Rear hatch rubber door to body cable sleeve
PDXSyncro
PDXSyncro is offline
PostPosted: Sun Jan 06, 2013 4:15 pm    Post subject: Rear hatch rubber door to body cable sleeve Reply with quote
Hi Guys,
I'm in need of a new rear hatch cable sleeve with grommets. It's #33 in the image on this page:
http://www.jimellisvwparts.com/showAssembly.aspx?u...gory=21728
If they are not available has anyone had any luck fabricating anything? I figure a few grommets and a nice thin yet tight fitting rubber sleeve might work.
Cheers,
glen
Timwhy
Timwhy is offline
PostPosted: Sun Jan 06, 2013 4:19 pm    Post subject: Reply with quote
nla
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
Timwhy
Timwhy is offline
PostPosted: Sun Jan 06, 2013 4:22 pm    Post subject: Reply with quote
If your are still somewhat intact, you can do what I did and smear black RTV all over them and let it cure.
It's not ideal but is keeping the water out of my hatch.
'15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
GMByers
GMByers is offline
PostPosted: Sun Jan 06, 2013 6:29 pm    Post subject: Reply with quote
Recently discussed here also http://www.thesamba.com/vw/forum/viewtopic.php?t=538771&highlight=hatch
And then there were two...downsized to 83 Doka &
74 Thing.
hdenter
hdenter is offline
PostPosted: Sun Jan 06, 2013 9:07 pm    Post subject: Reply with quote
I haven't gotten to this yet, but my plan was to search the wrecking yard for a similar tube and either use that tube or use the make and model to order a new one from that manufacturer. Switching to an oval tube would be a good idea, too.
Hans
'79 triple white convertible bug
'84 sunroof vanagon
'85 weekender
PDXSyncro
PostPosted: Sun Jan 06, 2013 9:39 pm    Post subject: Reply with quote
Thanks guys I got the part number from the other link (251971840) and found it at busdepot. I just ordered it. We'll see if they have it. They'll probably just come back and say that they don't have it. If it doesn't work I'll try that grommet and clear plastic tubing workaround. Mine was completely disintegrated. The drivers side grommet/tubing is in good condition. Weird!
BTW: I'm in the process of running new windshield washer tubing in the front and back. I've completed the front and tested some new squirters I got and they shoot straight up over the windshield Rolling Eyes So anyway I've searched and found a link for some 2 way squirters that someone had good luck with:
http://www.thesamba.com/vw/forum/viewtopic.php?p=6356690#6356690
Fingers crossed Wink
So now at least the front tubing is all replaced and working apart from the crap squirters from gowesty. Now the back tubing will have to wait for this darn grommet sleeve.
