Is the under-body propane tank a hazard?
Page: 1, 2, 3  Next
zippyslug31
zippyslug31 is offline
PostPosted: Tue Jan 29, 2013 12:08 pm    Post subject: Is the under-body propane tank a hazard? Reply with quote
Having a syncro westy in rocky terrain has always made me wonder how safe that propane tank under the vehicle is. Maybe I'm just paranoid but a tank of explosive gas hanging under a car driven off-road seems to be a recipe for disaster. The guard around the valve/regulator wouldn't take much to deform; a direct hit would likely sheer off the valve allowing a sudden release of propane.
Searched around and only really found some comments in this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=443751
It's one thing to over-think this sort of thing, and another to dismiss this hazard.... has anybody ever had a real world experience of clobbering this tank with no problems afterward? Anybody have any technical data on exactly what sort of forces it would take to cause a rupture?
previous:
'80 westy
current:
'90 syncro westy 2.5L subi, triple knob, 16" wheels.
'84 sunroof van, 2.1L motor.
Ahwahnee
Ahwahnee is offline
PostPosted: Tue Jan 29, 2013 1:18 pm    Post subject: Reply with quote
That tank is pretty stout, plus (as I understand it) the explosive power of propane, though considerable, is greatest when it is a gas in a confined space. A leak into the open air (e.g. from a damaged tank) while not harmless is not necessarily an imminent disaster.
skivan
skivan is offline
PostPosted: Tue Jan 29, 2013 2:27 pm    Post subject: Reply with quote
mine was off when i bought the van and now i'm going to put one on the back and replumb for a heater and the stove. i don't like it underneath as a skid plate. on a rear swing-a-way it will work well also for a zodi shower and to hook up the bbq.
'87 subaru westy syncro
'04 TDI passat wagon
Ahwahnee
Ahwahnee is offline
PostPosted: Tue Jan 29, 2013 3:40 pm    Post subject: Reply with quote
skivan wrote:
... i don't like it underneath as a skid plate. on a rear swing-a-way it will work well...
Just an observation -- I don't think I have ever seen a vehicle hit from beneath, but have seen a great many rear-ended.
joseph928
joseph928 is offline
PostPosted: Tue Jan 29, 2013 3:42 pm    Post subject: propane tank Reply with quote
Blue Bay Bus I thought about this a lot. Decided to take it out. Put in a TF49 only had a stove to deal with. So went with a 1LB propane bottle in sink cabinet works well . In Moab I would of bashed the old tank, glad I did this! Now my side rock bars will protect both sides, now that the tank is gone.
Very Happy
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
NorCalbuggy
NorCalbuggy is offline
PostPosted: Tue Jan 29, 2013 5:16 pm    Post subject: Reply with quote
I would agree - I'm not a fan of gas cans or propane on the rear of a vehicle...
"Steam seems to have killed all gratitude in the hearts of sailors"
1987 Westfalia Vanagon - "Clifford"
PDXWesty
PDXWesty is offline
PostPosted: Tue Jan 29, 2013 5:33 pm    Post subject: Reply with quote
I don't think there's a reason to over think this one. I've never heard of a van catching fire due to a propane tank being ruptured from an impact, rocks or otherwise. The valving is protected with the skid plate. 25 years of road use and many millions of miles should be enough to ease your concerns.
89 Westy 2.1 Auto
bluebus86
Banned
bluebus86 is offline
Think FORD PINTO!
remember the gasoline tank is also under the van. same issue, yet we live with it. I'd not worry too much about it, Of course you could add some extra steel under and around the propane tank for extra security.
Tank on the rear is not a good idea in my opinion. I have been in three pretty bad car crashes, all three of the cars i was driving were totaled, all caused by someone rear ending me.
I have never even dented my under floor gasoline tank, ever.
If I had a flammable gas tank on the rear of either of the three cars that were totaled in a rear end crash, there likely would have been a big fuel leak.
If looks mean anything a rear bumper mounted tank is ugly in my opinon. and is more likely theft prone.
Racerrojo
Racerrojo is offline
PostPosted: Tue Jan 29, 2013 7:53 pm    Post subject: Reply with quote
I like the idea of the 1lb bottle, but mostly for convenience, filling the tank can be a hassle specially if the hardware its not upgraded, that and I never cook in the van, now if you run a propex or such, its more convenient, then again a 20lbs BBQ that can be exchange at a service station or Seven Eleven makes more sense to me.
BTW I have seen a van with a gaping hole in the tank but the van was in the junk yard and it could had been intencional
Tight is tight... too tight is expensive!!!!
