thundercougar Samba Member
Joined: January 01, 2013 Posts: 10 Location: Cleveland,Ohio
Posted: Thu Feb 21, 2013 6:52 pm Post subject: New to Bajas, does and don'ts ? |
Hey guys, so I fixed up and sold my lime green Berrien Warrior with the 1600 dual port in it! I'm looking to do a Baja bug or something similar to that for a driver and to take out off-roading. The only thing is, I really don't know a whole lot about what it takes or the time/money, etc etc. I've had some people call me with stock 66-74 bugs or super beetles that they've started to make into bajas or restos and haven't finished, how hard/long would it take to make a "mid travel" or just sort of pretty sweet Baja? My budget is about $2500 for the actually bug itself (max I will go), and I'm willing to put in the hours and I'd say another $4-6k into it to make it amazing.
Any advice or words of wisdom would be very helpful! I realize I live in Ohio and we have mud, not sand and the big thing here is jeeps and trucks but I want to do something a little different (: .
The few stipulations I have on this project are that it must be relatively efficient (for daily driving), at least 4-8in of travel (is that average?), street legal !, and not to forget out of the ordinary.
Thanks guys!
- Will |
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Thu Feb 21, 2013 7:07 pm Post subject: |
If your willing to put that kind of $$ into the project, I would start with just a nice shell, go tube chassis. 3x3 or larger rear, 091 trans, motor of choice, A-arms or wider LP with long arms. |
Posted: Thu Feb 21, 2013 7:27 pm Post subject: |
Well I'm only 18 and going off to college next fall so if I can get a semi started project that'd be ideal. I know this is probably a $20,xxx+ rig but something sort of like this: http://farm4.static.flickr.com/3597/3357054324_5ae0e938eb_o.jpg
I have no problem with using a VW engine or going with a small V block, anything I can get really. For the most part this stuff is pretty new to me but I'd love to learn and eventually get into racing/off-roading, custom fabrication, ya know all that good stuff. The only reason I came into all the cash was someone hit my truck and totaled it ): so I'm looking to do a project off the insurance money (is that wrong? haha) |
Snappy Samba Member
Joined: July 16, 2010 Posts: 170 Location: Eureka, CA
Posted: Thu Feb 21, 2013 11:26 pm Post subject: |
We picked up our rag top for about 2.5k I'm about to start dumping money into it paycheck by paycheck, so far my list would run around 2k that's with some new bfg ats I'm about to throw in the front...as soon as I can refinish these jackmans...no real plans for suspension YET... but I think nice fox shocks will run 400-600 each! |
tobiism Samba Member
Joined: January 21, 2004 Posts: 504 Location: Chandler AZ
Posted: Fri Feb 22, 2013 9:04 am Post subject: |
Thats more like an $80-100,000 rig. Trust me you're not going to get very far with $4-6 grand if you want to build your own car from scratch. Put your $2500 together with your 4-6 g's and buy someone's mid-travel project. Look for one that already has the cage, shocks, transmission, cv's and axles. You will save a HUGE amount of money that way. I have seen plenty of mid-travel cars out there going for around $8k that the owner probably had 2-3 times that invested.
Or if you want to build it yourself you don't have to go mid-travel to still have a ton of fun, convert to linkpin with an 8" beam and you can still get a good amount of travel. Run Type 4 cv's in the rear and you can get a good amount of usable travel, up to 10".
Thats how I'm setting my car up because I'm on a limited budget and it should work out great. _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
1450bug Samba Member
Posted: Fri Feb 22, 2013 2:19 pm Post subject: |
^^x2
6k on a scratch build wont get you much _________________ I like bugs and I don't care who knows |
qwerty8669 Samba Member
Joined: January 07, 2012 Posts: 231 Location: kentucky
Posted: Sat Feb 23, 2013 7:21 am Post subject: |
Oh... Well that's different haha, see this is why I use the forums (: I'm just starting out with this stuff so I'm going to be asking some "stupid" questions and/or have bad ideas. Thanks though guys! I actually found someone's started Baja build, runs and all just needs the shell painted and some bondo work, has a 1600 single in it with bone stock everything so it should be a relatively good start for me.
Thanks again for the input! |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2923 Location: San Antonio, Nuevo Mexico
Posted: Sat Feb 23, 2013 8:51 am Post subject: |
dude...
Introduction
Stage 1 & Stage 2
The Book Of The Car
Beetle Basics
Body ID
Pan ID
The Ball Joint Beam
The IRS Transmission
next is raising the front and rear, installing T3 rear brakes, and installing a bus trans. after that, body lift and the class 11 roll cage.
anything beyond that will be outside the scope of a beginners tutorial _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
