design. Don't know what this is off but since the VW guys are stumped I'd wager it's something really weird,...like French or some such. Possibly Panhard?...Deutch Bonet?
There are lots of air cooled horizontaly opposed engine designs in the past. Fairbanks Morse? And then there's the whole aviation world and ground power unit world...
Or, like some have suggested, some sort of aftermarket speed development head someone designed and had made. |
Posted: Thu Dec 13, 2012 9:28 pm Post subject: |
or one of those car companys in brazill that also did some special heads, there was some 356 replicas coming out of there back 20+ years ago. it sort of looks like a single port superflow valvecovered vw ex,port porsche, conglomoration of some sort.kinda like a replica should have, not just a run of the mill vw mill. |
Posted: Thu Dec 13, 2012 9:44 pm Post subject: |
this is what I have found and it appers to be what I thought.
1980s, air-cooled VW Gol: upgrade for VW Types 1, 2 & 18
Posted: Fri Oct 13, 2006 7:28 am Post subject: 1980s, air-cooled VW Gol: upgrade for VW Types 1, 2 & 18
1980s, Brazilian built, air-cooled engined, VW Gol (not Golf !): engine upgrades for VW Types 1, 2 & 181
Whilst browsing through some of my old car magazines, I came across an article (Neil Birkitt, " VWs From Abroad: It's not Golf, it's GOL!", VW Motoring, December 1995, pp68~70), about the Brazilian built VW Gol, featuring a VW 13/1600 Type 1 style, air-cooled engine, but with redesigned, twin-port cylinder heads (valves inclined at 15º to the cylinder axis, rather than parallel) and a cooling system with axial-flow fan and integral alternator (akin to the Porsche 911 arrangement), whose fan inlet is at the crank-pulley end, rather than the flywheel end of the engine.
The air-cooled engined VW Gol, went on sale in Brazil, in the early 1980s and it's interesting to note, that the redesigned, twin-port cylinder heads and unique cooling system, were sold by Claude's Buggies (later renamed CB Performance), as a performance upgrade for VW Type 1, 2 & 181 engines. By 1995 or perhaps earlier, the VW Gols, were re-engined, with VW 1600 & 1800 water-cooled, in-line engines.
Regards.
Nigel A. Skeet
MikeGatch Samba Member
Joined: April 01, 2009 Posts: 445 Location: Valparaiso IN
Posted: Fri Dec 14, 2012 8:13 am Post subject: |
mark tucker wrote: |
twin-port cylinder heads |
Only one issue with that reference. _________________ Daily Driver: 73 STD Beetle.
Road tripper: 82 diesel westy vanagon. (Won't idle work in progress)
Adequately powered road tripper: 73 campmobile.
Bugs with no legs. 1 72 standard and 2 super verts. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2882 Location: HdG, MD & NJ
Posted: Fri Dec 14, 2012 8:39 am Post subject: |
I want the fan shroud!
_________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79494 Location: Sneaking up behind you
Posted: Fri Dec 14, 2012 8:45 am Post subject: |
NJ John wrote: |
The GOL shroud has been proven not to work on a Type 1 engine.
It will run hot. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Fri Dec 14, 2012 10:29 am Post subject: |
but it is on a type 1 engine from vw. and yes I would run it if I had one or 2 of them, wish I did.
so who proved it? and what were they doing? was it properly done? the typ1 shroud has proven to run hot too.in ohsomany cars.not trying to start shit but I dont see any issue with it I couldnot fix.
and whats the issue with the twinport??that was just copied from another older samba post.(no I dont know how to link them, remember I lived in cali so some brain cells are burnt out) just messen. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3295 Location: SOUTH DAKOTA
Posted: Fri Dec 14, 2012 10:55 am Post subject: |
MikeGatch wrote: |
Only one issue with that reference. |
What he said... |
Posted: Fri Dec 14, 2012 6:06 pm Post subject: |
so the olson twins dont port vw heads?they went from single ports to duel ports(twinport) |
Beetspeed Samba Member
Joined: July 30, 2004 Posts: 434 Location: The Netherlands
Posted: Sat Dec 15, 2012 4:23 am Post subject: |
Very cool! Never seen anything like that either.
They seem to resemble the above Gol description, save for the twin-port part.
So, have there ever been single port VW Gol engines?
Maybe if some VW Gol's were 1500 engines, single port would sound consistent with VW's prior offerings in head-engine combo's?
Igtoth: where did you found these? Were they on an engine that you know of? Any history of the heads or just the picture?
Would also love another good pic of the chamber  _________________ '75 SB 1303 2,4ltr T4 turbo: 10.58 @ 129.9mph
'65 Ruska buggy 1192cc EFI 90hp N/A |
Posted: Sat Dec 15, 2012 8:28 am Post subject: |
Mark, I know no one has ever mentioned this, but you're ridiculous. I don't see how anyone could ever get mad at you are genuinely argue anything you say. In my opinion you keep things casual and light hearted in these forums and maybe I have a poor sense of humor, but I'm usually laughing at your jokes. _________________ Daily Driver: 73 STD Beetle.