Too many vans and mostly all projects Smile
Crankey
Crankey is offline
PostPosted: Tue Jan 29, 2013 8:08 pm    Post subject: Reply with quote
while I worked in a blacksmith shop we ran our forge on propane
I was told if we had a leak the gas would flow onto the floor and if it caught on fire it would catch everything else on the floor on fire if it would burn.
we used a big bottle about 4 ft tall. if we ran the forge for a long time it would freeze up on the bottom so we would put our hot parts around the base...agents the ring that is the foot of the bottle to help thaw it out.
it made me a little nervous but I trusted my boss and nothing ever happened. it wasn't like we had huge piles of stuff up agents the bottle...just a few parts.
having said that I'd still be concerned with it. if I had a camper I might be compelled to make an extra guard around the valve.
rfoubi
rfoubi is offline
PostPosted: Tue Jan 29, 2013 11:04 pm    Post subject: Reply with quote
are there other smaller, narrower or different shaped tanks that would tuck up along the frame rails out of the way? In particular, to add to a non-westy van? Im thinking of a propex at some point in the future and would prefer something that was less of a dangler than the tanks ive seen on westies.
skivan
skivan is offline
PostPosted: Wed Jan 30, 2013 10:50 am    Post subject: Reply with quote
thanks for the input.
i have annoying green bottles plumbed inside now, but haven't installed the heater yet, and no tank on the bottom since i bought it. i'm not buying a new tank to install underneath a syncro and further decrease my clearance, Clarence. Yes, i am that cool that i worry about offroading in my syncro westy.
the good thing is that both my soon to be big propane tank and gas tanks on the back swing away are removable, and carried when necessary.
Phishman068
Phishman068 is offline
PostPosted: Wed Jan 30, 2013 2:48 pm    Post subject: Reply with quote
the gas tank on the bottom of the van only exists on a 2wd, which generally don't get offroaded to the same extreme as a syncro. The syncro tank is tucked away nicely!
I removed the tank when I did my westy swap and also used 1lb cylinders. I like them. They last a long time.
http://www.thesamba.com/vw/forum/viewtopic.php?t=559766&highlight=winter+rust
http://www.thesamba.com/vw/forum/viewtopic.php?t=482402&highlight=sunroof+syncro
http://www.thesamba.com/vw/forum/viewtopic.php?t=569774
http://www.thesamba.com/vw/forum/viewtopic.php?p=6864936#6864936
"Along with the ability to go fast, one looses the desire to hurry."
noganav
noganav is offline
PostPosted: Wed Jan 30, 2013 5:08 pm    Post subject: Reply with quote
You could push the propane tank right through the bottom of the van without rupturing it. They are very stout.
The only real worry is tearing the copper lines open while off roading. The lines aren't protected by the skid plate.The safest bet would be just to turn off the propane before going rock crawling.
Definitely having it underneath is safer than putting a tank on the back I'd think.
indytriple
indytriple is offline
PostPosted: Sat Mar 02, 2013 10:12 am    Post subject: Reply with quote
Time to rethink?
http://www.thesamba.com/vw/forum/viewtopic.php?t=546624
As The Dude would say..."New sh*t has come to light".
"See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com
dixoncj
dixoncj is offline
PostPosted: Sat Mar 02, 2013 10:16 am    Post subject: Reply with quote
I agree. The TF49 fridge and small propane bottles are in my future. Too risky.
r39o
Samba Polizei
r39o is offline
PostPosted: Sat Mar 02, 2013 10:52 am    Post subject: Reply with quote
I agree an all electric modern frig of some kind is way better than the stock Dometic.
BUT, not all applications can get away with 1lb of propane at a time.
We use a combination of (cheap) butane stoves and Jetboils to heat stuff.
BUT, to heat our butts at night you need a serious amount of propane, which I doubt a 1 lb can will do for the duration required by the Propex heater, for example.
How to handle the needs of a heater?????
syncrodoka
syncrodoka is offline
PostPosted: Sat Mar 02, 2013 10:53 am    Post subject: Reply with quote
eberspacher/espar or webasto gas heater.
VW installed them all the way back to the days of bugs, busses, ghias, fastback etc.
skivan
skivan is offline
PostPosted: Sat Mar 02, 2013 11:00 am    Post subject: Reply with quote
remind me why a refillable internal (larger) tank is bad or illegalish...
would it be so bad to have a 5# tank inside, closed at the valve when not in use or when driving? that would be more convenient than the green bottles for me, and have the capacity for a heater.
Ahwahnee
Ahwahnee is offline
PostPosted: Sat Mar 02, 2013 11:05 am    Post subject: Reply with quote
skivan wrote:
remind me why a refillable internal (larger) tank is bad or illegalish... would it be so bad to have a 5# tank inside...
Propane leak in a confined space
Page: 1, 2, 3  Next
