algg Samba Member
Posted: Wed Jan 02, 2013 5:24 am Post subject: Correct voltage to the coil |
want to ask question about the correct voltage to the coil. I am running 6V battery of my 1966, voltage measured at the battery is 6.6V while in the coil is 4.6V.
I found it is hard to start the engine ESP during winter time. Wonder if i have the enough Voltage or Current to the coil.
thank you. |
Komissar Samba Member
Joined: May 18, 2008 Posts: 894 Location: Bucharest, Romania
Posted: Wed Jan 02, 2013 5:58 am Post subject: |
You have a voltage drop because of aging electrical system. Clean all connections of corrosion (and other types of dirt/grime) between battery -> ignition switch (plus fuse box) -> ignition coil.
Inspect the wires as well - check for cracks, aging and so on.
And of course, clean the battery terminals and clamps. _________________ 1965 Sunroof Beetle
1972 Type 3 Squareback
1978 Skoda 105S |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13948 Location: White Mountains Arizona
Posted: Wed Jan 02, 2013 7:11 am Post subject: |
When i had my 59 6 volt it was like yours till I cleaned every electrical connection. Got it up to 5.8 volts. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
algg Samba Member
Posted: Mon Jan 07, 2013 6:47 am Post subject: |
thank you all. i have clean up every contact from battery, regular, light switch, ignition switch, fuse and coil. Voltage measured at Coil is now 5V. A bit better. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25988 Location: Olympia Wash Rinse & Repeat
Posted: Mon Jan 07, 2013 6:56 pm Post subject: |
http://www.thesamba.com/vw/forum/viewtopic.php?t=538339
Keep going thru the connections, measuring how much voltage is getting each. You should easily get the voltage drop to less than 1/10 of a volt. _________________ In Stereo, Where Available! |
